| This is a discussion on Tire pressure sensor light now stays on with change to new tires: how do you reset this? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I presume you've checked your tire pressures and they are all OK? But even if they are out of whack, ... |
| | #11 |
| Member Join Date: Dec 2007 Location: Western New York
My Car: 2007 Prius Model: Package: Base Thanks: 0
Friends: 0 | I presume you've checked your tire pressures and they are all OK? But even if they are out of whack, wouldn't resetting the TPMS button make the light go out anyway? So, it does sound like a bad sensor someplace. Why it decided to show up after the dealer did work to your car is what I can't understand. |
| | #12 |
My Car: 2007 Prius Model: Package: #2 Thanks: 7
Friends: 3 | when you tried to reset the switch did you hold it for like 5 seconds until the light in the dash flashed. |
| | #13 | |
My Car: 2008 Prius Model: Package: T3 Thanks: 7
Check the pressures with a decent gauge - filling station air lines have notoriously inaccurate gauges - and if they're where you want them, press the reset button. | |
| | #14 |
| Senior Member Join Date: Jun 2006 Location: Boone, North Carolina
My Car: 2006 Prius Model: Package: #5 Thanks: 1
Friends: 25 | |
| | #15 | |
| Member Join Date: Jul 2009 Location: MD
My Car: 2008 Prius Model: N/A Package: #6 Thanks: 0
| | #16 | |
| Member Join Date: Feb 2007
So it was all because they were under-inflated? How long ago was this and is the light still off? On my last oil change I requested they put in 38 psi. When I checked later, all 4 tires were nearly the same except one was slightly under -- I filled it later, and the light still remains on. What's strange is that the sensor issue happened soon after this maintenance, which was over a month after my actual tires were replaced. But the dealer assured me the sensors can't get damaged with just oil change/tire rotation. | |
| | #17 |
Friends: 0 | |
| | #18 | |
I actually stopped going to the dealer for oil change and tire rotation with the purchase of 4 new Michelins. Up until last month, I went to a Toyota dealer every single time in order to keep up with the policy of my Extra Mile Tire Warranty (which turned out to be worthless by the way). | |
| | #19 |
Friends: 0 | The saga continues: Just got back from original tire replacement shop (well known chain) and they used an electronic tool to check each sensor. All 4 checked out as "active", which I take it means OK. I watched them perform the procedure. Toyota claims THEIR (more expensive) tool says that one is defective, and they want to charge over $200 to "fix" it. Tells me to ask how much tire shop will reimburse for damages. Tire shop management doesn't return message. No one mentions anything about re-programming internal computer............ What a pain in the *ss. I'm about to crack this case with a piece of black tape. Been driving for 20 years without these d*mn sensors. But then what happens when I go to sell/trade in? |
| change, light, pressure, reset, sensor, stays, tire, tires |
| Can't find tire pressure RESET switch | Randall Rash | Gen III 2010 Prius Care, Maintenance and Troubleshooting | 11 | 08-07-2009 11:55 PM |
| tire shop broke a TPMS tire pressure monitor sensor during tire change | theorist | Gen II Prius Care, Maintenance and Troubleshooting | 32 | 04-08-2009 11:57 PM |
| Tire pressure sensor | mssmith95 | Gen II Prius Main Forum | 2 | 06-04-2006 02:09 PM |
| Tire Pressure Monitor, where is the sensor? | DocVijay | Gen II Prius Main Forum | 28 | 12-19-2005 06:08 PM |
| Maintenance required light stays on after oil change. | newbie | Gen II Prius Main Forum | 4 | 10-27-2005 09:02 PM |
