| This is a discussion on So I figured out how to install my block heater within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally posted by oly_57mpg @Dec 1 2005, 07:08 PM OK! The Wattmeter is connected. It doesn't seem to matter what ... |
| | #201 | |
| | #202 |
| Member Join Date: Sep 2005 Location: Issaquah, Washington
Friends: 0 | Tripp or anybody Have you run the numbers to see if the block heater is cost effective? Since many of us Prius drivers accept a higher operating cost (i.e. self imposed tax to help the environment), another analysis might be CO2 effectiveness. In other words, will the amount of CO2 released generating the electricity to pre-heat the engine be more or less than the amount of CO2 released heating up the engine using gas? |
| | #203 | |
__________________ You can quote me on this, People who drive vehicles that idle at a traffic light, are idiots. mine 2k3 avg. 5.36 for 46,915Km Best tank 4.4L per 100K 64.2 Imperial 53.4 U.S. gallon, MiniScanner, SilverStars, block heater, winter lips, in as of Oct 15, out on April 25. In again on Sept. 21st. her's 2k4 "B" avg. 6.01 for 42,317 Km Best tank 4.02L per 100K, CAN-view with OBD11 module and flashloader, SilverStars, 06 Chrome grill bar, Michelin HydroEdge, upper and lower grill blocker,upper out as of April 7, lower out on April 28. In again on Sept 21st. | |
| | #204 | ||
| Senior Member Join Date: May 2005 Location: Olympia, Portland, Seattle...
I have a bit more than a hub in my garage; 7 foot 4 post rack, half full of hardware (servers, UPSs, Custom battery packs...) and the house is wired with 1 GB Ethernet and 1-wire (sensor network).
__________________ Had an 05 Prius now a BMW 550i... | ||
| | #205 | |
Here is some current data to mull over... Date Time (GMT), Watt hour reading, calculated watt 12/02/2005 05:15:03, 343266.5, 412 12/02/2005 05:21:08, 343307.6, 405 12/02/2005 05:27:17, 343348.8, 402 12/02/2005 05:33:20, 343389.6, 405 12/02/2005 05:39:26, 343430.5, 402 12/02/2005 05:45:29, 343471.3, 405 12/02/2005 05:51:33, 343512.0, 403 12/02/2005 05:57:44, 343553.3, 401 12/02/2005 06:03:51, 343594.8, 407 | |
| | #206 | |
Friends: 6 | Quote:
BTW, that's a great price. I don't think that I can justify it though. We typically use less then 400 kWh/month at our house so measuring the load has never been an issue. It would satisfy various curiosities about energy use however. Frank et al., what's the the CO2 emissions for 1 kWh generated by a coal fired plant? I know that 1 gallon of gas creates 20 lbs of CO2 so I can figure out the emissions reductions. Yeah, I know that it's pretty trivial but I'm curious.
__________________ Cheers, Tripp 2005 Silver Pkg 3, OEM Block Heater, Coastal Tech EV mod, BT Tech Chassis Stiffener, hell damned infernal reverse beep disabled Boulder Real Estate ![]() Howay the Toon!"Sometimes when you aim for the stars, you hit the moon." -- Ian Holloway | |
| | #207 |
Friends: 0 | for what it's worth http://www.sierraclub.org/cleanair/factsheets/power.asp |
| | #208 | ||
Friends: 6 | Quote:
Frank, sorry for being so lazy. If I'd gotten off my arse and just googled "CO2 Emissions per kWh Coal" I'd have answered my own question. However, there are probably other folks out there that are interested... I dug the following up at: http://www.eia.doe.gov/cneaf/electricity/p.../co2report.html Note the text in bold. Quote:
| | #209 |
Friends: 0 | it's actually the mercury emissions that have got me worried. |
| | #210 |
Friends: 6 | Yep, those are never good. However, if the EBH is running in the early hours or the morning or at night it's probably just drawing on base load, which would be generated anyway right? So in that case there would actually be a reduction in emissions because of the gasoline savings? Am I full of it or is this correct? |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/10591-so-i-figured-out-how-install-my-block-heater.html | ||||
| Saturn Of Green Bay, Saturn Oil Change, Missions To Saturn The Planet - Marshallboots | This thread | Refback | 03-11-2009 08:16 AM | |
| Ford Escape Prices, The Great Escape Rockford Illinois, Ford Escape Hatch - Kawasakiklr650 | This thread | Refback | 03-10-2009 06:55 AM | |
| Conti Ducati 750 Paso, Contax Rts Repair Manual, Continental Aircraft Engine Parts - Championenterprises | This thread | Refback | 03-08-2009 08:37 AM | |
| Prius heat-efficiency mods | This thread | Refback | 07-06-2008 05:15 PM | |
| Prius heat-efficiency mods | This thread | Refback | 03-29-2008 03:48 PM | |
| Engine Block Heater Install - Did I do it right? | Green Hokie | Gen II Prius Modifications | 36 | 12-30-2007 03:05 PM |
| My Engine Block Heater install | Rangerdavid | Gen II Prius Modifications | 66 | 07-09-2007 01:26 PM |
| DIY Block Heater Install? | gpb5200 | Gen II Prius Modifications | 3 | 03-02-2007 10:41 PM |
