| This is a discussion on So I figured out how to install my block heater within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Here's a link to some pics I took while I was installing my block heater. The first one gives you ... |
| | #311 |
| Senior Member Join Date: Jun 2006
My Car: 2002 Prius Model: Package: N/A Thanks: 0
Friends: 0 | Here's a link to some pics I took while I was installing my block heater. The first one gives you a good idea what you are looking for and the next few are of the same area looking up from under the car. The two circled areas are the same boss that the heater goes into viewed from different angles. Mike |
| | #312 | |
Friends: 0 | <div class='quotetop'>QUOTE(lee @ Oct 19 2006, 01:40 PM) [snapback]335240[/snapback]</div> Quote:
I'll still probably do it from above. Dave M. | |
| | #313 |
Friends: 37 | |
| | #314 | |
Friends: 0 | <div class='quotetop'>QUOTE(efusco @ Oct 20 2006, 08:23 AM) [snapback]335560[/snapback]</div> Quote:
Thanks Evan. I just went back and found your earlier post of this photo, and it does look like what I saw when I looked up and saw the exhaust manifold. Your photo shows one of the two holes I mentioned earlier, but is obvously from a slightly different angle than I had viewed it. I had printed off your photo earlier, and now I wish that I had carried it under the car with me. In seeing the correct angle, it would probably have given me an indication of where to try to get my hand through. I may end up doing if from below, but will have to jack up the car higher than I had it to possibly get my arm into the hole. I'll have another look at it this evening. I would prefer not to take the wiper assembly, etc. apart if I can avoid it. In looking at the jack point in the owner's manual again, I guess it is clear enough, but I'll have to be under the car when positioning it. I'd like to get at least 3 or 4 inches more clearance before trying to reach up to find the correct hole. At it is, I can barely slide under the car without it touching my chest. Thanks again. Maybe I'll actually get it done this evening. Dave M. | |
| | #315 | |
| Prius Absolutum Dominium Join Date: Sep 2005 Location: Long Island, NY
My Car: 2004 Prius Model: Package: Base Thanks: 27
Friends: 10 | <div class='quotetop'>QUOTE(efusco @ Oct 20 2006, 11:23 AM) [snapback]335560[/snapback]</div>To clarify a little, Evan's picture is taken from ground level ---UP. <div class='quotetop'>QUOTE(dmckinstry @ Oct 20 2006, 12:01 PM) [snapback]335587[/snapback]</div> Quote:
SAFETY precautions are a MUST!!! | |
| | #316 | |
Friends: 0 | <div class='quotetop'>QUOTE(mrbigh @ Oct 20 2006, 09:38 AM) [snapback]335607[/snapback]</div> Quote:
Right. The first time I looked at Evan's picture I wasn't sure of that. But it became apparent later. Now I'll have to get under the car again to see exactly where he had the camera when he took the photo. Hopefully that will tell me where to stick my hand through. As I told Evan, I'll have to jack the car up further to have a chance of succeeding. As it is, the front wheels are only 6 inches off the ground when they are on the ramps I have. Anyway, thanks for the continued support. Dave M. | |
| | #317 | |
Friends: 0 | <div class='quotetop'>QUOTE(dmckinstry @ Oct 20 2006, 09:45 AM) [snapback]335609[/snapback]</div> Quote:
Well, replying to myself, but I've about given up on doing the installation from below the car. That is, unless someone can tell my how to get my elbow past the drive shaft. I'm attaching a photo. I'm sorry for the poor quality, but I couldn't get my camera set on a wide enough angle to hold the camera while I was taking the picture and had to try holding the camera against the ground. If I'd held the camera I would have gotten a picture closer in appear to the one Evan provided. [attachmentid=5411] As you look at the photo, you can see what I presume to be the right drive shaft near the top of the image, and beyond that the exhaust manifold, which is also visible in Evan's photo. Below and to the left of the exhaust manifold is the point I should be trying to reach. Below the driveshaft (not physically below, but below in the photo) seems to be the widest entry point to reach the required location. However, I've been unable to get my elbow through that region from any angle I can reach. This is with my right arm as was mentioned by someone here earlier. Going over the top of the drive shaft seems impossible as well. Is there a better entry location? I can't see one, but clue me in if there is. I've been in and out from under the car close to a dozen times without any luck. If no one can tell me what I'm doing wrong, I'll have to remove the wiper assembly and cowling and try to get at it from above. Thanks for any suggestions. Dave M. | |
| | #318 | |
Friends: 10 | <div class='quotetop'>QUOTE(dmckinstry @ Oct 21 2006, 08:33 PM) [snapback]336231[/snapback]</div> Quote:
Working from above is much cleaner and safer.
__________________ PHEV conversion (rolling since Dec '06) | |
| | #319 | |
Friends: 0 | <div class='quotetop'>QUOTE(mrbigh @ Oct 21 2006, 06:11 PM) [snapback]336240[/snapback]</div> Quote:
Thanks for the quick reply. You've definitely convinced me. Dave M. | |
| | #320 | |
However, is there a special puller tool for removing the wiper arms? I've tried tapping on the bolt while pulling up on the wipers with no luck, and I don't want to take the chance of damaging anything. After all, this is the first completely new car I've ever owned. That's after nearly 50 years of driving. Would a spray lubricant be in order? Dave M. | |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/10591-so-i-figured-out-how-install-my-block-heater.html | ||||
| Saturn Of Green Bay, Saturn Oil Change, Missions To Saturn The Planet - Marshallboots | This thread | Refback | 03-11-2009 08:16 AM | |
| Ford Escape Prices, The Great Escape Rockford Illinois, Ford Escape Hatch - Kawasakiklr650 | This thread | Refback | 03-10-2009 06:55 AM | |
| Conti Ducati 750 Paso, Contax Rts Repair Manual, Continental Aircraft Engine Parts - Championenterprises | This thread | Refback | 03-08-2009 08:37 AM | |
| Prius heat-efficiency mods | This thread | Refback | 07-06-2008 05:15 PM | |
| Prius heat-efficiency mods | This thread | Refback | 03-29-2008 03:48 PM | |
| Engine Block Heater Install - Did I do it right? | Green Hokie | Gen II Prius Modifications | 36 | 12-30-2007 03:05 PM |
| My Engine Block Heater install | Rangerdavid | Gen II Prius Modifications | 66 | 07-09-2007 01:26 PM |
| DIY Block Heater Install? | gpb5200 | Gen II Prius Modifications | 3 | 03-02-2007 10:41 PM |
