| This is a discussion on Nav update & override on 2004 within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by mlibanio P.S. You can make a hybrid disc of 8.1 and 9.1 Just replace the Loading.KWI and ... |
| | #11 | |
| Junior Member Join Date: Jul 2009 Location: NC
My Car: 2004 Prius Model: N/A Package: #9 Thanks: 1
1- Get update, keep override, but have less accuracy 2- Get update, loose override, but better accuracy (maybe put a switch in the speed wire) 3- Get another Garmin and store it in the "secret" box for use when the Prius nav isn't sufficient I think I'd prefer the 2nd option but the 3rd option is probably the better one. | |
| | #12 |
Friends: 0 | I just went out to my Prius and finally looked at the detailed areas that it covers and it's pathetic! I never realized that it was soooooo bad because my local area is covered pretty decent but most of the country isn't covered in detail. I have version 4.2. Did the detailed areas increase dramatically since that version? |
| | #13 | |
| | #14 | |
On my 4.2 disk about the only area in the northern part of SC that shows detail is the greenville area, western NC is basically only the Charlotte area and GA isn't much more then the Atlanta area. When I look at the detail areas in the different regions they seem to only be around the the major metro areas. My system shows blue areas where the detail is when you pull-up each region. Basically every region excluding the northeast is quite sparse. So my question was, has this improved dramatically or is it still basically the same? My wife and I prefer the nav system in the prius but if Toyota's coverage hasn't improved substantially since 4.2 then my money would be better spent buying a Garmin and stashing it in the "secret" drawer for when the Prius' nav system comes up short. I've thought about maybe taking a ride over to the Toyota dealership to take a look at the latest nav system regional detail.
__________________ No liberal tree hugger here. Stop supporting terrorists, drill here drill now. High mileage cars aren't the answer although they help. Bought my Prius to save on fuel and because it's a cool gadget car, lots of fun to drive! | |
| | #15 |
| High Fiber Member Join Date: Jun 2005 Location: South OC So Cal & the Flathead Valley MT
My Car: 2004 Prius Model: Package: #9 Thanks: 15
Friends: 12 | You also have to be zoomed into the 700 foot scale or closer before small roads & dirt trails show up. . |
| | #16 |
Friends: 0 | Hill, I don't know if you are responding to me. In case you are, my 4.1 maps will show me where in each region there is detailed information available to give me turn by turn directions to an inputted address. It isn't very much of the US. I have the original disk that came with my Prius when it was new. My 2004 Prius was manufactured in Oct 2003. So it doesn't matter how much I zoom in if the information for turn by turn directions to an entered address isn't there then the system can't help me. I don't use the zoom. I let the software control the zooming. I want to find out how much better the mapping info is now. I have a Garmin with 2009 maps on it that only has half my street on it. I recently bought a new Garmin with 2010 maps on it and it now shows my street correctly. My street has been here since 1998. I would think that since Toyota and Garmin get their map info from the same company that it should be the same but from what I've read it isn't. |
| 2004, nav, override, update |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-main-forum/69256-nav-update-override-2004-a.html | ||||
| denso nav - Page 2 | BoardReader | This thread | Refback | 10-11-2009 12:53 PM | |
| Nav override for 2004 Prius?? | edward15 | Gen II Prius Technical Discussion | 2 | 07-01-2008 08:17 AM |
| Nav Override | mktbob55 | Gen II Prius Main Forum | 2 | 06-09-2007 09:01 PM |
| Has anyone tried this override for Nav on 2006? | yarzy | Gen II Prius Main Forum | 3 | 09-14-2006 08:04 AM |
| Navigation Override | JeffSchlichter | Gen II Prius Main Forum | 1 | 12-05-2005 12:39 AM |
| Motor Trend One-Year Test Update 2004 Prius | jkash | Prius and Hybrid News | 15 | 07-28-2004 02:18 PM |
