| This is a discussion on Shattered rear glass within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Auto glass is tempered. That puts incredible strain in it. The purpose is to make it stronger and to ensure ... |
| | #21 |
My Car: 2007 Prius Model: Package: B Thanks: 4
Friends: 0 | Auto glass is tempered. That puts incredible strain in it. The purpose is to make it stronger and to ensure that if it is broken, it will end up in tiny pieces as seen above that won't kill you. Now, if you put a small scratch on a tempered glass sheet the forces will concentrate there, probably eventually getting strong enough to cause the sheet to fail (shatter). Hatch glass is sometimes installed poorly, such that it touches the steel body. This point will rub and that will cause the tempering forces to concentrate there, eventually shattering the piece. This includes the little piece below the spoiler. There is usually -no way- to tell what broke the glass if it falls apart. If it shatters and stays together you -may- be able to tell where the failure started. A side window break such as that just posted is -usually- caused by an external force. Rock, BB, bullet, but usually a rock if on the highway. Most BB guns or pellet guns can't break auto glass unless at very close range. Even a 22 cal bullet has a hard time unless it hits almost perpendicular. Windshields are even stronger, as they are made of two sheets of tempered glass with a plastic sheet in between. The law requiring this was passed years ago after people were horrified by the blood and gore involved when humans try to fly through ordinary glass. It almost sounds funny, but I'm glad they didn't have colour film then.
| | #22 |
Friends: 0 | it most likely was an external force which caused the side window to shatter. but also its possible if the chassis flexed a tiny bit and bent the door frame. |
| | #23 |
| Junior Member Join Date: Jan 2009 Location: Los Angeles, CA
Friends: 0 | Thanks for the replies, Anyway, what ended up happening was I took it to the Toyota dealership and they were extremely cool enough to put it under my warranty. It didn't cost me a dime to repair my rear passenger window. It was even done within the next day! I cannot be more pleased with Toyota right now. Just wanted to follow up with info incase other people were wondering. |
| glass, rear, shattered |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-main-forum/56970-shattered-rear-glass.html | ||||
| 56970 Shattered Rear Glass Rapidshare Search Engine - Meta search engine - search DVD, MP3, ISO, music, video, games | This thread | Refback | 05-16-2009 11:56 AM | |
| Shattered fog lamp | catsbox | Gen II Prius Care, Maintenance and Troubleshooting | 13 | 04-04-2009 12:36 PM |
| Distorted Replacement Rear Window Glass | shimadog | Gen II Prius Care, Maintenance and Troubleshooting | 13 | 09-12-2008 10:32 PM |
| shattered window | davedog | Gen II Prius Main Forum | 2 | 12-05-2006 02:58 PM |
| Distortion in bottom of rear upper glass panel? | naterprius | Gen II Prius Care, Maintenance and Troubleshooting | 13 | 10-29-2004 10:32 AM |
| XM under glass? | naterprius | Gen II Prius Audio and Electronics | 4 | 10-04-2004 05:24 PM |
