| This is a discussion on '04 Prius dies suddenly and often within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; 2004 Prius with 35,000 miles dies suddenly and when I wait a while it starts up. And a few days ... |
| Junior Member Join Date: Jan 2009 Location: Spike
My Car: 2005 Prius Model: Package: N/A Thanks: 0
Friends: 0 | 2004 Prius with 35,000 miles dies suddenly and when I wait a while it starts up. And a few days later it dies again. Caution light says P lock not working. Park on flat surface. What does this all mean? |
My Car: 2004 Prius Model: Package: #9 Thanks: 92
Friends: 41 | It means you need to see your dealer....short version. When is it dying? While you're in motion going down the road or when stopped? How long is "a while" that you wait to restart? How often has it happened and what have you done to have it addressed? Do you get a CEL? Does it go away after a few restarts or does it stay on? Have you replaced the 12v battery yet (it's probably due if not). Any prior damage, repaires? Have you had all the SSCs performed and all routine maintenance? Any mods? Any other behavioral changes, mpg drop? What about the HV battery SOC indicator...is it's behavior normal? Has it done all this on a single tank of gas...could it be bad? Feed us!!
My Car: 2007 Prius Model: N/A Package: #4 Thanks: 50
Friends: 45 | Considering the low odometer reading, if you haven't replaced the original equipment 12V auxiliary battery yet, I would suggest doing that first. It is likely that the battery is weak due to lack of vehicle use and cold winter weather. A weak battery can cause weird electrical symptoms like the parking lock warning. |
| spike11 |
| 2006 Prius just dies | TomLink | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 01-24-2007 05:41 PM |
| Another Prius Dies on the Highway | ggood | Gen II Prius Main Forum | 40 | 11-07-2006 01:55 PM |
| 2005 Prius Suddenly Stops and Loses Power | joannej | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 09-19-2006 09:42 PM |
| '98 Prius traction battery dies Down Under | Jack 06 | Gen II Prius Main Forum | 6 | 10-31-2005 03:26 AM |
