| This is a discussion on The Windshield Sprayers are AIMABLE!! within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; 8-) Originally, I meant to type that they are amiable. Once I realized my typo I figured that I'd might ... |
| | #11 |
My Car: 2004 Prius Model: Package: #9 Thanks: 58
Friends: 27 | 8-) Originally, I meant to type that they are amiable. Once I realized my typo I figured that I'd might as well create a post to go along with it. |
| | #12 |
| Guest
Posts: n/a
My Car: Model: Package: | I must say that I was rather surprised when I tried the front washer for the first time yesterday. Maybe it's just having a new car in general, but the feeling was not unlike replacing my old shower head with a new supersoaker massaging unit. |
| | #13 | |
| Member Join Date: Apr 2006
tks much and sorry to ask just a basic question. | |
| | #14 |
My Car: 2004 Prius Model: N/A Package: Base Thanks: 206
Friends: 36 | If you use 2 pins you can rotate the nozzle but the 2 streams from each ball nozzle will still be the same distance apart. So by turning them a little you could make one squirt higher than the other. You might play with one of each nozzles streams on the top of the screen and the other just above the wiper. |
| | #15 |
| Junior Member Join Date: Jan 2009 Location: Stockholm, Sweden
My Car: 2006 Prius Model: Package: N/A Thanks: 0
Friends: 0 | I have been using pins for aiming washers for years as well. Works on most cars. A safety pin gives a good grip, but could be a bit thick. Ordinary pins does the job. Just grab one from the next shirt you buy. In my experience pins is the best method. I tried using pliers once. That felt quite crude and more likely to break someting compared to the pin method. |
| | #16 |
| Senior Member Join Date: Aug 2007 Location: Tillson, New York
My Car: 2007 Prius Model: Package: #6 Thanks: 2
Friends: 1 | By using a pin, you can rotate the nozzle in any direction you want. you don't need two pins. Just stick the pin in and use it like a joystick..... but be careful a little goes a long way. Like the other person said.... Been using that method for many years. Sometimes they get stuck and take alittle to get them to move, but DON'T use pliers or screwdrivers. All you will do is ruin the nozzle. |
| | #17 |
| High Fiber Member Join Date: Jun 2005 Location: South OC So Cal & the Flathead Valley MT
My Car: 2004 Prius Model: N/A Package: #9 Thanks: 41
Friends: 14 | Being the consummate prankster, I can't wait 'till I get home. Aim one towards the sidewalk, while waiting for the green light. Aim the other straight up in the air to squirt the tailgater behind you on the freeway. |
| | #18 |
My Car: 2008 Prius Model: Package: #6 Touring Thanks: 171
Friends: 2 | Hill, +1, but why not use one/both of the nozzles for the hatch window for the tail gater? |
| | #19 |
Friends: 0 | thank you everyone.... my stream also does not look very strong.... should i just use my air compressor? Any recommendations? My friend's prius is much stronger. |
| aimable, sprayers, windshield |
| Really Big Windshield | B Rad | Gen II Prius Main Forum | 14 | 06-04-2006 01:14 PM |
| Windshield crack | BoosPrius | Gen II Prius Main Forum | 8 | 05-05-2006 10:30 AM |
| Shaded windshield? | darelldd | Gen II Prius Main Forum | 10 | 05-01-2006 06:34 AM |
| Tint on the windshield | AlphaTeam | Gen II Prius Modifications | 11 | 04-29-2006 10:01 PM |
| New Windshield | RBW111 | Gen II Prius Main Forum | 4 | 11-19-2005 11:34 AM |
