This is a discussion on Photo of blocked front Grill. within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; bc104, excellent job....
Old 01-22-2008, 10:00 PM   #11
JimN
P719 of ???
JimN's Avatar
Default Re: Photo of blocked front Grill.
JimN is offline
Old 01-23-2008, 12:58 AM   #12
jiw395
It works for me, my mpg's went up instantly,like the minute I drove it after blocking off the intakes. It went from low 40's to mid to high 40's like 45/46, and it did that the very next time I drove it...
jiw395 is offline
Old 01-23-2008, 11:31 AM   #13
bc104
bc104's Avatar
Talking Re: Photo of blocked front Grill.
Thanks, JimN.
My mileage has gone up as well, but I did several things at the same time. I blocked the grill, put a small piece of insulation on top of the engine (it doesn't touch the block or exhaust and is far away fromthe fan belt, just on top of the plastic), I'm driving a bit smoother (although I was already trying pretty hard not to use the gas too much) and I haven't used the heat. The begining of the tank was at 43 mpg average (about 20 miles used) and now I have 3 bars left at 51 mpg. I think I'm on to something here!
bc104
bc104 is offline
Old 02-07-2009, 09:01 PM   #14
dropkin
Do you all have SG's ? I have to contend with the "W" factor, so SG or not, it can't be something she has to think about. I'm in Westchester County, NY, and some morning's it's a solid 5 degrees. I'm getting about 45 mpg, but considering I usually get 60 in the summer, I was hoping there was a "low tech" and "set it and forget it" solution.
dropkin is offline
Old 02-07-2009, 09:15 PM   #15
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
There is, move to a warmer climate.
patsparks is online now
Old 02-08-2009, 08:40 PM   #16
Green Hokie
Green Hokie's Avatar
Package: S Touring
I like Pat's solution!
However, for those who cannot afford the move, here are some pics of mine. http://priuschat.com/forums/prius-mo...-blocking.html
Green Hokie is offline
blocked, front, grill, photo
