inverter pump failure - dodged the bullet
| Junior Member Join Date: Jul 2009 Location: Clinton, LA
My Car: 2004 Prius Model: N/A Package: #4 Thanks: 3
Friends: 0 | Greetings - This is a follow-up from my experience with an inverter pump failure last week. To recap, the inverter pump failed while I was driving under hot, mountainous conditions in the middle of nowhere. In continued to drive to Nashville [2 hours] but by the time I got to Rivergate Toyota, the car was practically non-functional. A diagnosis revealed the pump failure, it was replaced, checked out and I have now driven it ~ 1000 miles, most of it fast and under Southern Heat conditons. Car works fine...so far. BTW, Rivergate Toyota was an excellent place to do business...professional and very helpful. |
| shortbus driver Join Date: Mar 2004 Location: United States
My Car: 2004 Prius Model: N/A Package: #6 Thanks: 583
Friends: 0 | Woo-hoo! After such an episode it is sometimes also necessary to reflash the firmware of an engine computer. It may be that the dealer did that when replacing the pump, but don't be too upset if you get a warning light. And sometimes they don't get all the air out of the coolant loops, so note the levels on the various coolant tanks yourself and listen for unfamiliar burblings. But fixing those is much less trouble and expense than replacing the inverter, so count your blessings :_> Last edited by richard schumacher; 07-17-2009 at 07:49 PM. |
| Ancient sloth foot Join Date: Apr 2009 Location: Crestview/North Florida
My Car: 2012 Prius Model: Four Package: Solar Roof Thanks: 170
Friends: 59 | Quote:
| bullet, dodged, failure, inverter, pump |
| How to Replace the Inverter Coolant Pump | Patrick Wong | Gen II Prius Care, Maintenance and Troubleshooting | 104 | 05-05-2012 05:03 PM |
| Drives Perfectly but inverter failure? | Nick900 | Gen II Prius Care, Maintenance and Troubleshooting | 62 | 01-31-2010 06:34 PM |
| How critical is the inverter pump? | hobbit | Gen II Prius Technical Discussion | 18 | 07-22-2009 02:00 PM |
| Inverter Coolant Pump Leak | Adamf | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 05-15-2008 06:42 PM |
| Inverter coolant pump running | twdusa | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 12-31-2005 11:55 PM |
