| This is a discussion on Aerodynamic Anomaly? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Priapus seems to have picked up a noise like air being disrupted. It reminds me of when I'm riding in ... |
My Car: 2004 Prius Model: Package: #9 Thanks: 56
Friends: 27 | Priapus seems to have picked up a noise like air being disrupted. It reminds me of when I'm riding in a friend's car with the canoe rack mounted. I've checked all over and can't find anything out of place. There's nothing to hear until I reach 40 mph. At that speed, it's constant. At 55 mph, it is pulsing. It starts with nothing, increases in noise, then decreases to nothing again. By my count, it's one second increasing, one second decreasing, and one second quiet. But only at 55 mph. I actually have not exceeded 55 mph since hearing it so I can not report on faster speeds. As I was washing him last weekend, I noticed that the spoiler seemed a little looser than I remember. Nothing overly alarming, but I seemed to be able to wiggle it up and down more than I remember being able to. Not that I try often. Another item for consideration is that I am due for new tires. I'm still running stock tires after about 47,500 miles. Thoughts?
__________________ |
My Car: 2008 Prius Model: Package: #6 Touring Thanks: 164
Friends: 2 | Did you check up under the chassis? It's possible that you have a plastic bag or other road debris stuck on something under there. Loose mud flap or tire air dam? [Edit] There are a few plastic belly pan pieces under there too. Perhaps one is torn and has a flap hanging down into the air stream. Last edited by Rokeby; 07-18-2008 at 08:32 PM. |
| A young senior member Join Date: Mar 2006 Location: Chicagoland, IL USA, Earth
My Car: 2006 Prius Model: Package: #1 Thanks: 24
Friends: 4 | Rokeby might be onto something. But you might need a helpful friend to hang over the front of your car looking underneath as you increase speed. Above 40 mph your friend should be able to easily spot the problem. (I am not a helpful friend). |
| C'Mere Sheepie! Join Date: Mar 2008 Location: Sanford FLorida
Friends: 7 | "(I am not a helpful friend)." LOL! At 40mph who would be?! |
| Re-Member Join Date: Mar 2005 Location: Philly, PA
Friends: 0 | If the sound is coming from the rear and you think that the spoiler may be loose, try some blue painters tape at the base of the spoiler. For a few cents you can eliminate one (of many) possibilities. |
My Car: 2004 Prius Model: Package: #2 Thanks: 0
Friends: 0 | Tony, you failed to mention if the windows are open or closed! I get the pulsing when I forget to close one of the rear windows. |
| Impressive Member Join Date: Mar 2007 Location: Western NY
My Car: 2007 Prius Model: Package: #1 Thanks: 0
Friends: 0 | Could it be the cargo area cover? I notice that tends to rattle a bit at times. |
| Senior Member Join Date: May 2008 Location: Nashua NH
word to describe the most annoying sound i ever encountered with a back window down. | |
Friends: 27 | Quote:
It's been almost a week since I started hear the noise. Of course, I didn't want to start a thread and then find out that it's something simple like the gas lid was open. So as I mentioned, I have spent the week looking, listening, trying to pinpoint what it might be. Usually when I'm moving at all, the windows are about one inch cracked and when I'm above 50 mph they are all the way up. I have heard it regardless of window position. It does sound as though it's coming from the back. If I had to pick a side, I'd say back passenger side. | |
Friends: 0 | Have you considered an out of round tire? The noise is speed related, and you can sometimes get a pulsating sound from the tires. And if it is a rear tire, you won't necessarily feel it like you would a front tire. |
| aerodynamic, anomaly? |
| Logical Anomaly? | robnich | Gen II Prius Main Forum | 18 | 04-12-2008 12:08 AM |
| MPG Anomaly | mjones675692 | Gen II Prius Fuel Economy | 8 | 10-24-2007 12:03 PM |
| The most Aerodynamic car in the market? | sebapisa | Gen II Prius Main Forum | 26 | 03-04-2007 04:46 PM |
| Aerodynamic Hubcaps | Cheap! | Gen II Prius Technical Discussion | 22 | 09-01-2006 07:08 AM |
| Aerodynamic's importance. Whoa! | Kablooie | Gen II Prius Main Forum | 2 | 08-10-2006 02:08 PM |
