This is a discussion on 08 Prius: Pulls to the left when braking. within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Ever since I got my new Prius, it pulls to the left on braking about half the time. It doesn't ...
LinkBack (1) Thread Tools
Old 03-14-2008, 07:47 PM   1 links from elsewhere to this Post. Click to view. #1
Joe 26
Joe 26's Avatar
Default 08 Prius: Pulls to the left when braking.
Ever since I got my new Prius, it pulls to the left on braking about half the time. It doesn't jerk the wheel out of your hand, but is annoying. It happens on both light and hard braking. Originally it pulled to the left while cruising as well, but an alignment at the dealer fixed that(too much negative camber RF) but says there is nothing wrong with the car otherwise.
I am looking for some ideas, and if anyone else has had this problem when their Prius was new and what was done to correct it.
Thanks, Joe
Joe 26 is offline
Old 03-14-2008, 07:50 PM   #2
silverbell
Default Re: 08 Prius: Pulls to the left when braking.
Not normal. No way. Ask to test drive other Priuses on the lot.
silverbell is offline
Old 03-14-2008, 07:50 PM   #3
silverbell
Old 03-14-2008, 08:00 PM   #4
Joe 26
Joe 26's Avatar
I know it is not normal, I am a certified master auto techician, currently doing verification inspections for extended warranty (including extra care). The problem is trying to convince the service writer and dealership, and hopefully giving them a direction to go in to solve it.
Joe 26 is offline
Old 03-14-2008, 08:07 PM   #5
derkraut
derkraut's Avatar
Package: #8
Definitely something amiss. On my car, I can take my hands off the wheel and apply the brakes. The car slows on a straight line. Have the mechanic @ your dealership drive it with you in the car, and see what he says.
derkraut is offline
Old 03-14-2008, 08:53 PM   #6
priusincc
priusincc's Avatar
My '07 did the same thing. Most of it went away after I got an alignment. The first alignment (within 12K miles) should be no charge on the warranty. At least, they were doing it for the 07 model.
Like I said most of it went away, but it still has a slight tendency to pull to the left when braking. I guess, it's the nature of the beast.
priusincc is offline
Old 03-15-2008, 12:07 AM   #7
dogfriend
Human - Animal Hybrid
dogfriend's Avatar
Friends: 11
I had this problem when I first got my car. My car was out of spec for rear toe-in and front cross camber (difference in camber side to side). The dealer actually made the camber problem worse. I was able to fix the rear with shims. Fixing the cross camber helped to get rid of the pull.
My ugly saga in this thread:
http://priuschat.com/forums/care-mai...tml#post440934
BTW, there is a TSB for the dealer to use to diagnose this problem. It could be alignment or a tire problem. I posted the TSB in this thread:
PULL to the Left Problem
My friends Dingo and Digby
dogfriend is offline
Old 03-15-2008, 01:23 PM   #8
jayman
Some Honda's are also prone to a PTTL (Pull To The Left) at least according to a co-worker of mine. Apparently, most of the Honda dealers around here invested in a Hunter GSP 9700 Road Force Balance tire balancer to aide in diagnosis
Hunter GSP9700 Wheel Vibration Control System
THe GSP 9700 will easily find tire/rim problems that are impossible to find with conventional wheel alignments or static tire balancing. I've never had a problem with my Prius, but have had issues with my FJ Cruiser
My FJ came from the factory with awful Dunlop Grandtrek tires that would hydroplane on dew. Well, almost that bad anway. The FJ has a tall tire, P265 70 17, so any issue will become very apparent
I had a slight pull to the right, which alignment did not fix. Also a slight vibration in the steering wheel and in my butt, despite repeated static balancing
Found out about the Hunter Road Force machine, drove over to a Honda dealer, and they claimed they had already seen a few FJ's come in with vibration and pull problems on aftermarket tires.
It took them 4 hours. The machine suggested what tire go with what rim, a lot of dismounting involved. One tire was considered "bad" - despite having less than 200 km on it (Ply pull ??) - and they had to get another one from the tire dealer
So after all that, went out on the Trans Canada. At speeds of 80-90 km/h the problem was the worst. No more problem. Smooth, tracks straight, one finger on the wheel. A huge day and night difference
So when I got the steel rims and Toyo winter tires, I didn't even hesitate. Dropped them off at the Honda dealer and let them mount and balance the tires. They claimed it took 3 hours to properly match the tires to the rims.
IMHO the cost is worth it, if you already have an issue. I expect vehicles to track straight, and not to have any vibration. If you have a pickup or SUV with tall tires, you will probably experience pulling or vibration problems that conventional static balancing and wheel alignment cannot resolve
jayman is offline
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-main-forum/44142-08-prius-pulls-left-when-braking.html
44142 08 Prius Pulls Left When Braking Rapidshare Search Engine - Meta search engine - search DVD, MP3, ISO, music, video, games This thread Refback 05-16-2009 10:25 AM
