| This is a discussion on Cabin Air Filter within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Google found http://www.drivewire.com/toyotaparts/catal...nairfilter.html which includes: Fits: 08/2003 - 12/2005 Toyota Prius Important Fit Details: Vehicles made from 08/2003 on. ... |
Cabin Air Filter
| | #1 | |
My Car: 2004 Prius Model: Package: #9 Thanks: 1
Friends: 0 | Google found http://www.drivewire.com/toyotaparts/catal...nairfilter.html which includes: Quote:
Friends: 0 | Electrostatic might work better and is probably washable--cheaper in the long run, and you're more likely to keep it clean that the paper filter. |
Friends: 0 | Thanks for the link to the site. No non dealer parts shops here have the cabin air filter in stock, however they all say they can order them. Anyway, I noticed that the pollen type is by Bosch, which is a good manufacturer, however the electrostatic type is by Dens, which is a subsidiary of Toyota, so that would basically be a Toyota replacement part, but possibly better than the original. I also show the actual price through your link above $26.81. That isn't too bad for a filter that will last about 12,000 miles. It doesn't say if it is washable. |
| Senior Member Join Date: Mar 2004 Location: Texas Hill Country
Friends: 0 | If your new filter has greater flow restriction than the original it will cause performance problems. At some point the added restriction can cause the coil to freeze up causing excessive head pressure and premature compressor failure. This is the case with residential compressed refrigerant cooling systems. If automotive systems are markedly different, feel free to correct me. |
My Car: 2004 Prius Model: Package: B Thanks: 32
Friends: 12 | Ray: You mean like those 3M "Filtrete Ultra Allergen" filters marketed in popular HVAC sizes? I believe they work as advertised, but I would *never* use a filter like that unless it was put in the same cabinet as an industrial HVAC with a DP monitoring system. Once the DP exceeds the preset limit, you get an alarm to replace the filter. I like electronic air cleaners for residential HVAC use, with a HEPA bypass filter if you're sensitive to pollen or fine dust. The EAC cells really don't cause airflow problems, and they are easy to clean too. For automotive applications with a replaceable filter, inspect frequently and replace when dirty. Jay |
| Senior Member Join Date: Feb 2005 Location: Circleville, Ohio
Friends: 1 | Jay, I use the 3M filters in my house and set the thermostat to show "filter" every 30 days so I can keep an eye on how dirty it gets. Having 3 dogs/7 cats you wouldn't want it to get plugged up, As for the Prius cabin filter, I have seen some really plugged up ones especially if trees are around. One was so plugged it restricted the air flow! It is so easy to check,maybe Toyota should put a light on the dash to let you know to check it like the "maintenance" light? The saying " Out of sight,out of mind" works here
__________________ Rick Angles Toyota Master Diagnostic Technician Toyota Hybrid Technician Germain Toyota Columbus, Ohio |
Friends: 12 | Rick: That's what I like about the Bryant Evolution home control at my hobby farm. I can program when I get reminders about the filters and cleaning the EAC cells. I suppose you have a Petting Zoo with all those critters. Don't be surprised if the return air trunk is full of animal fur, and make sure to check the A/C evaporator too. I really like Electronic Air Cleaners. The stainless steel mesh prefilter is very easy to clean, and on most EAC's once the cells get too loaded up the indicator light goes out and you know it's time to soak them in dishwasher detergent. Jay |
Friends: 0 | I Googled for the 88880-41010 part number and ordered one for around $32 shipped. This is the trial of the Premium filter, and then next time I'll try another style, maybe Bosch. Anyone know if these 'electrostatic' filters are what came with the car? I have nearly 23,000 miles on the car in 15 months and I'm making the first change, so unless this one fills up and I get no heat or air, I'll probably be changing at the same rate from now on... |
Friends: 14 | I suggest all Prius drivers consider the following: At your favorite hardware store, buy a washable electrostatic filter sold for residential HVAC. Tpically you will see a 20 X 25 inch for $20. Cut the element into 8 3/8 inch or 21 cm squares. Keep a couple for yourself and the rest for Prius party favors, etc. Remove, wash and reuse. To the Toyota employees who contribute so much here, I hope that not everybody takes my advice, and that your company can maintain a profitable service/maintenence operation. But frankly the Toyota part is not cost effective in this application.
| Silver Business Sponsor Join Date: Oct 2004 Location: Tyngsboro, MA
Friends: 0 | My local Toyota dealership told me that the cabin air filter that comes w/ my '05 Prius is already the HEPA / Electrostatic type. There is this new Photocatalytic air filter that we plan to import from Japan. They make one model for the Prius. It doesn't just trap. It supposedly breaks down the trapped allergens/pathogens as well with the use of an UV lamp or natural sunlight. So I assume it's reusable after washing & exposing under the sun? A lil' preview: ![]() |
| Cabin Filter | rmblaster | Gen II Prius Care, Maintenance and Troubleshooting | 0 | 08-09-2007 06:57 PM |
| cabin air filter | sheila'sprius | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 09-20-2006 10:10 PM |
| cabin air filter | dg92104 | Gen II Prius Care, Maintenance and Troubleshooting | 13 | 07-19-2006 04:58 PM |
| Cabin air / AC / filter question | dancekat59 | Gen II Prius Technical Discussion | 8 | 06-25-2006 08:05 PM |
| Cabin air filter | gregm13 | Gen II Prius Care, Maintenance and Troubleshooting | 9 | 03-14-2006 03:12 PM |
