| This is a discussion on 12 Volt Battery Issues within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi Everyone, We own a 04 prius that we purchased in early 07. In mid O7 we repalced the 12 ... |
| Junior Member Join Date: Jul 2009 Location: Phoenix
My Car: 2004 Prius Model: N/A Package: Navigation Thanks: 2
Friends: 0 | Hi Everyone, We own a 04 prius that we purchased in early 07. In mid O7 we repalced the 12 volt battery after an incident where the car just stopped in the middle of the road. According to the dealership, the computer system thought the car was out of gas(which it wasnt) and proceeded to discharge the battery. They fixed this. I cant actually remember why they had to replace the battery Anyway jumping ahead 2 years: I have had to jump start the car on twice over the past 2 weeks. After the 1st time we thought that it was an overhead light that may have been left on over night. The car ran just fine for the next weeks until last Saturday. We were on our way to Flagstaff for the weekend. The car started just fine. We drove about 10 miles and stopped for gas. The car would not start. When pressing the power button for a couple of seconds, some lights would come on for a second and then nothing. When pressing the button and depressing quickly, the other electronics in the car would work fine(Air, Radio). We have the jump leads in the car and were able to ask a friendly passer by to help us. I called the dealership(same one as 2 years ago) and they told me that its possible that its a bad battery. I explained that the battery was only 2 years old. He said that the AZ heat is very hard on battery life. Would a battery die after 2 years in Arizona? Before we left for the trip, I did have the car running idle with the air on high for 10 mins because we have a 1yr old. Would this affect the battery? This evening the car is starting fine. I want to do some tests to figure this out and so I would like some guidance. Am I able to verify for myself that this is a bad battery? It costs $275 including labor to replace the battery. For the battery alone its $165. Im going to call a different Toyota Dealership tomorrow morning to get a 2nd opiniin as well. Thanks for any suggestions, Dave |
My Car: 2004 Prius Model: Package: #9 Thanks: 102
Friends: 41 | 2 years is a bit premature for a battery to fail, but it wouldn't be unheard of. That said, it seems like something weird could be going on preventing the battery from charging properly (since it wouldn't start after the fill-up I wonder if it's a charging issue). Of course, once it's drained once or twice they're never quite the same and you may well be due for replacement. Don't pay anyone to put the battery in for you. It's very easy to do yourself. Yes, they are pricy, but at least pocket the $100 they wanna charge you for install. http://www.techno-fandom.org/~hobbit/cars/prius-12V/ Also, several people have been happy using the Optima battery as a more durable choice...also a DIY job. Optima Battery Installation
Friends: 0 | Thanks for the super quick response. We only have 50K miles on the car and this would be the 3rd 12V battery. I forgot to add that about 3 weeks ago we had to have the invertor replaced on the car. Would this cause a drain on the battery in any way? It may just be coincidence but we have not had any issues with the car for 2 years and suddenly the invertor and battery have to be replaced? |
Friends: 41 | Which inverter? It'll take someone with deeper tech knowledge than I have to answer the question of whether an inverter could lead to 12v issues...but my gut says "yes". |
Friends: 0 | |
Friends: 41 | |
Friends: 0 | afaik it was just the inverter. They told me that they were going to replace the old one with a newer model. I can tell you exactly how much it cost. $492 |
My Car: 2006 Prius Model: Package: #7 Thanks: 359
Friends: 14 | If it was the inverter that supplies 13.8V to the DC bus, that would explain the dead 12V battery. Tom |
Friends: 0 | So I just called Right Toyota and they told me that it was just the pump that was replaced and not the inverter. I went ahead and ordered one of those Ultima batteries so hopfully that will resolve the problem. |
| Resident Conservative Join Date: Mar 2009 Location: Austin, TX
My Car: 2009 Prius Model: Package: Base Thanks: 1
Friends: 3 | 2 years is short, but with an event like the interior light staying on that drained the battery down, it's life was probably reduced. Batteries don't like to be too deeply discharged. Sometimes getting to that state permanently alters it's ability to charge back up. Chemistries vary, though. |
| battery, issues, volt |
| battery jumpstart issues | 04priusJESSIE | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 01-11-2009 10:04 AM |
| dealer issues, hv battery problem | statultra | Gen II Prius Technical Discussion | 2 | 10-22-2007 02:05 PM |
| Prii Battery Discharge Issues | ecowood | Gen II Prius Main Forum | 6 | 06-27-2007 03:09 PM |
| Are there any issues with the battery? | yarzy | Gen II Prius Main Forum | 10 | 08-27-2006 09:32 PM |
| Battery issues | Raenstoirm | Gen II Prius Care, Maintenance and Troubleshooting | 25 | 11-12-2004 12:39 PM |
