This is a discussion on Hurricane Ike & Prius Power within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by statultra since the high voltage battery is about 200 volts DC... is it possible to hook up ...
LinkBack (1) Thread Tools
Old 09-21-2008, 03:51 PM   #21
bwilson4web
03 and 10 Prius
bwilson4web's Avatar
Package: #1
Friends: 20
Default Re: Hurricane Ike & Prius Power
Originally Posted by statultra View Post
since the high voltage battery is about 200 volts DC... is it possible to hook up two modules in paralell, giving 14.2 volts, and having all of the 28 modules producing the 14.2 volts while still having the cars 201 volt series connections? then using the 14.4 volt power to a high wattage inverter ( 6000-12000 watts )?. . .
No but the 200 V could be connected to a high power, 3 kW, UPS systems that uses 200 V battery bus. IMHO, the right answer is to design a proper co-generation system so our Prius can be used to run the house.
bwilson4web is offline
Old 09-22-2008, 03:39 PM   #22
drewtx
Thanks to everybody for all the additional info.
We are still without power at home - but running happily on Prius Power.
My original 100w inverter died, so I replaced it with a 350w model from Radio Shack. This may not be the 'best' inverter available, but seems to work OK; I just needed a replacement quickly. It came with cables/clips to hook it directly to the battery terminals. 350w has been ample for running TV, a dvd player, cooling fans, a Wii and some CFL lights. I have not tried running everything at the same time - more because we just don't need all that stuff running all the time.
MUCH quieter - and significantly cooler ;-) - than running a nasty generator 24/7.
I CERTAINLY consider an inverter to be a VITAL piece of my emergency kit now
drewtx is offline
Old 09-22-2008, 05:16 PM   #23
zenMachine
Just another Onionhead
zenMachine's Avatar
Drew,
Best wishes to you. Glad to hear the 300W inverter works out. Thank God for Prius Power, no doubt.
Does anybody have any recommendation on a good inverter? I've been looking at some 1000-1500W inverters from Cobra and Duracell. Not sure which one is better. Any pointers much appreciated.
zenMachine is offline
Old 09-22-2008, 06:00 PM   #24
hoop
On The South Texas Coast
if you have natural gas, its a better deal to invest in a 15kw or 11 kw standby generator with transfer switch.
Funny thing, The gas company shut off all natural gas to galveston island due to the many leaks. wouldnt that tick you off..Pay all that money for a generator that runs on natural gas and then they shut it off.
hoop is offline
Old 09-23-2008, 12:27 AM   #25
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
I think all the modified sine wave inverters 100-1500 watts, $100-$150 are going to be very similar regardless of the name on the label. I used a Whistler and it was OK. A little too sensitive on the high temperature lockout maybe?
If you install in the vehicle, consider it a high-vibration environment. I opened the case on the Whistler and found several loose bits of solder. Get those out.
The pure sine wave inverters are going to be much more expensive. $300 minimum $600 typical for this power output range. Would like to assume those would be built to a higher standard, but I'd open the case for a look anyway.
DAS
tochatihu is offline
hurricane, power, prius
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-main-forum/53671-hurricane-ike-prius-power.html
53671 Hurricane Ike Prius Power Rapidshare Search Engine - Meta search engine - search DVD, MP3, ISO, music, video, games This thread Refback 05-16-2009 11:33 AM
Prius Uses after Hurricane Ike sugar land dave Gen II Prius Main Forum 12 10-06-2008 12:54 AM
Hurricane Ike - Floridian - YIKES! Prius as basic generator advice. partipilo Gen II Prius Technical Discussion 11 09-18-2008 10:40 AM
Prius and hurricane evacuation Texguy Gen II Prius Main Forum 9 07-09-2008 07:27 PM
Hurricane Frances on e-bay DaveinOlyWA Fred's House of Pancakes 3 09-07-2004 11:15 PM
Getting ready for ANOTHER HURRICANE!! :( BT Tech Gen II Prius Main Forum 0 12-31-1969 07:00 PM
