This is a discussion on Tire Upgrade within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by Cordsniper I recently purchased a used 2008 touring edition, it has about 10k miles on it and ...
Tire Upgrade
LinkBack (1) Thread Tools
Old 02-22-2009, 06:25 PM   #351
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
Default Re: Tire Upgrade
Originally Posted by Cordsniper View Post
I recently purchased a used 2008 touring edition, it has about 10k miles on it and has Goodyear integrities in a 195/65R16 size. That seems pretty strange to me after doing some research about tires, I didn't know it was a touring until after I got it. I hate the tires and would like to change them. Should I go to a 205/55R16 to avoid run flat tires or should I stay at a 195? I'm really looking for better handling and stability out of it as living in LA necessities quick highway adjustments, etc.
Odd that you have those tires on a supposed Touring Edition.
The Touring's OEM tire is the Bridgestone Turanza El-400 in the 195/55R16 size.
In any event, quite a few Touring owners have moved to the 205/55R16 size for the greater variety of tires offered, and I haven't heard of any problems.
If you haven't seen it already, here's a decent thread on tire upgrades for the Touring Edition:
http://priuschat.com/forums/prius-mo...e-upgrade.html
There are other threads and posts on the subject too.
Good luck.
EDIT: If I had a Touring and wanted to stay with the OEM 195/55R16 size, I'd try the Falken Ziex. You can google "Falken Ziex" using the google search function here and get lots of posts about it.
Best regards, Tom
07 Magnetic Gray #2 - GY TripleTreds 195/60R15, BT Tech Stiffening Plate & Strut Tower Brace, Philips X-Treme Power Headlights, Webasto 4300 Sunroof, Sharkfin Antenna, Chrome Wheelskins Wheel Covers & Door Handles, BumperDefender.com Bumper Guard Strips, Body Side Moldings & Rear Bumper Protector, NoBump.com License Plate Screw Bumpers, Bumper Bully, Sheepskin Seat Cover, Leather Steering Wheel Cover, Leather Center Console Cover, Center-Hump Litter Basket, Non-Slip Pads, Dalmatian Bobble Heads.
Boo is offline
Old 02-23-2009, 08:03 PM   #352
GB'sprius07
I'm reading and see a lot of post regarding changing tire size.... , what is the real significance of the larger tire size , i do know with a up grade from the OEM Integreties , most tires of a better overall grade will give you increased , grip handling, smoother ride , longer tire wear , this is what i hear , my tire size is 185/65/15 , i have read some
owners have gone up from a this size to a 195 /60/15 on the same rim , my Prius is a base model not Touring, i called a dealer and asked if they would put the larger size on my car and they said either they would not do it , and did not recommend it , so my question other than , handling , longer tread wear , longer life , and appearance , what's the significance of the larger size
GB'sprius07 is offline
Old 02-23-2009, 08:29 PM   #353
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
All other things being equal, changing to a wider width tire should result in better overall handling, traction and braking, but lower mpg.
For example, when Consumer Reports road tested the 2004 Standard Prius with its 185/65/15 Goodyear Integrities and a 2007 or 2008 Touring Edition with its 195/55/16 Bridgestone Turanza El-400s, it found that the Touring Edition had 10 feet dry and 12 feet wet shorter 60-0 mph braking distances, but also got 2 fewer mpg than the Standard Prius. I think that most of these differences are attributable to the 10mm wider Touring tires.
The Standard Prius' braking distances are below average. It ranked only in the 11th percentile of the over 100 current model sedans tested by Consumer Reports. That's pretty bad.
Personally, I think trading 2 mpg for 10-12 feet shorter braking distances is a very good trade. I switched to 195/60/15 Goodyear TripleTreds when I only had 1000 miles on my Prius and its OEM Integrities.
Boo is offline
Old 02-23-2009, 08:59 PM   #354
GB'sprius07
Thanks Boo, i have read alot of your post , and i do appreciate the time you put into your research , its greatly respected , from a new Prius owner such as myself , all points taken , as far as the MPG drop is concerned , is the drop a on going result from the upgrade , or does the MPG return after the break in period ?
Old 02-23-2009, 09:41 PM   #355
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
The 2 mpg drop was what Consumer Reports reported. Because they test new cars, it was a 2 mpg drop from the Standard Prius' new tires and the Touring Edition's new tires. I doubt that this 2 mpg differential would change as both cars' tires wear.
It would be great if we could have a real apples to apples (different sizes of the same tire) comparison test. But I think Consumer Reports' results make sense. And that if you were to do a comparison test of 185mm wide Integrities against 195mm wide Integrities, you'd get substantially similar results.
If you do decide to go with 195/60/15 tires, a lot of places (like your dealer, Costco, others) may not do it, but others will. In my case, I ordered my wider tires online from TireRack.com because TireRack had the lowest prices. I had TireRack drop-ship the tires to an approved tire installer of my choice, and the tire installer then installed them.
Good luck on whatever you choose to do. Between the 185/65/15 and the 195/60/15 sizes, I don't think there's necessarily a wrong and a right choice.
