| This is a discussion on 2008 prius: How long do the front struts last on the prius? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by 2009Prius Gee this makes me wonder if I should buy the extended warranty if the struts tend ... |
| | #11 | |
| Junior Member Join Date: Aug 2009 Location: NY
My Car: 2003 Prius Model: N/A Package: N/A Thanks: 1
I can go get a couple front struts for $58 each, and it's not real complicated to replace... Involves about 6 bolts... Then an alignment when done... So it should cost under $200 and maybe a few hours(I tend to go slow) of my time... Then again I've had places tell me $600 for brakes when I fixed it with a $20 set of pads... Levi | |
| | #12 |
Friends: 44 | Pls show me where you can buy Prius front struts for $58 each. Also, the removal requires much more than six bolts since you have to remove the cowl that runs across the rear of the engine compartment... |
| | #13 |
My Car: 2004 Prius Model: Package: #9 Thanks: 1
Friends: 0 | Well, all this talk has me worried about every bump I'll hit from now on. Never replaced struts on ANY of my cars. Didn't think I'd start now... |
| | #14 | |
KYB GR2's. I've used them several times before on various cars and have been quite happy with them. Ohh, hadn't actually looked to replace them yet. That would potentially add a good bit of complexity if the top strut mounts aren't out in the open... I'm going to have to investigate further... Still... I'd like to think it's not THAT bad of a job... Levi | |
| | #15 |
Friends: 0 | |
| | #16 |
| Member Join Date: Apr 2005 Location: Columbus, OH
My Car: 2005 Prius Model: N/A Package: #4 Thanks: 3
Friends: 0 | My 2005 has just under 142k and the front struts are starting to groan when I go over bumps - not to the point that I am going to replace them yet, just to the point that I am researching cost options. |
| | #17 | |
Friends: 44 | Quote: However, note that you'll probably have to replace the rubber insulators located above and below the spring and should also consider replacing the top strut mount located above the spring if your car has 100K miles or more. That will add more cost. See my post here for Toyota part numbers and prices. Hints Regarding Replacement of 2G Front Struts I don't doubt that your struts (and rear shocks for that matter) need to be replaced at that odometer reading. However note that the groaning noise you hear may be caused by worn front stabilizer bar rubber bushings. Last edited by Patrick Wong; 10-29-2009 at 02:27 PM. | |
| | #18 |
Friends: 59 | Remember 04 and 05 front struts are not compatible with 06 and up. |
| | #19 | |
ToyoDIY.com Here's the parts catalog for 2008, note that the part numbers are the same: ToyoDIY.com However see the Champion Toyota website which does differentiate between older and newer 2G regarding front struts: Champion ToyotaWorld Champion ToyotaWorld | |
| The Following User Says Thank You to Patrick Wong For This Useful Post: | usbseawolf2000 (10-29-2009) |
| | #20 |
Friends: 59 | ToyoDIY.com lists two numbers though. For right, part number 48510-47041 is probably for the 04 and 05. One ends with 48510-47050 is for 06 and higher. For left, part number 48520-47041 is probably for the 04 and 05. One ends with 48520-47050 is for 06 and higher. I guess parts are inter-changeable? |
| 2008, front, long, prius, struts |
| Hints Regarding Replacement of 2G Front Struts | Patrick Wong | Gen II Prius Care, Maintenance and Troubleshooting | 15 | 10-19-2009 08:08 AM |
| Why did Toyota change the front struts in 2005? | sdcruiser | Gen II Prius Modifications | 9 | 10-05-2009 01:20 AM |
| 2005 front bra cover on 2008 Prius? | rpiereck | Gen II Prius Main Forum | 6 | 04-25-2008 11:27 AM |
| FS: 2006 springs, rear shocks, front struts | sc_trojan | Private Sales | 1 | 02-22-2008 07:35 PM |
| 15" wheels+sensors+tires - trim rings - struts - shocks - struts | Pinto Girl | Private Sales | 5 | 12-19-2007 05:13 PM |
