This is a discussion on Does ECU Upgrade Fix 04/05 Traction Control? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; 2005 owner who grew up driving in snow. Never been stuck, even with worn tires, in other cars both front ...
Old 03-06-2009, 10:11 AM   #71
CHockMT
Default Re: Does ECU Upgrade Fix 04/05 Traction Control?
2005 owner who grew up driving in snow. Never been stuck, even with worn tires, in other cars both front and rear wheel drive. The 2005 Prius traction control is inadequate, possibly dangerous, and I am hoping there has been a upgrade that either allows the owner to disable the system or severely restricts the operation of the system. Is there an answer from Toyota that I haven't seen?
CHockMT is offline
Old 03-06-2009, 02:45 PM   #72
jayman
Friends: 14
Living in Montana, you also get "real" winter weather, and are probably just as cold as Winnipeg too
Tideland Prius got a new ECU when the dealership made a booboo during a reflash and fried the old one. He claims the Trac behavior is much improved
I test drove a 2008 about a year ago, and can honestly state the Trac behavior is much improved. Still nothing like the Trac on my FJ, but it isn't fair to compare a Prius to an FJ
I finally solved most of my winter traction complaints by running very aggressive, modern studded snow tires. From Canadian Tire I got the Goodyear Nordic, which is the same tire as the Ultra Grip 500 sold in the EU
Goodyear Eur-Winter Tire-UltraGrip 500
If you click on "Profile" a Flash movie loads that explains the tire construction and benefits. Studded, this tire works very well on glare ice, and the aggressive tread is great in snow. On dry pavement, noisy
I've heard good things about the General Altimax Arctic studded. A co-worker has them on a minivan and swears by them.
The factory studded Nokian Hakkapeliitta 5 is a very good winter tire too, but pricey
The only way to disable the Trac is to put the car into Inspection Mode. This is dangerous as you run the very real risk of grenading your PSD or CVT
jayman is offline
Old 03-06-2009, 03:24 PM   #73
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 46
Since this thread has been resurrected, could Tideland please look at his service invoice and let us know the part number(s) of the part(s) that was(were) replaced? Thanks!
Patrick Wong is offline
Old 03-06-2009, 05:20 PM   #74
jayman
Friends: 14
I second that request
jayman is offline
Old 05-26-2009, 05:54 PM   #75
cthindi
Package: Base - CA
I bought a used 2005 Prius as well.
a) Is there any way to know if ECU was upgraded ?
b) Is there a way to know if cars built prior to certain date were required in ECU upgrade?
I do not know from service records if this was done. I do not see this in any formal recalls for this car. I see that a steering recall was issued. My car has that recall addressed. I could not see any formal recall for ECU anywhere. Was that a voluntry or a soft recall from Toyota? Was there any letter sent to registered owners back then?
Thanks,
Parag
cthindi is offline
Old 05-26-2009, 07:19 PM   #76
jayman
Friends: 14
Tideland Prius had his ECU replaced due to the dealer making a booboo and frying the original ECU during a flash update process for another problem
I'm not aware of any dealership procedure to "upgrade" the ECU itself, short of a problem requiring replacement. The flash updates for issues like The Stall (My '04 had that happen) do not have any effect on TC behavior
jayman is offline
Old 05-26-2009, 09:48 PM   #77
cthindi
Package: Base - CA
I meant flash (software) upgrade when I said ECU upgrade.
Was that a standard recall based on some build date or was it done strictly as a resolution of the problem? Is there any version information you can find out yourself from some hidden screens?
cthindi is offline
Old 05-27-2009, 12:02 PM   #78
jayman
Friends: 14
I'm unaware of any flash to change the TC behavior. I had to have my car reflashed due to The Stall. It had no impact whatsoever on TC behavior
jayman is offline
Old 06-02-2009, 09:04 AM   #79
mikey1377
My 06 has this problem too (of spinning and stopping when trying to climb a snowy hill). I put studded snow tires on in the winter which helps a bit...but I'm wondering.
Would the "Power Mode" on the 2010 Prius help with this? Since the wheels stop spinning to protect the electric motors, I'm thinking power mode might give me that little extra boost to make it up the hill.
mikey1377 is offline
Old 06-02-2009, 12:40 PM   #80
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
Along the same lines, I had heard from a PriusChatter in Europe that with his European Gen II, the "EV Mode" solved this problem.
Boo is offline
04 or 05, control, ecu, fix, traction, upgrade
