This is a discussion on Looking for Driver's side window weatherstripping.. within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi, My weatherstripping is rotting (thanks to the AZ sun) on my driver's side window. It's the piece of rubber ...
Old 06-07-2009, 05:58 PM   #1
Sparky9292
Question Looking for Driver's side window weatherstripping..
Hi,
It's the piece of rubber that your elbow would rest on if you had the window down.
I can't find it on PC.com's site.
I'm also looking for a dash mat as well. If someone could give me a recommendation on where to buy these, I would appreciate it.
Thanks!
Sparky9292 is offline
Old 06-07-2009, 11:44 PM   #2
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Default Re: Looking for Driver's side window weatherstripping..
MSRP for the door weatherstrip is $25. Part number 68172-47030.
ToyoDIY.com
Patrick Wong is offline
Old 06-08-2009, 05:56 PM   #3
Sparky9292
Thumbs up Re: Looking for Driver's side window weatherstripping..
ToyoDIY.com
Awesome Patrick!
Really dumb question, there are two parts that point to the same item..
WEATHERSTRIP, FRONT DOOR GLASS, INNER RH (68171-47030)
WEATHERSTRIP, FRONT DOOR GLASS, INNER LH (This is the one you picked, part 68172-47030)
What does RH and LH mean?
The part that I want to replace is the rubber piece on the outside of the car, not inside.
Last edited by Sparky9292; 06-08-2009 at 06:07 PM. Reason: need to clarify RH and LH
Old 06-08-2009, 06:12 PM   #4
LRKingII
LRKingII's Avatar
Package: Navigation
Originally Posted by Sparky9292 View Post
Awesome Patrick!
Right Hand and Left Hand
LRKingII is offline
Old 06-10-2009, 10:07 AM   #5
Sparky9292
Question Re: Looking for Driver's side window weatherstripping..
Does that mean RH is the right side of the car and LH is the left side of the car?
Old 06-10-2009, 03:46 PM   #6
firepa63
Senior Citizen
Right hand is the passanger side and Left hand is the driver's side
firepa63 is offline
Old 10-28-2009, 02:32 AM   #7
yups
Hey Sparky,
Where did you end up finding the bolt weatherstripping? I'm in AZ too and mine dissolved in under 3 years. Toyota will meet me half way on price and install, but I'd like to see if there's an aftermarket part somewhere.
thx
yups is offline
Old 10-28-2009, 12:33 PM   #8
alanh
Note that the above part number is the inside strip. For the strip on the outside of the door, it's
MOULDING ASSY, FRONT DOOR BELT, RH 75710‑47010
MOULDING ASSY, FRONT DOOR BELT, LH 75720‑47010
alanh is offline
Old 10-31-2009, 04:17 PM   #9
alanh
I got mine from Toyota OEM Parts | Genuine Accessories & Toyota Original Factory Body Parts City Toyota -- for a body part like this, you aren't going to find an aftermarket replacement. Total price with shipping was about $50.
As it turns out, there's a way to replace it without removing the inner door panel. Toyota's service manual does it this way because that's the only way to remove it without damaging it. It's hooked over a lip in the sheet metal on the inner side, so you need to get a tool under that lip to unhook it.
However... it's already damaged, so who cares? It's just rubber, so starting at one end tear the outside part off. Once you do that, you can push down the inner part and get it over the hook. Be careful not to drop it inside the door.
You will still need to remove the mirror as it overlaps it. The inner cover (or speaker) just pops off. Remove the three nuts holding the mirror in place. If the metal clip from the inner panel comes off the inner panel, you can get it from the outside once the mirror is off. Likewise for the white push-in clip.
alanh is offline
driver, side, weatherstripping, window
Squeaky Driver's Side Window Tobalt Gen II Prius Care, Maintenance and Troubleshooting 0 10-29-2008 05:19 PM
Whining noise from driver's side ron69424 Gen II Prius Care, Maintenance and Troubleshooting 41 10-07-2008 11:17 PM
Disable Automatic Driver's-Side Window? reddave Gen II Prius Main Forum 15 06-17-2008 09:50 AM
FS: new driver's side oem wiper galaxee Private Sales 0 01-06-2008 06:08 PM
Schematic for the Driver's side Junction Box bobc Gen II Prius Audio and Electronics 7 05-10-2005 01:30 AM
