This is a discussion on So I figured out how to install my block heater within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I think the engine would still go through it's normal warm up cycle based on outside air temp and engine ...
LinkBack (5) Thread Tools
Old 12-29-2005, 09:14 AM   #261
tomdeimos
I think the engine would still go through it's normal warm up cycle based on outside air temp and engine temperature.
tomdeimos is offline
Old 12-29-2005, 10:19 AM   #262
HybridVigor
[snapback]180575[/snapback]
Yeah, I guess in retrospect exhaust gases are much hotter than anything you're likely to be able to cost-effectively heat to get a jump-start on the warm-up process. I remember doing an IR temperature measurement on a big ol' diesel engine exhaust pipe for a mud-rotary drill rig last summer, and it went off the scale of the temp gauge (>500 degrees F) so I probably should have reached that conclusion already. Back to the drawing board.
HybridVigor is offline
Old 01-05-2006, 02:17 PM   #263
mdmikemd
mdmikemd's Avatar
Ok, got my heater in...it was a PITA...
When I got the plug in, I couldn't feel if it was flush with the core and I can't sense if it's very tight or not. Anyone else have the same experience?
Mike
mdmikemd is offline
Old 01-05-2006, 02:56 PM   #264
Friends: 37
Mike
[snapback]184225[/snapback]
When it is in right it feels right. the core should 'snap' when it locks in place. It should not slide out without releasing the clip. the plug should go on snuggly, but it's a little harder to be absolutely certain that it's on all the way. I just wiggled the cord to make sure it didn't feel loose or fall out.
efusco is online now
Old 01-05-2006, 03:13 PM   #265
mdmikemd
mdmikemd's Avatar
[snapback]184264[/snapback]
That's all I did too...fingers crossed!
mdmikemd is offline
Old 01-05-2006, 03:54 PM   #266
Frank Hudon
do you have a multimeter whereby you could check the ohm reading between the two blades on the plug. You should have a reading of about 350 ohms.
Frank Hudon is offline
Old 01-16-2006, 06:29 PM   #267
sdgeiger
If you purchase the block heater from Toyota Canada's website, does it come with instructions and a diagram?
My dealer said they have no idea how long it would take to install and asked if I could provide instructions with a diagram.
Also, they said that I should call Toyota to see if this would void my warranty since it's not offered in the US.
sdgeiger is offline
Old 01-16-2006, 06:37 PM   #268
Bill Lumbergh
USAF Aircraft Maintainer
Bill Lumbergh's Avatar
Package: #1
The block heater won't void your warranty, and it IS available in the US, as I got mine in Alaska. My local dealer wanted 1.5 hours labor to install it. Took me less than half that time.
The instructions are worthless, as they don't explain where to install the heater. Your best bet would be to either do it yourself or give the install techs a link to this thread.
Bill Lumbergh is offline
Old 01-16-2006, 07:42 PM   #269
sdgeiger
[snapback]191462[/snapback]
The service dept mgr searched and couldn't find it available anywhere. He feels that it's only available in colder areas.
By the way, can you easily unplug the heater and detach the power cord so it's not hanging inside the engine or do you just wrap it up inside to secure it?
sdgeiger is offline
Old 01-16-2006, 07:45 PM   #270
mdmikemd
mdmikemd's Avatar
[snapback]191459[/snapback]
It comes with a schematic of the heater, but not really with instructions on where it goes. Mine gave directions on where it goes in the Matrix and Rav4, but it was just descriptive, no pictures.
I went to my dealer's parts department, they ordered from Canada and it took 2 weeks to arrive.
mdmikemd is offline
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/10591-so-i-figured-out-how-install-my-block-heater.html
Saturn Of Green Bay, Saturn Oil Change, Missions To Saturn The Planet - Marshallboots This thread Refback 03-11-2009 08:16 AM
Ford Escape Prices, The Great Escape Rockford Illinois, Ford Escape Hatch - Kawasakiklr650 This thread Refback 03-10-2009 06:55 AM
Conti Ducati 750 Paso, Contax Rts Repair Manual, Continental Aircraft Engine Parts - Championenterprises This thread Refback 03-08-2009 08:37 AM
Prius heat-efficiency mods This thread Refback 07-06-2008 05:15 PM
Prius heat-efficiency mods This thread Refback 03-29-2008 03:48 PM
Engine Block Heater Install - Did I do it right? Green Hokie Gen II Prius Modifications 36 12-30-2007 03:05 PM
Help me install block heater. i will pay $ saechaka Private Sales 1 09-21-2007 01:44 PM
My Engine Block Heater install Rangerdavid Gen II Prius Modifications 66 07-09-2007 01:26 PM
DIY Block Heater Install? gpb5200 Gen II Prius Modifications 3 03-02-2007 10:41 PM
