| This is a discussion on Is there a real purpose for the cover above the radiator? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have an 06 Prius. For a long time I've wondered why there is a black plastic cover in the ... |
| priusunum Join Date: Oct 2006 Location: Virginia
My Car: 2006 Prius Model: Package: #3 Thanks: 0
Friends: 0 | I have an 06 Prius. For a long time I've wondered why there is a black plastic cover in the front of the engine compartment, just above the radiator. It's held down loosely by six "screws", actually plastic fasteners with phillips head and sort of a molly screw type of thing in the "threaded" part. After a year of wondering, my curiosity got the best of me and today I removed the six fasteners and took off this plastic cover: I couldn't really see what difference it makes, and so remain mystified. Can anyone tell me what its purpose is? And do the 2007 and 2008 also have such a cover? By the way, in refastening the cover, I broke three of the six fasteners! Perhaps my technique was faulty, but I found it very difficult to get them through the hole without breaking the "molly" screw aspect of the fastener. I was able to fasten those three missing holes by cutting up and using an old earphone cord I didn't need. the cord holds it down ok and it is black so it even matches the cover. I looked for replacement fasteners in Advance Auto, but none looked like they would fit, so I guess I' ll stay with my makeshift fastener.
__________________ priusunum[size=3] |
Friends: 35 | On all of my GM cars it was to help direct airflow from the grille through the radiator. I'm not sure about the Prius but It may play a part of it is for asthetics. |
My Car: 2004 Prius Model: Package: #2 Thanks: 0
Friends: 0 | Instructions for the proper removal method are included in the Owners Manual under headlight replacement. You can get replacement fastners from any Toyota dealer. The manual just calls it a cover, no clue as to the real reason for its being there. |
Friends: 10 | It keeps the matter and anti-matter separated before mixing in the plasma reactor. Tom |
My Car: 2007 Prius Model: Package: #2 Thanks: 167
Friends: 22 | My 2007 has the cover as well. I think we can safely presume that the 2008 has it too. I had to remove the cover recently when I upgraded my OEM halogen headlight bulbs to Philips X-Treme Power halogens (which btw are 80% brighter than the OEMs ... fantastic). Those screws are odd ... they don't really tighten ... they kinda lie loosely in the hole with the "molly" or anchor part keeping the screw from popping out. |
Friends: 37 | Took mine off 3 years ago to install my first grill blocker...never put it back on...think I have the fasteners floating around on my bedside table somewhere. Can't see that it's there for any but aesthetic reasons...so it looks 'purty' when you open the hood. |
| Fat Member Join Date: Jul 2007 Location: Sunny S. Florida
My Car: 2008 Prius Model: Package: #6 Touring Thanks: 31
Friends: 9 | <div class='quotetop'>QUOTE(qbee42 @ Nov 18 2007, 08:52 PM) [snapback]541367[/snapback]</div> Quote:
| Shuttlecraft Commander Join Date: Jun 2007 Location: Out there, somewhere
Friends: 11 | <div class='quotetop'>QUOTE(lefat1 @ Nov 18 2007, 09:24 PM) [snapback]541383[/snapback]</div> Quote:
Friends: 9 | <div class='quotetop'>QUOTE(Doc Willie @ Nov 18 2007, 09:49 PM) [snapback]541392[/snapback]</div> Quote:
My Car: 2007 Prius Model: Package: B Thanks: 3
Friends: 0 | The cover is there to force the air entering the front grills through the rad into the engine compartment. If you remove it some air will flow over the top of the rad assembly. The fans will then run more often. |
| cover, purpose, radiator, real |
| What is the purpose of the rear spoiler? | DougSlug | Gen II Prius Main Forum | 34 | 05-12-2008 03:04 AM |
| What is the purpose of....? | FL_Prius_Driver | Gen II Prius Main Forum | 16 | 08-20-2007 12:11 PM |
| Screen off- on purpose | jamarimutt | Gen II Prius Main Forum | 28 | 10-04-2006 02:18 AM |
| What is the purpose of N, neutral? | george6233 | Gen II Prius Main Forum | 40 | 09-14-2006 10:50 AM |
| Has any one tried to cover the radiator to keep warm? | Ralphmc | Gen II Prius Modifications | 7 | 12-20-2004 09:02 AM |
