| This is a discussion on Lost 5 mpg when replacing Integrity tires with Hydroedge within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; The Hydro Edge are not an option for me as they are not V rated and no one will install ... |
| | #21 |
| Junior Member Join Date: Oct 2009 Location: Monterey
My Car: 2007 Prius Model: N/A Package: S Touring Thanks: 0
Friends: 0 | The Hydro Edge are not an option for me as they are not V rated and no one will install anything less than H rated on my 16 inch wheels for my 2007 touring version. But in looking at what was available in a 16 inch diameter and H rated the choices came down to the Goodyear Assurance ComforTred, Fuel Mark, or the Triple Tread. With the Fuel Mark I would expect to be buying at least one extra set of tires as compared to the other two models so it makes little sense to get an extra 2-3 MPG and spend the money on the additional set of tires. The tires will cost appreciably more than the additional gasoline, and I would be contributing additional tires to the local landfill as well. Having tires that last for only 30K miles is one decidedly ungreen aspect of the Prius. |
| | #22 | |
| I study nuclear science... Join Date: Apr 2008 Location: San Diego
My Car: 2006 Prius Model: N/A Package: #3 Thanks: 1
You CAN get the Hydroedge for the Touring model. Find another dealer who will sell them. You'll just need to get the right spec tire to make the overall diameter roughly the same as the original, which is P195/55R16 I think. But the Hydroedge isn't made in that size. Try P205/55R16, which will probably be about 1.5% different in circumference. You'll be happy with the Hydroedge. Incredibly good wear specs and warranty. Excellent handling, especially on wet roads, and a quieter tire. You'll lose a couple MPG, though, as they are not LRR.
__________________ Mods: Two scangauges, body side moldings, mudguards, rear bumper protector, grill blocking. Coming soon: EV button, engine block heater | |
| | #23 |
Friends: 0 | I am in California, and neither Costco or Sears nor two local independent car dealers will install a tire that is more than one "speed rating" lower than the stock OEM tires. The Bridgestone stock 195/55R16 tires are V rated so that means buying V or H rated tires and paying about 30% more. With my trucks I have had a similar deal with B/C/D load rated tires, but the odd thing is that the higher speed rated car tires actually have a 10% lower load rating on average. People with 15" wheels are not going to run into this problem, nor would anyone running stock "H" or "T" rated tires as they can put on V, H, or T tires and no one would say a word and they would be, like you, ignorant of the policy. I ran into the V or H rated tires with my Mercedes coupe but did not expect to run into it with the Prius. What strikes me as odd is not the policy of the tire dealers, but that Toyota would put V rated tires on a Prius in the USA. In Europe and especially in Germany, I can understand putting 130mph tires on a car. It makes little sense in the USA where people drive a lot slower (as well as a lot less sanely). In addition to paying 30% more for tires one has to deal with the very limited selection of H rated tires available in a 195/55R16 size, or go to a larger diameter 205/55R16 which is what I will be doing. But the fault is not with the tire dealers but with the idiot at Toyota who specified a V rated tire on the Prius for the USA market. Had Toyota used a 130mph H rated tire on the Prius people would be able to choose another H rated tire or a "T" tire and be limited to 118mph (and the rating applies to sustained speed not top speed). Toyota is not trying to produce a green car so whether a car requires 4 sets of tires or 12 sets and puts 32 more tire carcasses into the landfills is clearly not their concern anymore than it is for USA car makers. |
| | #24 | |
My Car: 2007 Prius Model: Package: #2 Thanks: 167
Friends: 22 | Quote:
TireRack tested the new HydroEdge with Green X which features a low-rolling resistance silica-based tread compound that is presumably lower than the original HydroEdge. I believe that all or almost all of the posters saying that they've lost a lot of gas mileage with HydroEdges are using the original higher rolling resistance HydroEdge. | |
| | #25 | |
| Senior Member Join Date: Sep 2006 Location: NorCal
My Car: 2006 Prius Model: N/A Package: #6 Thanks: 0
| | #26 |
| Member Join Date: Jan 2008 Location: San Diego
My Car: 2008 Prius Model: Package: #2 Thanks: 2
Friends: 0 | UPDATE: After 3000 miles, my gas mileage has improved to an average of 53 MPG compared to 50 MPG when the tires were new. Maybe the tires broke in and I also increased the pressure in the tires from 36 to 40 psi. |
| hydroedge, integrity, lost, mpg, replacing, tires |
| (4) Michelin Hydroedge tires for Prius: $288 shipped after $40 rebate | usbseawolf2000 | Gen II Prius Main Forum | 11 | 10-19-2007 06:25 PM |
| Michelin Hydroedge tires | tmorrowus | Gen II Prius Technical Discussion | 12 | 07-28-2006 06:29 AM |
| Tire Pressure in your Hydroedge Tires? | Bill Compton | Gen II Prius Main Forum | 5 | 10-14-2005 08:27 AM |
| 4 Michelin Hydroedge tires | FredWB | Private Sales | 0 | 10-09-2005 01:55 AM |
| Michelin HydroEdge tires on snow | john1701a | Gen II Prius Modifications | 13 | 12-07-2004 07:24 AM |
