| This is a discussion on Warning - Check tire pressure after service within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Tickwood , when they did the tire rotation, did they just do front to back and back to front? Or ... |
| | #11 |
| Senior Member Join Date: Jan 2009 Location: Boston, MA
My Car: 2009 Prius Model: Package: #2 Thanks: 22
Friends: 1 | Tickwood, when they did the tire rotation, did they just do front to back and back to front? Or did they do fronts to backs, backs crisscross to front? |
| | #12 |
| Junior Member Join Date: Sep 2009 Location: Raleigh,nc
My Car: 2010 Prius Model: III Package: Solar Roof Thanks: 0
Friends: 0 | [QUOTE=KK6PD;960291] Tire pressure 42/40, etc./QUOTE] I never expected Toyota service depts to observe my favored pressures, but I once assumed they'd follow manufacturer's proportionate differential between front and rear. After five years, and now on my second Prius, I've found the two major dealers in my NC area to be equally at fault in ignoring this -- rotate the tires and I end up with low pressure in front and high pressure in rear. So now I ALWAYS check pressures immediately after a service. |
| | #13 |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 229
Friends: 23 | Yup. I've had my tyres set at 30 all around because that's what the Corollas are set to |
| | #14 |
| Junior Member Join Date: Jun 2006
My Car: 2006 Prius Model: Package: #6 Thanks: 0
Friends: 0 | I've had the same experiences happen to me with techs pretending to be the air pressure police. I've also had bad experiences with techs losing my chrome tire valve covers or leaving them loose and having them fall off on the drive home. Now, whenever I've had the dealer perform my service, I usually tell them, AND MAKE SURE IT'S WRITTEN ON THE CONTRACT, not to mess with my tire pressures. They usually follow that directive. The last time I took the car in, they spilled some type of acidic solvent on my rear wheel covers when checking the brakes. Whatever it was, ruined the wheel covers. I immediately showed it to the service rep, who immediately replaced them with new ones. Just because you're taking your car to the dealer, doesn't mean that the service will be any better than your regular ole' shady auto repair joint! Check the car thoroughly - before you leave!
__________________ 06 Prius, package #6, magnetic gray, tinted windows, clear bra, mud guards, side mouldings, XM. |
| check, pressure, service, tire, warning |
| Receiver to check tire pressure via TPMS? | cpatch | Gen III 2010 Prius Care, Maintenance and Troubleshooting | 1 | 08-31-2009 06:56 PM |
| I tell you, check your tire pressure | siliconhybrid | Gen II Prius Fuel Economy | 22 | 06-23-2007 05:54 PM |
| Best way to check tire pressure? | Sho-Bud | Gen II Prius Main Forum | 20 | 08-07-2006 11:40 AM |
| Tire pressure warning? | geckoboi78 | Gen II Prius Care, Maintenance and Troubleshooting | 20 | 03-13-2005 10:13 PM |
| Tire Pressure Warning | glscheil1 | Gen II Prius Care, Maintenance and Troubleshooting | 3 | 01-21-2004 11:07 AM |
