| This is a discussion on Tire Upgrade within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(nyprius @ Jun 22 2007, 12:47 PM) [snapback]466498[/snapback]</div> A better tire, such as the TT, CT, HE or many ... |
Tire Upgrade
| | #151 | |
| Tree-hugging Vegan Witch Join Date: May 2007 Location: Grays Harbor, WA, USA
My Car: 2007 Prius Model: N/A Package: Base Thanks: 249
Friends: 66 | <div class='quotetop'>QUOTE(nyprius @ Jun 22 2007, 12:47 PM) [snapback]466498[/snapback]</div> Quote:
| | #152 |
Friends: 0 | Can you put the touring tire from the 2007 (195/55r16) on the Camry Hybrid rim, which is a 16x6.5? Or, do you have to get new tires? |
| | #153 | |
Friends: 8 | <div class='quotetop'>QUOTE(Bill_Lovett @ Jun 24 2007, 03:28 AM) [snapback]466913[/snapback]</div> Quote:
It is very clear that Camry Hybrid rims (PCD 114.3 mm) won't fit on Prius (PCD 100 mm). Ken@Japan | |
| | #154 | |
| Senior Member Join Date: Oct 2005 Location: Saratoga Springs, NY
Friends: 1 | <div class='quotetop'>QUOTE(Bill_Lovett @ Jun 23 2007, 02:28 PM) [snapback]466913[/snapback]</div> Quote:
| | #155 |
Friends: 0 | I'm surprised so many people are having trouble getting non-185 tires. I had no trouble getting my Toyota dealer's parts dept to order Kazera KZ-V 16x7 wheels with ComforTred 205/60 HR16's pre-mounted from TireRack. They gave me TireRack's pricing, free shipping, $10 mounting, free disposal of the old (37K) Integrities, free 24-month road hazard warranty, took a $20 coupon and gave me another $20 coupon for the next set. Great deal, no hassle at all, and the same shop still stands behind the car since they sold & installed them.
__________________ '01@77K@56mpg, '05@40K@44mpg, '06@20K@46mpg |
| | #156 | |
Friends: 0 | Interesting information. Questions: Does the stock tire rim fit the Falken Ziez 205/60R15's, and did this raise the rear end height up at all? Thx <div class='quotetop'>QUOTE(TomKahn @ Jun 27 2006, 01:30 PM) [snapback]277445[/snapback]</div> Quote:
| | #157 |
| Shuttlecraft Commander Join Date: Jun 2007 Location: Out there, somewhere
Friends: 11 | Driving in my area usually involves dedicated snow tires in winter. With that in mind, what would be the recommended tire for high mpg as opposed to all- (=no) season tires? |
| | #158 | |
Friends: 0 | <div class='quotetop'>QUOTE(Doc Willie @ Jul 5 2007, 10:58 AM) [snapback]473554[/snapback]</div> Quote:
Not that I'm recommending these. They seem to rate poorly among current owners at TireRack. In the P195/65R15, the 5 tested tires I found reported RRC 4/ numbers of: BF Insignia SE 200 89S .0076 Goodyear Integrity .00955 GY ComforTred .01139 GY Regatta 2 .01253 BF Affinity LH30 89H .0126 but frankly I'm not recommending any of these either (though we really like our ComforTred 205/55-16's). After some fairly obscure research, I figured out the whole "rolling resistance coefficient" thing to my satisfaction, at least for the moment, and it got so involved I decided to post in the Technical Discussion forum: http://priuschat.com/LRR-tires-and-R...ta-t35624.html You could try playing around with the data-sorting in the xls I uploaded with that topic. I must admit, as abstract as the numbers actually are, I can understand why no one is rushing to study up on them, or to promote the RRC numbers as a way of selecting LRR tires. A few basic problems with the tests: They test with the tires overinflated (3 psi over sidewall's max-pressure rating). They test only when already running warm, at 80 kph only, in a straight path on a drum. No effort is made to check or describe the contact patch under these conditions. The only way an RRC will give you any useful info is in comparing selected tires in the exact same width/aspect-ratio/wheel-diameter... even then, the weakest-tread tire will deform the most, and tend to show the best score. That said, within an exact width/aspect-ratio/wheel-diameter, the reported numbers do seem to give a telling rank of which tires have better LRR performance. Cheers, Bob | |
| | #159 | |
| Electrical Engineer Join Date: Jan 2007 Location: Camas, WA
Friends: 1 | <div class='quotetop'>QUOTE(bobdavisnpf @ Jul 5 2007, 08:56 PM) [snapback]473818[/snapback]</div> Quote:
| | #160 | |
| Junior Member Join Date: Jun 2007
Friends: 0 | Would you use 205/65R15? Thanks. <div class='quotetop'>QUOTE(nyprius @ Jun 26 2006, 10:46 AM) [snapback]276822[/snapback]</div> Quote:
| tire, upgrade |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/20573-tire-upgrade.html | ||||
| Toyota Sai to Be Next Prius-Branded Hybrid? | PriusChat | This thread | Refback | 10-15-2009 12:09 PM | |
| Touring Edition Tire Upgrade | wblovett | Gen II Prius Modifications | 44 | 10-24-2009 08:57 PM |
| Tire Upgrade - Walmart | ibcs | Gen II Prius Main Forum | 3 | 11-19-2007 11:21 AM |
| Tire upgrade and pressure sensor question | Dr Ed | Gen II Prius Technical Discussion | 16 | 08-20-2007 06:01 PM |
| Tire Upgrade | Kramer | Gen II Prius Main Forum | 16 | 10-10-2006 10:39 PM |
| 17" Tire Upgrade Reccs? | Ken S | Gen II Prius Modifications | 5 | 09-12-2006 03:41 PM |
