Replacement of 12 volt auxiliary battery
Old 01-13-2010, 07:23 PM   #71
shortbus driver
richard schumacher's Avatar
Default Re: Replacement of 12 volt auxiliary battery
Originally Posted by suk View Post
Come on! Don't stir with the gas emitted! The gas is only hydrogen and oxygen. While hydrogen is not poisonous and is not absorbed, oxygen is just what you are breathing for. And realize how leaky your car is when following a smoke belcher and how little gas the battery emits: the maintenance-free battery never need a sip of water for a 5-year life? Although I won't suggest that you ducktape the bat vent tube to your nostrils ...
If there is no problem, then there will be no problem; but if there is a problem, then there will be a problem: acid will be spewed inside the car, or an explosive gas mixture will be released inside the car. Defeat the vent tube at your peril.
richard schumacher is offline
Old 01-22-2010, 01:54 PM   #72
My wife's 2004 Prius was completely dead two weeks ago (no lights, doors wouldn't unlock) and had to be jumped, then yesterday didn't start after a 15 minute drive (though the electronics were all active) and had to be jumped. The good news for those in Silicon Valley, Yarnell's in Mountain View put in a new OEM unit for $138 plus tax (apparently they only charged for the battery, not labor).
Question:
- Is there a way for me to check the voltage level via the nav screen? Or can I use my $20 multimeter? If so, am I just checking voltage across the terminals with the car off, and can I do this from the jump location in the hood (between positive terminal and the body)? What should the voltage be?
Thanks!
Bill
2004 Driftwood Pearl Prius
Package BC
cyclone is offline
Old 01-22-2010, 02:06 PM   #73
My other car is a boat
Friends: 19
Originally Posted by cyclone View Post
<snip>
Question:
Thanks!
Bill
Checking 12v Battery Health - Hybrid Car Forums
qbee42 is online now
Old 01-22-2010, 05:54 PM   #74
Package: #8
Originally Posted by dzitlow View Post
Where can one obtain a replacement for the 12 volt auxiliary battery in the Prius? What are the specifications (e.g., product name, capacities, etc) and prices of the replacement 12 volt auxiliary battery?
I have one that is out of a 2005 prius that I replaced with optima yellow top simply because I needed more battery as I installed an electric lift for a wheel chair/ I would like to have $35.00 for it . The negative cable is with it. It holds over 12.33 volts while out of the car for days.It looks like new I believe it was replaced in the car before I bought it. Never had problem with it . Just needed more battery
donalmilligan089 is offline
Old 04-18-2010, 11:10 AM   #75
Just replaced my 04 accessory battery at 55,000 miles (6 years old). It was discharging after sitting for a few days and the car wouldn't start. It did this three times in two weeks so I wised up and bought an Optima D-51 deep cycle battery locally. I used a bench grinder to alter standard battery cable ends to fit the old cables. Also, I used the grinder to lessen the diameter of the stock battery vent connector to fit in the smaller hole of the optima. I used gasket sealer to plug the vent hole on the other side of the optima. Works like a charm all for $144 from Advanced Auto parts. Bought online for a 15% discount on the battery (or any parts) and picked it up at the store.
Ordered a #9 Salsa Red 4/27/04
Delivered: June 3, 2004
Modifications: Factory EV Switch
Johno is offline
Thanked by:
tlessard (09-13-2011)
Old 04-18-2010, 02:42 PM   #76
shortbus driver
Yes
Partly; also do it in ACC
Yes
12.4 to 12.8V with the car OFF, not much less than 12.0V in ACC. Less than that -> dying battery. More than that -> car is ON or in IG-ON, or there is a serious charging system fault.
Leave the car OFF for a few hours before measurement so that any misleading "surface charge" in the battery will have dissipated.
Old 04-19-2010, 02:33 PM   #77
My Car: 2001 Prius
Does anyone know how long the warranty on these 12 volt auxiliary batteries is? Mine was replaced two years ago and now they are telling me it is bad again.
I have a Prius Classic
smaneck is offline
Old 06-19-2010, 11:20 AM   #78
< Never-mind! Found answer.. It is Not..>
Greetings!
Perhaps this is the dumb question of the day, but does anyone know, for sure, if the 12V OEM battery is covered by the extended warranty (the one referred through PriusChat) ??
TIA!
Last edited by PeeDeePrius; 06-19-2010 at 12:38 PM. Reason: 1)Clarify WHICH battery-- 12V 2) Found answer-no
PeeDeePrius is offline
Old 06-20-2010, 11:47 PM   #79
Napa has a $20 mail in rebate on the optima batteries.
brownsnoutuk is offline
Old 10-28-2010, 10:55 PM   #80
KD6HDX's Avatar
My Gen II 2005 Prius has a new Optima 12 volt aux battery from eLearnAid. The battery was easy to replace with the included instructions. I will admit that I changed out the 12 volt battery way ahead of time because I just did not want to take chances provoking a well known Achilles heel in the Prius. I still have the original 12 volt battery that is in use as a starter battery for my Honda Eu3000i generator. Each time I have changed out the battery, I have kept them and use them for amateur radio disaster readiness. The last California earthquake shakeout drill was on 10/21. The little batteries were in use in the generator and in my ham radio station on the air with battery power. I keep the batteries instead of exchanging them for the small core fee. Hopefully I will get 5 years of use out of the new Optima D51. It will be in use in the car since I just added a ham radio to the rear of the car. So far so good. A small jump battery was in use during the exchange to preserve the radio settings. I do believe I may actually be getting slightly better mileage with the bigger 12 volt battery. Maybe its the increased tire pressures of 40psi and 0-20w Mobil 1 oil in use that keeps me in the average range of 48-50 mpg, both city and highway averaged together. Not a scientific calculation by any means, but just a good average on average.
166,000 miles and still running strong. Optima D51-12V aux blue top battery. Mobil One synthetic motor oil. Trans drain and fill three times in total mileage. Average 48 MPG, 500 miles a week.......
KD6HDX is offline
auxiliary, battery, replacement, volt
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-main-forum/9271-replacement-12-volt-auxiliary-battery.html
Checking 12v Battery Health - Page 3 - Hybrid Car Forums This thread Refback 03-06-2012 04:36 PM
Comunitatea Toyota (Prius) - Page 5 - Forum Club Toyota Romania This thread Refback 01-28-2012 03:02 PM
Comunitatea Toyota (Prius) - Page 5 - Forum Club Toyota Romania This thread Refback 10-02-2011 04:52 PM
Checking 12v Battery Health - Page 2 - Hybrid Car Forums This thread Refback 05-23-2011 04:18 PM
Checking 12v Battery Health - Hybrid Car Forums This thread Refback 05-20-2011 11:25 AM
Checking 12v Battery Health - Hybrid Car Forums This thread Refback 03-01-2011 02:00 PM
Prius battery? - Automotive Forums .com Car Chat This thread Refback 01-30-2011 10:11 PM
s46b24r pdf kr This thread Refback 01-04-2011 07:18 PM
Vacation vs auxiliary battery gring40 Gen II Prius Technical Discussion 11 12-26-2011 11:09 PM
Auxiliary Battery Replacement mecram1 Gen II Prius Technical Discussion 18 09-20-2011 04:03 PM
Replacement Auxiliary Battery Bigdog148 Gen II Prius Main Forum 11 09-08-2008 11:11 PM
Errr... Auxiliary battery???? babsrocks Gen II Prius Care, Maintenance and Troubleshooting 9 02-28-2007 02:18 PM
auxiliary 12 volt battery tomdeimos Gen II Prius Modifications 12 01-18-2005 06:44 PM
