This is a discussion on Synergy drive technical questions... within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; 1) How can you tell when the brake pads engage. i.e. I'd like to brake as hard as possible but ...
Old 07-16-2008, 04:24 PM   #1
sorka
Default Synergy drive technical questions...
1) How can you tell when the brake pads engage. i.e. I'd like to brake as hard as possible but without engaging the pads. Is there an indicator light or some other method for knowing when you're wasting energy on braking?
2) Is the management software smart enough not to completely charge the battery while in motion? I'm assuming that the system is smart enough to leave enough room in the battery for a full regenerative capture when braking? If it wasn't, then you'd waste energy by braking with an already fully charged battery.
sorka is offline
Old 07-17-2008, 05:06 AM   #2
effwitt
Paparazzi Magnet
effwitt's Avatar
Default Re: Synergy drive technical questions...
1. No indicator light, but light to moderate braking doesn't use the brake pads until you drop to 7 MPH.
2. A lot of work was done to make the management software very smart. Even if you have all the bars, the battery is only 80% charged. It doesn't take very long to use a bars worth of energy.
effwitt is offline
Old 07-17-2008, 07:17 AM   #3
JimboK
One owner, low mileage
JimboK's Avatar
Friends: 6
Originally Posted by sorka View Post
1) I'd like to brake as hard as possible but without engaging the pads.
Why? Light to moderate braking is more efficient. See this for more.
Effwitt is correct about the 80% level being "full." (Actually I've seen it go as high as 82% after a long descent out of the mountains with continuous regeneration.) Taking it a step further, the car aims for an optimal charge of 60% (six blue bars) to allow just what you suggest -- headroom for any upcoming regeneration.
JimboK is offline
Old 07-17-2008, 08:38 AM   #4
archae86
I wish that the standard display on the Prius supported that function but it does not.
I can get a pretty good approximation using my ScanGaugeII. With a cool battery at moderate charge level it will allow you something like 95 amperes of regeneration. If I modulate the braking level a little, and see the regeneration current change, I figure I'm not at maximum yet. This is necessary because the actual maximum value drops with a hotter battery or a higher state of charge.
While some folks posting here would have you believe that you're not likely to exceed the regeneration maximum unless you are braking pretty hard, watching the SG2 has taught me that at higher speeds on downhill it is really quite easy to go past the maximum. 90 amperes of regeneration at 70 mph does not feel like very strong deceleration at all. On the other hand at 25 mph it is quite robust.
archae86 is offline
Old 07-17-2008, 08:48 AM   #5
JimboK
JimboK's Avatar
Friends: 6
I had forgotten about this, but in researching something for an unrelated thread I rediscovered this, in case you're at all inclined to a DIY hack.
JimboK is offline
Old 07-17-2008, 09:06 AM   #6
bushface
bushface's Avatar
I go down a 12% grade (per state road sign) for 3 miles every workday, at the top I shift the Prius to "B" to help with braking. Half way down the grade when my battery shows full, the motor speeds up like my jeep manual drive when I gear down. Or at least that what it sounds like. What is going on? I suspect that the ICE is doing the braking without regen the battery. I wish that I could not have the battery at 4 or 5 bars at the top of the grade but at 2 bars.
SIPPING GAS ON THE WAY TO WORK OR CHURCH OR PLAY.
2008 MAGNETIC GRAY # 2 WITH LEATHER INTERIOR. HYDROEDGE TIRES AT 44 AND 42 PSI. MOBLE ONE OIL. LIFETIME MPG 50.03 AT 37670 MILES WITH 752.896 GALLONS.
WE SUPPORT OUR TROOPS AND MAY GOD BLESS THEM.
bushface is offline
Old 07-17-2008, 09:30 AM   #7
That is exactly what is happening. Once the battery is full, regenerative braking no longer has a place to dump all of the generated electricity, so it uses the excess electricity to spin the ICE. The ICE is being used as a big friction device by pumping air with the valves in a high drag configuration.
You deserve some sort of prize for being one of the few Prius drivers to correctly use B mode. This is exactly the application for which it was designed.
You might be a good candidate for an EV switch. That way you might be able to keep your SOC low before you hit the top of the hill.
Black 2006 package #7
Northern Michigan
Old 07-17-2008, 10:26 AM   #8
sorka
....because you're not engaging the brake pads. What I want to know is if there's a way to tell when the brake pads engage.
sorka is offline
Old 07-17-2008, 10:28 AM   #9
sorka
That is very cool. So of course they did the right thing. That's awsome.
sorka is offline
Old 07-17-2008, 10:38 AM   #10
David Beale
David Beale's Avatar
First, be aware the pads are brought to the rotor as soon as you press lightly on the brake pedal. They are not pressed against it however, just placed in a "ready" position.
So far, the only way anyone has come up with to tell if the braking is friction or not is the DIY circuit posted above.
At slower speeds most reasonable braking is regen. If you panic stop (quick and hard application of pedal) it is purely friction. Be careful, in this situation the car will just about stop on its' nose.
David Beale is offline
drive, questions..., synergy, technical
Variants of Hybrid Synergy Drive bredekamp Gen II Prius Technical Discussion 17 03-15-2008 10:50 PM
Hybrid Synergy Drive emblem FS? sal Private Sales 7 08-28-2007 06:04 PM
Hybrid Synergy Drive Community efusco Gen II Prius Main Forum 3 10-10-2006 02:32 AM
hybrid synergy drive commercial galaxee Gen II Prius Main Forum 10 10-10-2006 12:47 AM
Synergy Drive Problem Petterr_Pan Gen II Prius Technical Discussion 8 09-28-2006 11:27 AM