Boo is offline
Old 03-02-2009, 12:18 AM   #356
butchbs1985
Taking things apart is fun!
New tires again today on my 2005. For those who haven't read the entire thread, here's the history:
- Stock Tires replaced at 18,500 Miles with Goodyear TT's
- Goodyear TT's 195/60/R15 replaced about 45,000 due to excessive treadwear
- My goodyear dealer special ordered Kumho Solus KR21's 195/60/R15 to replace the TT's (only paid about 1/3 cost because or the short TT life).
- Today 97,000 replaced the KR21's with Michelin WeatherWise II's 195/65/R15. I found that the 195/65's were considerably cheaper. Not sure why there is a cost difference but perhaps I'll be accurate on my spedo now since it's a larger tire.
Initial observations: Much softer ride on the new Michelin tires even when inflated to 40/38 psi.
My biggest complaint about the Kumho KR21's was that they didn't seem to grip the road as much as the TireRack reviewes indicated. They were however CHEAP so for the price, I don't think you can go wrong.
I hope to get much longer life out of the Michelin's so I paid the extra cash and here's to hoping!!
-Brian Maxwell
Mods:
1. Terk XM Satellite Radio
2. Mud Guards
3. Costal Tech 2" receiver
4. PC Shop Decals
5. Integrated an Ultra 400 Watt Power Inverter
6. Drivers Side Lumbar Support
7. Automatic Bluetooth Speed Sensor Override
8. WeatherTech FloorLiners - Worth every penny
Last edited by butchbs1985; 03-02-2009 at 12:19 AM. Reason: Incomplete thought :-)
butchbs1985 is offline
Old 03-02-2009, 12:44 AM   #357
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
Thanks Brian for your reviews. Good luck on the Michelin WeatherWise II's. Hope you let everybody know how they work out for you.
Regarding the larger 195/65/15 tire, nyprius in his initial post observed that you might expect a 2.2% under-reading on the speedometer compared to the speedometer's reading with the OEM Integrities. But I don't remember the source (or its assumptions, if any) of his RPM numbers:
"In the 195, I looked at the 195/60R15 and the 195/65R15. The 195/60 has 863 RPM (.9% higher than the US OEM). The 195/65 has 836 RPM (2.2% lower than US OEM). According to others on PC, the Prius speedometer over-reads by 1-2 mph (ie: it says you’re doing 60 when you’re really doing 58 or 59 mph). The 195/60 has less than half the distortion of the 195/65. It would increase the over-read by less than 1%, whereas the 195/65 would reduce over-read by more than 2%, possibly resulting in under-read (a more risky condition). Personally, I don’t mind a little over-read. It helps to minimize speeding tickets. The radius of the 195/60 is .325 cm less than the 185/65 (about one eighth of an inch). So ground clearance won’t be affected significantly. (The 195/60 tire is .65 cm shorter than the 185/65, but the car would only be .325 cm lower.)"
Boo is offline
Old 03-02-2009, 09:11 AM   #358
butchbs1985
Thanks Boo. You're correct that the decreased RPM will decrease the over-read and possibly lead to under-read. I plan to do a bit of testing with the Prius' GPS as well as my wife's portable GPS. I'll reply with what I find regarding actual speed compared to the speedometer speed. Like I said initially, the biggest benefit of getting the 195/65 was the price difference. If there's a bit of under-read, I'll just have to keep that in mind.
Old 03-02-2009, 10:43 AM   #359
hyo silver
awaaay
hyo silver's Avatar
Friends: 63
... so my question other than , handling , longer tread wear , longer life , and appearance , what's the significance of the larger size
Those are all good reasons. Another is that not all tires come in all sizes. I chose the Goodyear Triple Treds, which aren't available in 185/65/15, but are made in 195/60/15.
hyo silver is offline
Old 03-05-2009, 06:14 PM   #360
David
I have about 48,000 on my Goodyear Triple Threads. I'm good at keeping the pressure at 40-38 and rotating the tires. Alignment was checked a while back and was fine. The tires are almost worn to their wear strips so it's time to replace. The TTs were great tires but I'm not happy about the wear or the road noise.
Has anyone gone from the TTs to the Comfort Tread? Any suggestions for another tire to try? I live in Florida so don't need the grip but we sure do get rain in the summer and the TTs were great in it.
Thanks.
2010 III w solar sunroof
David is offline
tire, upgrade
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/20573-tire-upgrade.html
Toyota Sai to Be Next Prius-Branded Hybrid? | PriusChat This thread Refback 10-15-2009 12:09 PM
Touring Edition Tire Upgrade wblovett Gen II Prius Modifications 44 10-24-2009 08:57 PM
Tire Upgrade - Walmart ibcs Gen II Prius Main Forum 3 11-19-2007 11:21 AM
Tire upgrade and pressure sensor question Dr Ed Gen II Prius Technical Discussion 16 08-20-2007 06:01 PM
Tire Upgrade Kramer Gen II Prius Main Forum 16 10-10-2006 10:39 PM
17" Tire Upgrade Reccs? Ken S Gen II Prius Modifications 5 09-12-2006 03:41 PM
