| This is a discussion on Automatic Shut Down within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hey Everyone, I enjoy reading the questions and answers of each forum. It is very helpful. I've owned my prius ... |
Automatic Shut Down
| Junior Member Join Date: Mar 2008 Location: Hampstead, NC
Friends: 0 | Hey Everyone, I enjoy reading the questions and answers of each forum. It is very helpful. I've owned my prius for three weeks with three fill ups. 42.7 mpg on tank one, 49.9 on second tank and 51.2 on third tank. Gets better every time. Anyway on to my question. If I leave my car running, because I fail to turn it off, will it turn itself off after a period of time? When I hit park, the car is so quiet I sometimes forget to hit the off button. Absent minded of me, but that is what old age does to you. |
My Car: 2004 Prius Model: Package: #2 Thanks: 0
Friends: 0 | No, it will continue to run the ice periodically until the fuel tank is empty. This is a good reason not to use Park before hitting the start button, just make a habit of using the start button to shut it down, it will automatically put the car in park. |
Friends: 10 | The automatic shutdown feature kicks in after you burn all of the gas. The Prius will fight hard to keep a charge in the HV battery, and without being able to run the gas engine, it will shut down. While the above is completely true, I don't suppose that's exactly what you had in mind when you asked your question. Tom |
My Car: 2004 Prius Model: N/A Package: Base Thanks: 128
Friends: 33 | Quote:
Welcome to PC and enjoy you fantastic car. | |
| Junior Member Join Date: Apr 2004 Location: Erial, NJ
Friends: 0 | On the plus side, it doesn't take a huge amount of fuel to keep the car running. I once accidentally left it running after driving to work. When I came out after work, the car was running, the interior was nicely cooled (summer), and I'd used about an 1/8 of a tank. In terms of remembering to turn off, it won't let you lock the doors and will beep at you, I believe. 4 long beeps when you close the door without the fob inside, and pressing the door handle lock button does nothing. |
Friends: 0 | Thanks everyone, I thought I read somewhere that you should always push park and then the off button. Is it safe to just hit the off button long term? |
| Member Join Date: Jan 2008 Location: Los Angeles
My Car: 2006 Prius Model: Package: #2 Thanks: 0
Friends: 0 | Hello, Be careful!!! you MUST NOT forget to turn off the car if you are parked in a garage. Carbon monoxide buildup is deadly! ![]() Put a sign up in your garage if you have to (Did I turn off my car?) Stay safe! Andrew |
My Car: 2007 Prius Model: Package: B Thanks: 3
Friends: 0 | Yes, it's safe to just hit the Power button to turn the car off. It will always go into "park" (unless it's moving). If moving slowly it will try to go into park and probably succeed once it slows below a few MPH. This is not healthy, so don't test it. All together now, "my car is smarter than me, my car is smarter than me".
| Senior Member Join Date: Feb 2008 Location: Maryland
Friends: 0 | I agree that the car can be quiet when not moving, but aren't there other clues that it's still on? -MFD is on -Speedometer and other instruments are illuminated -Climate control functioning -CD/Radio emiting sound |
| Has his homepage set to PC Join Date: Mar 2005 Location: Vancouver, BC
My Car: 2005 Prius Model: Package: B Thanks: 0
Friends: 3 | The car will turn itself off after an hour in ACC mode, but like others have said, it'll just stay in READY until you run out of gas. |
| ICE Wouldn't shut off - 20-30 MPH | bigmahma | Gen II Prius Fuel Economy | 20 | 07-11-2007 12:29 AM |
| Proper way to shut down | splashback | Gen II Prius Main Forum | 11 | 05-15-2007 12:36 AM |
| Shut down!! | treehuger | Gen II Prius Technical Discussion | 11 | 03-06-2007 04:18 PM |
| My headlights don't shut off | AlphaTeam | Gen II Prius Care, Maintenance and Troubleshooting | 13 | 08-30-2006 06:25 AM |
| Shut the A/C off? | Walker1 | Gen II Prius Main Forum | 20 | 03-07-2006 11:08 AM |
