| This is a discussion on DVD Nav 8.1 hack on 2009 prius? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by LeviSmith Pretty sure it does. I have yet to get a "fully reliable" copy working, but I ... |
| | #31 | |
| Member Join Date: Aug 2009 Location: NY 11020
My Car: 2005 Prius Model: N/A Package: Navigation Thanks: 15
Friends: 1 | Quote:
wasnt worth the override tried it in 2005 prius gen 4 navigation sysytems are very good with copied dvds gen 2/3 sucks specially in 200-2003 cars gen 5 has problem with some cars only , prius is one of them | |
| | #32 | |
| Member Join Date: Mar 2004 Location: Newark, DE
1. Get the new 9.1 disk for the '05 Prius 2. Make an ISO of the 9.1 disk 3. Take my original disk from my '05 Prius 4. Copy the loading.kwi file off of my original disk 5. Use UltraISO to replace the loading.kwi in the 9.1 ISO with the loading.kwi that I copied off my original disk 6. Burn that updated ISO and put it in the car 7. Enjoy the 9.1 map data with the old override trick Am I missing anything besides potential burning issues here? As a general question. If the burn of the hybrid old/new disk doesn't work, I just put my original disk back in, correct? Also, if I put in the unaltered 9.1 disk, I lose my override sequence. If I put my original disk in, do I get the override sequence back? Thanks! Brian Last edited by Cyndrax; 12-02-2009 at 03:18 PM. Reason: spelling error | |
| | #33 | |
My Car: 2004 Prius Model: N/A Package: N/A Thanks: 2
Old disc going back in after trying a failed hybrid will keep you just as you were. The answer I see most often is that once a 2006 or newer disc goes in your override is lost forever. However, I *thought* I saw a post somewhere about opening the Nav unit itself and finding a reset switch to allow you to go back to the 05' disc... But I'd call that iffy at best... Levi | |
| | #34 |
Friends: 1 | |
| | #35 | |
Navigation ECU disassembly | |
| 2009, hack, prius? |
| 05 Prius Radio Hack? | bugssmith | Gen II Prius Audio and Electronics | 1 | 04-06-2008 03:32 AM |
| 2007 Prius and the navigation hack | GatorJoe | Gen II Prius Technical Discussion | 4 | 07-18-2007 10:58 PM |
| Prius Hack Installations | starkeef | Gen II Prius Audio and Electronics | 2 | 01-28-2007 01:41 PM |
| 2004-06 prius fob hack? | statultra | Gen II Prius Technical Discussion | 6 | 06-30-2006 10:16 AM |
| Hack your Mac into your Prius MFD!! | m2oore | Gen II Prius Main Forum | 1 | 03-22-2006 09:04 PM |
