This is a discussion on Racing Hubcaps or Aerodynamic Hubcaps within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Finally took a picture of my mudguards and my caps. Mudguards should not be a problem with hurting fuel mileage ...
LinkBack (10) Thread Tools
Old 04-26-2006, 06:47 PM   #21
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Finally took a picture of my mudguards and my caps. Mudguards should not be a problem with hurting fuel mileage because the caps push the air around them. But i dont care about that anyway. The mudguards and the caps look good and that all I care about.
TheForce is offline
Old 04-27-2006, 12:50 AM   #22
talonts
VFAQman
talonts's Avatar
<div class='quotetop'>QUOTE(theforce @ Apr 26 2006, 05:47 PM) [snapback]245776[/snapback]</div>
[attachmentid=3118]
Jay,
What length rivets did you use? I'm assuming you used 3/16" rivets. All the rivets I have currently are either too short or way too long.
My hubcaps arrived today, I have drilled the extra 3 holes in each and have all the holes in the trim rings, but the bolts/nuts I used to hold the pizzapans on will interfere with the rim a bit, so I'll have to rivet them.
I'm assuming the washers you used on the rivets were the specialized rivet washers that may or may not have come with your rivets?
I'm dropping by Home Depot tomorrow with a trim ring and hubcap to get the right length rivets, but it would be nice to verify my thoughts on the "right" length.
BTW, these hubcaps are the same brand I bought for my 71 Mustang in college in the late 80s, I can't believe they're still around! And obviously their QC on size is still an issue, as I see from your original pics that your Mike's hubcaps pretty much sit flush with the edge of the trim rings, while mine are about 1/8-3/32" smaller in radius than the trim rings.
Tom Stangl
* http://www.vfaq.net/
* Prius Visual FAQ Home
* 04 Prius AM #7
* 06 Prius NL #7
* http://www.vfaq.com/
* DSM Visual FAQ home
* 90 Talon AWD
talonts is offline
Old 04-27-2006, 01:16 AM   #23
darelldd
Prius is our Gas Guzzler
darelldd's Avatar
Probably my only concern with doing this mod is how the wheels (front especially) will be caked with brake dust that won't be as easy to clean off. Brake dust is hell on clear-coat. I wash my wheels off quite often, and it'll just add one more step of removing these covers to clean an area that I don't even see. Am I a slave to fashion? Only time will tell... I still greatly appreciate you sharing this with us!
darelldd is offline
Old 04-27-2006, 09:17 AM   #24
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Here are the rivets I bought at lowes.
Rivets
They are 3/16 by 1/4inch long. I had to buy the washers seprate. 50 rivets per pack and 30 washers to a pack. WTF? They were even the same brand! Its just like buying hotdogs and hotdog buns. I plan on changing to stainless steel rivets when I can find them.
I bought the 15 inch caps and my caps are about the same size as my rings or 1/32 larger or smaller but they fit well.
I'm washing my car about 1 time a month and I take off the caps to wash out the brake dust. Its not that hard really. So far theres not much dust in there but I dont use my brakes that much anyway. Mostly regen until I hit that 7mph or below mark and then I come to a quick stop.
Hope this helps eveyone.
TheForce is offline
Old 04-27-2006, 05:21 PM   #25
Bob Allen
Captainbaba
Bob Allen's Avatar
Where do the valve stems go? Looks like you'd need to take the hubcaps off to check your tire pressure, which is inconvenient enough to encourage not checking tire pressure. I think they do look cool, but I'm skeptical about the mileage claim.
Bob
Bob Allen is offline
Old 05-11-2006, 07:29 PM   #26
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
I would like to say I took my car up to 97MPh today and the hub caps are still holding strong. I'll never go that fast again unless i'm on a drag strip or race course. The car felt a little too lose for me at those speeds.
Yes you have to take the caps off to check the air pressure but I fill my car with gas, wash the car, and check air pressure once a month so its no big deal for me. Increased mileage or not i'm keeping mine on. I seen an improvement but your mileage may vary.
TheForce is offline
Old 06-15-2006, 03:09 PM   #27
Cheap!
Cheap!'s Avatar
My hubcaps shoud be here today. Thank you for the post. Here is my goal.
[attachmentid=3809]
Cheap! is offline
Old 06-15-2006, 03:28 PM   #28
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Your welcome. Looks nice! Where are you going to get your wheel skirts?
TheForce is offline
Old 06-15-2006, 05:02 PM   #29
Cheap!
Cheap!'s Avatar
<div class='quotetop'>QUOTE(theforce @ Jun 15 2006, 02:28 PM) [snapback]271777[/snapback]</div>
I'll Make them from sheet metal or foam covered in resin and painted to match
Notice the skirts don't come down all the way...I've been looking at the curve of the sides of the Prius. If I made a full skirt it would have to puff out at the bottom and I'm not sure I want to do that.
Cheap! is offline
Old 06-15-2006, 05:43 PM   #30
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Please post pictures when you get them finished. I would like to see how they look.
TheForce is offline
aerodynamic, hubcaps, racing
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/17361-racing-hubcaps-aerodynamic-hubcaps.html
Клуб Любителей Toyota Prius -> Фото колеса This thread Refback 11-11-2008 05:40 AM
Frickin Ridiculous - Page 2 - Subaru Legacy Forums This thread Refback 10-25-2008 01:28 AM
Frickin Ridiculous - Page 2 - Subaru Legacy Forums This thread Refback 10-18-2008 12:14 PM
Frickin Ridiculous - Subaru Legacy Forums This thread Refback 10-17-2008 04:31 PM
Frickin Ridiculous - Subaru Legacy Forums This thread Refback 10-17-2008 01:58 AM
Frickin Ridiculous - Subaru Legacy Forums This thread Refback 10-17-2008 01:19 AM
Frickin Ridiculous - Subaru Legacy Forums This thread Refback 10-17-2008 01:07 AM
Клуб Любителей Toyota Prius -> Фото колеса This thread Refback 09-03-2008 11:40 AM
Клуб Любителей Toyota Prius -> Фото колеса This thread Refback 09-03-2008 09:47 AM
Jay Groh dot com This thread Refback 08-21-2008 12:15 AM
Plastic Hubcaps On or Off? Dahgu Gen II Prius Modifications 18 11-22-2007 08:49 PM
Used racing or aerodynamic hubcaps. Only 3 available. TheForce Private Sales 2 10-30-2007 07:20 AM
Aerodynamic Hubcaps Cheap! Gen II Prius Technical Discussion 22 09-01-2006 08:08 AM
Can I paint my hubcaps? Godiva Gen II Prius Modifications 20 07-05-2006 09:06 PM
