This is a discussion on Prius Uses after Hurricane Ike within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Bump. Anyone have a go by guide for doing this?...
Old 10-05-2008, 10:30 AM   #11
HomeandRanch
Default Re: Prius Uses after Hurricane Ike
HomeandRanch is offline
Old 10-05-2008, 11:17 AM   #12
bwilson4web
03 and 10 Prius
bwilson4web's Avatar
Package: #1
Friends: 23
There are two approaches today:
  • 12 VDC inverter - using commercial, off the shelf, inverters, you can draw 1 kW using the 12 VDC system. Several have done this and a "search" for "UPS Prius" should give multiple hits including mine.
  • 202 VDC traction battery - using UPS inverters that use a 200 VDC range internal battery pack, put plugs on the traction battery and use the inverter to generate up to 3 kW (test) of AC power like Richard did.
A 1 kW inverter is enough to 'camp out' at home. It can drive the fan of a gas furnace in the winter or a 5,000 BTU window AC in the summer and a TV, a few florescent lights and a laptop. The 3 kW inverter can also keep the fridge running and a microwave if you are careful about load balancing.
bwilson4web is offline
Old 10-06-2008, 12:54 AM   #13
Erin Rothchild ~ RE/MAX
Erin Rothchild ~ RE/MAX's Avatar
Package: #2 Touring
Thank You : )
Erin Rothchild ~ RE/MAX is offline
hurricane, prius
Hurricane Ike - Floridian - YIKES! Prius as basic generator advice. partipilo Gen II Prius Technical Discussion 11 09-18-2008 10:40 AM
Prius and hurricane evacuation Texguy Gen II Prius Main Forum 9 07-09-2008 07:27 PM
Getting ready for ANOTHER HURRICANE!! :( BT Tech Fred's House of Pancakes 18 10-29-2005 12:05 AM
Hurricane Frances on e-bay DaveinOlyWA Fred's House of Pancakes 3 09-07-2004 11:15 PM
Getting ready for ANOTHER HURRICANE!! :( BT Tech Gen II Prius Main Forum 0 12-31-1969 07:00 PM
