| This is a discussion on 2006 Being Prius towed as a TOAD ?? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi All We are looking at buying a Class A RV & wonder if our 2006 Prius can be towed ... |
| Junior Member Join Date: Feb 2008 Location: Ormond By The Sea FL
My Car: 2006 Prius Model: Package: #2 Thanks: 0
Friends: 1 | Hi All We are looking at buying a Class A RV & wonder if our 2006 Prius can be towed behind the RV on a car dolly, with both front wheels up off of the ground ? Any info & first hand experiences being shared would be greatly appreciated. And, yes we have reviewed our owners manual. Thanks !! Bill in FL |
| Senior Member Join Date: Sep 2009 Location: N/A
My Car: 2009 Prius Model: N/A Package: N/A Thanks: 0
Friends: 0 | Interesting...so you use an RV that gets 10 mpg, then make up for it by using your Prius which gets 50 mpg. Isn't that called a paradox? Haha, sorry. I can't answer your question. I have no experience, but it's an interesting idea. |
| Senior Member Join Date: Dec 2006 Location: Columbia, SC
My Car: 2007 Prius Model: Package: #2 Thanks: 10
Friends: 0 | Front wheels up on a dolly should be fine. You just can't tow it all wheels down. |
Friends: 1 | The money we save on gas goes toward a night at the Hilton instead of a Days Inn LOL |
Friends: 0 | |
My Car: 2007 Prius Model: Package: B Thanks: 3
Friends: 0 | Yes, you can tow with the front wheels on a dolly. DO be careful that there is still sufficient ground clearance in the rear as the Prius doesn't have much to begin with. Also note that the front wheels will be higher than the rears, so the rear alignment will be off (both camber and toe-in) so watch for tire wear. If you don't notice much then it's probably ok. Note that it's difficult to leave the Prius in "N" so if the dolly manufacturer wants that, you'll have to work to get it. There is a fuse that can be pulled that prevents the car from engaging "P" when you power off. I don't remember which one. Your dealer may be able to tell you.
Friends: 33 | Good point David, you need to have the trans in neutral to prevent park pawl damage. Other than that, as above and then there is how to get the lights working down the back? Or do you use a light board? If there is a fuse you can pull to stop the trans engaging park then it might be worth adding a switch to that circuit rather than pull a fuse each time. |
Friends: 1 | Please keep the great info coming & thanks !! If the car is in N when I shut it off, how can it switch into any other gear with power off ? For lights I figure to put the parking lights on when towing as the RV's rear lights shine above the Prius - I think. And, we also have a 2 WD Highlander Hybrid & wonder if we can tow this the same way - front wheels up ? Any thoughts here ?? Thanks !! Bill in FL Last edited by wtfjr36; 10-31-2009 at 05:04 PM. |
| Senior Member Join Date: Dec 2008 Location: Kingston Ontario
My Car: 2009 Prius Model: N/A Package: C Thanks: 10
Friends: 0 | When you hit the power button when in anything but park, it puts it in park before powering down... unless you can find a way around this. |
| | #10 | ||
Friends: 44 | Quote:
I've noticed many RVers towing Saturn vehicles with all wheels on the ground. Looks like this is one feature that differentiates Saturns from most automatic transmission vehicles.
__________________ 2006 Highlander Hybrid 4WD-i 2004 Prius 2001 Prius (sold Feb. 2008, 75K miles) 2000 Ford Mustang GT conv. | ||
| 2006, prius, toad, towed |
| Using Prius tail lights when being towed by RV | Gamble | Knowledge Base Articles Discussion | 0 | 05-17-2009 08:36 PM |
| 2007 had to be towed | torresr001 | Gen II Prius Care, Maintenance and Troubleshooting | 10 | 07-02-2008 01:23 AM |
| 2005 Prius died while driving and was towed | PoutyPrius | Gen II Prius Care, Maintenance and Troubleshooting | 16 | 02-29-2008 02:30 AM |
| 6 weeks old and already towed | cecilkitten | Gen II Prius Care, Maintenance and Troubleshooting | 38 | 01-17-2008 01:58 PM |
| I Got Towed! | PatapscoPete | Gen II Prius Modifications | 8 | 10-12-2006 08:43 PM |
