This is a discussion on Two rear facing car seats in Prius (twins) within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi all, I just got a 2005 Prius so I'm new around here. We have twin infants and I'm wondering ...
Old 11-05-2009, 11:45 AM   #1
sdc177
Package: Navigation
Default Two rear facing car seats in Prius (twins)
Hi all, I just got a 2005 Prius so I'm new around here. We have twin infants and I'm wondering how much room the driver and passenger will have with rear facing Graco Snugrides installed behind each seat. I'm 6'3" 285 lbs so I prefer my seat back all the way...anyone with experience here?
sdc177 is offline
Old 11-05-2009, 02:09 PM   #2
jengel
Default Re: Two rear facing car seats in Prius (twins)
We have a Graco SafeSeat which we put in the center since it interfered with seat back recline on either side. My wife and I keep both front seats as far back as possible for legroom. The SafeSeat is a little bigger and bulkier than the SnugRide if I recall correctly so you may be OK, but my guess is that you will have to have the front seats less reclined than you are used to. The only way to be sure is to install the seat and give it a try. Most stores will humor you with the floor model if you ask to try and test fit. Good luck.
-Jon
jengel is offline
Old 11-05-2009, 02:15 PM   #3
kabin
kabin's Avatar
We almost purchased a reverse seat but decided against them for numerous reasons. Not nearly enough room in the prius. Plus it blocked driver peripheral vision. The strangest thing is the child's legs having to be pulled back into their laps because the child seat butts into the car's second row back seat making no place for the child's legs to reside. Lastly it wasn't very sociable for the child/parent.
kabin is offline
Old 11-05-2009, 02:34 PM   #4
drees
It's going to be tight. Anything short of a full-size car will be snug with rear-facing seats.
Any decent store will let you test the seat fitment out before you buy it - highly recommended.
drees is offline
Old 11-05-2009, 02:58 PM   #5
sdc177
Package: Navigation
I would hope your child was 20+ lbs when this decision was made...
sdc177 is offline
Old 11-05-2009, 03:53 PM   #6
cmar
hopefully someone that has actually tried it will chime in, but...
I had no problem with my britax and grace either direction in both a dodge neon and s-10 blazer, both of which had less room between the f and r seats. i i currently use the graco in my prius foward with no problem with the seat all the way back.
cmar is offline
Old 11-05-2009, 04:10 PM   #7
chinna
I use a graco rear facing seat in my prius and it is behind driver seat(so that I can drop off the older from passenger side at school).
I would say it would be pretty tight, may be almost unusable for your height. I am not tall, and room is not enough for me, it is a compromise for me. But again I think it is the case with any mid size car. If it is single rear facing, then middle of rear seat is the best bet.
chinna is offline
Old 11-05-2009, 04:14 PM   #8
drees
I'm 6' and have used both a Britax Boulevard and a Graco - both rear-facing in 3 different cars of similar size: '95 Civic, '03 Impreza WRX, '08 Prius. Prius has the most room, but rear-facing required us to move the front seats up from where we normally put them with both child seats. My wife was OK with it, though, but she's a lot shorter. With the Boulevard rear facing on the passenger side and the seat as far back as it goes, my knees almost touch the glovebox. Cramped, but livable for the year my kids were facing backwards.
drees is offline
Old 11-05-2009, 07:05 PM   #9
sdc177
Package: Navigation
Wow, hopefully we won't have to use the Prius much for the kids! It will be secondary to our Flex anyway for family travel.
sdc177 is offline
Old 11-06-2009, 09:25 AM   #10
Ophbalance
Hah, a topic I can answer. We have twin 7 month olds that we took when we test drove our '05. The only thing is, I'm only 5'8". There's enough room between the back seat and the rear facing carry along that they never touch... but then, I'm only 5'8" . If you put the seat all the way back, it's not going to work out. We have the typical graco seats with the click in base, but for test drive we just used the car seat without the base.
Ophbalance is online now
car, facing, prius, rear, seats, twins
How does one remove classsic prius rear seats? orange4boy Generation 1 Prius Discussion 4 10-30-2009 06:53 PM
2010 vs. rear facing infant car seat. nineinchnail1024 Gen III 2010 Prius Main Forum 14 08-30-2009 09:22 PM
Which years don't have fold down rear seats? Optimus Gen II Prius Main Forum 11 04-01-2008 09:19 AM
Toyota facing the scale down of 06 Prius Three60guy Gen II Prius Main Forum 84 01-29-2006 09:53 PM
what have you done with rear-infant seats? rwithop Gen II Prius Main Forum 5 11-14-2004 07:49 PM
