This is a discussion on Synergy drive technical questions... within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by JimboK I had forgotten about this, but in researching something for an unrelated thread I rediscovered this ...
Old 07-17-2008, 10:45 AM   #11
Highly ImPriused
Impressive Member
Highly ImPriused's Avatar
Package: #1
Default Re: Synergy drive technical questions...
Originally Posted by JimboK View Post
I had forgotten about this, but in researching something for an unrelated thread I rediscovered this, in case you're at all inclined to a DIY hack.
Which is great, but too much work for probably 99% of drivers to consider (myself included). Shouldn't there be a signal in the CAN that indicates when there is hydraulic pressure to the friction brake system? If so, it would seem simple enough (for someone who knows what they're doing -- again, not me) to code an XGauge (or whatever CanView uses) to pick up on this and display a simple on/off message. That would be very useful. I try to keep braking regeneration to about 60 amps, but as mentioned above, it's very easy to exceed that at higher speeds. I wonder when I'm seeing 90+ amps if there is also some friction braking being done. I expect there is at times, but it would be nice to know a what point that actually occurs and to be better able to avoid it in future situations.
The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man. - George Bernard Shaw
Last edited by Highly ImPriused; 07-17-2008 at 10:47 AM. Reason: spelling, clarity
Highly ImPriused is offline
Old 07-17-2008, 02:08 PM   #12
JimboK
One owner, low mileage
JimboK's Avatar
Friends: 6
Me too!
If there is, no one has reported finding it, AFAIK. There is a CAN data element for brake pedal position, but of course it tells you nothing about whether a given position engages the friction brakes.
This got me to wondering about the relationship between pedal position and regeneration. I threw together a chart from my CAN-View data and, to avoid straying too far off-topic here, posted it in my CAN-View charts thread.
JimboK is offline
drive, questions..., synergy, technical
Variants of Hybrid Synergy Drive bredekamp Gen II Prius Technical Discussion 17 03-15-2008 10:50 PM
Hybrid Synergy Drive emblem FS? sal Private Sales 7 08-28-2007 06:04 PM
Hybrid Synergy Drive Community efusco Gen II Prius Main Forum 3 10-10-2006 02:32 AM
hybrid synergy drive commercial galaxee Gen II Prius Main Forum 10 10-10-2006 12:47 AM
Synergy Drive Problem Petterr_Pan Gen II Prius Technical Discussion 8 09-28-2006 11:27 AM
