This is a discussion on Battery temp and other high precision gauges! within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I know I've been posting like crazy on this stuff, but man, I've been hoping someone would get this working ...
Old 07-01-2008, 04:18 PM   #1
Dan.
MPG Centurion
Friends: 21
Default Battery temp and other high precision gauges!
I know I've been posting like crazy on this stuff, but man, I've been hoping someone would get this working for a long time. So please excuse the excess traffic.
OK... I'm pretty much done with my XGauge hacking for the time being. What I've managed to piece together is pretty neat. I've attached my latest drop.
  1. SOC and BTA on the same gauge!
  2. Speedometer with a decimal point precision.
  3. A gas gauge with 4 times the precision of the "guess gauge"
  4. Realtime RPM (no half second delay on the SG refresh).
  5. Coolant temp with half-degree precision.
  6. Gas pedal position indicator (0-100% depressed).
  7. Brake Pedal position indication (0-100%).
  8. HV pack temperature gauge.
  9. An "ON/OFF" gauge to know if the EV button is "ON or OFF"
I'm hoping someone else can pick up the torch and find MG1-rpm, MG2-rpm, and inverter temp.
11011011
Click the image to open in full size.Click the image to open in full size.
Best commute = 14.3mi @ 114 MPG (sg2)
Best (non-trivial) tank = 1101mi @ 91.2 MPG (fcd)
MPG Centurion-Hybridfest 2007-Prius II-26mi @ 106 MPG (sg2)
Dan <11011011> @ CleanMPG.com
Dan. is offline
Thanked by:
mlupan (10-23-2009)
Old 07-01-2008, 06:21 PM   #2
Sheepdog
C'Mere Sheepie!
Sheepdog's Avatar
Friends: 7
Default Re: Battery temp and other high precision gauges!
Dan this might be beneath you to answer, but I have a scan gauge now but have no idea how to program these nice gauges in? Be there a reference somewhere?
Sheepdog is offline
Old 07-01-2008, 06:32 PM   #3
archae86
You want to look up XGauge editing on page 25 of the user manual. It is on page 27 of the pdf.
archae86 is offline
Old 07-01-2008, 09:52 PM   #4
Bob64
Sapphire of the Blue Sky
Bob64's Avatar
Kudos.
Glad my earlier thread was slightly useful
Bob64 is offline
Old 07-01-2008, 09:55 PM   #5
Dan.
MPG Centurion
Friends: 21
Originally Posted by Bob64 View Post
Kudos.
Very much so. Thanks for all the ground breaking.
11011011
Dan. is offline
Old 07-02-2008, 09:40 AM   #6
Highly ImPriused
Impressive Member
Highly ImPriused's Avatar
Package: #1
This is great work and deserves a bump. Thanks so much Dan and others!
Highly ImPriused is offline
Old 07-02-2008, 10:24 AM   #7
orracle
Whaddaya mean "senior" member?
orracle's Avatar
Friends: 8
Now could someone figure out why I can no longer get anything for "tank--to empty"?
I used to get a reading and now it just bounces back to "current". I have e-mailed the SG people 3 times with no response.
orracle is offline
Old 07-02-2008, 10:29 AM   #8
Bob64
Bob64's Avatar
Certain "Active" gauges can't be used at the same time. Try changing the other 3 gauges to something else.
Bob64 is offline
Old 07-02-2008, 11:51 AM   #9
Dan.
MPG Centurion
Friends: 21
I suggest liberal use of "reset factory defaults". On the way home yesterday, my "CURRENT" mpg registered a 52, where I'm normally in the 80's. I suspected one of the passive gauges so I cleared them all before heading into work this morning. Well about 3 miles in, I've got current mpg up and I watch it drop (over one-second) from 78 to 27. The 27 stuck and the glide worked that number back up to 50 by the end of the glide. So I then did a factory reset and everything cleared up ok. I've slowly started adding gauges back and all looks well.
I suggest that you play around with the gauges until you get a "proven" set. Once you have that, clear them all and perform a factory reset. The after a few miles on a "clean gauge" add the "proven" ones back.
I'll let you know if I get any other random drops in MPG. This is why I always check my SG numbers against my FCD.
11011011
Dan. is offline
Old 07-02-2008, 03:49 PM   #10
orracle
orracle's Avatar
Friends: 8
I have pushed every frickin' button there is and reset it several times. It also lost most of the colors after it's "upgrade"
Since my year of service is coming to a close, I am going to try and send it back.
orracle is offline
canbus, prius, sgii
Is Battery Temp Reason for Low MPG @ Lo Temp? msilverb Gen II Prius Technical Discussion 7 02-21-2008 07:38 PM
High HV Battery Temp and Cooling fan p626808 Gen II Prius Care, Maintenance and Troubleshooting 7 09-20-2007 09:42 PM
Precision fit care seats?? draker Gen II Prius Main Forum 1 02-24-2007 03:01 AM
High voltage battery always in high charge state kkayser Gen II Prius Technical Discussion 8 02-03-2007 07:51 PM
Battery Temp efusco Gen II Prius Fuel Economy 22 02-22-2006 10:43 PM
