This is a discussion on Tire Upgrade within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by David I have about 48,000 on my Goodyear Triple Threads. I'm good at keeping the pressure at ...
Tire Upgrade
LinkBack (1) Thread Tools
Old 03-05-2009, 07:23 PM   #361
butchbs1985
Taking things apart is fun!
Default Re: Tire Upgrade
Originally Posted by David View Post
I have about 48,000 on my Goodyear Triple Threads. I'm good at keeping the pressure at 40-38 and rotating the tires. Alignment was checked a while back and was fine. The tires are almost worn to their wear strips so it's time to replace. The TTs were great tires but I'm not happy about the wear or the road noise.
Has anyone gone from the TTs to the Comfort Tread? Any suggestions for another tire to try? I live in Florida so don't need the grip but we sure do get rain in the summer and the TTs were great in it.
Thanks.
Comfort Treads were great until about 20,000 miles in when I had them on my Intrepid. At about 50% wear, they were like driving on slicks when it rained and worse in the snow. Goodyear told me I was crazy and would not replace them under warranty as 'they still had tread'. Needless to say, I ditched them and won't be buying more Goodyear.
butchbs1985 is offline
Old 03-06-2009, 11:09 AM   #362
Cremaster77
New to the forum and wanted to see if anyone had any opinion on the Nokian WR G2 vs. the Goodyear TT. I'm at 40k now and the tread on my OEMs is pretty much gone. I live where it snows maybe 2-3 times a year and am not that particular about tire noise. I would like to preserve as much MPG as possible and would like to get good tread wear. Any thoughts on these two tires vs. each other or perhaps an even better tire for what I'm looking for? Thanks.
Cremaster77 is offline
Old 03-06-2009, 01:09 PM   #363
wicastawakan
Package: #1
Someone asked & I have th Kumho Solus KR21 tires. 195-60-15. I have always preferred Michelin tires & planned on putting them on my 2008 Prius. I have a Kumho store near me & they swear by the KR21 tires, so I tried a set.
Ride-Outstanding & I use a higher psi than stock
Handling-Outstanding wet, dry, VG snow/ice
Quiet-Outstanding
Responsiveness- outstanding
I have been super impressed with these tires so far. I did drop mpg on the first tank. The first initial 150 miles was in a stiff crosswind & significantly hilly country & slightly under 40mpg, but the full tank averaged in the 40's.
After a few thousand miles, I averaged 50 mpg all through the "winter". I have averaged 50 mpg over the last 5-6 tanks of gas & a combo of 30% city & 70% highway.
It is warming up here, but offset by miserable wind & last couple tanks are 51mpg plus.
I'd say the mileage is fine, but the handling makes a different vehicle out of it. I recommend the tire size & the tire itself. I do not regret a single thing about these tires at this time. Hope that helps.
wicastawakan is offline
Old 03-07-2009, 10:38 AM   #364
jdenenberg
jdenenberg's Avatar
I can't directly discuss the GY TT as I have never used them, but if you want good MPG, get a tire that has a known Low Rolling Resistance (LRR). My Nokian WR tires (now get the WRg2) have improved my MPG by 4% (about 2 MPG) averaged over 12 months (29k miles) vs the OE Goodyear Integrity tires that came with my 2004 Prius. They also track well (no highway instability), have great traction in ALL weather conditions, and have a 51 psi MAX pressure rating (185/65HR15). The only drawbacks are expense (>$100 per tire - 50,000 mile treadwear - sorry, but you need a soft rubber compound to get good traction) and a little road noise (the WRg2 should be quieter).
JeffD
jdenenberg is offline
Old 03-07-2009, 05:23 PM   #365
Cremaster77
Thanks for the opinions. After reading some more I think I'm going to go with the Nokian WR G2. At the very least, I'm sure they'll be a significant improvement over the Integrity.
Old 03-08-2009, 01:09 PM   #366
derohanes
Great stuff guys/gals. My Prius is about ready for new shoes, but I have 2 questions regarding this thread. 1) I live in Salt Lake City with a very steep driveway, and no tire will get my car up the hill, so the all season tires aren't an option- I use a 4wheel drive. What tires would you guys recommend for wet/dry/no-snow conditions. 2) I see 42/40 tire pressures referred to as standard, but my '06 calls for 33/32.
derohanes is offline
Old 03-09-2009, 10:03 PM   #367
jdenenberg
jdenenberg's Avatar
First, your 06 calls for 35/33 on the OE tires and that is too soft for stability in highway driving. Since the tires are safe to 44 PSI many of us do run 42/40.
Second, I have Nokian WR tires on my Prius and they have great traction in dry/wet/snow/ice. The Nokian WRg2 tires now sold should be just as good in most conditions (a little less traction in snow due to a less agressive tread design), Note that the Nokians are safe up to 51 PSI.
JeffD
Old 03-10-2009, 03:54 PM   #368
sunnymoe
Hi Frank.Thanks for a great in depth & scientific article!
My wife's Prius 2006 with 30,009 miles has about 2->3/32" left on the original OEM tires. I just started looking for replacement and your informative article, beside providing big help, also confirmed my personal observation. Some time ago I bought Goodyear's TT tires for my Oldsmobile 2000 Intrigue. I have logged close to 15,000 miles here in South Florida, with no apparent wear out(!) yet. These tires have great grip of the road both at hot weather and super wet drenched road. Our local road formulation is different by way of using local elements for the formulation of the paving material, like adding crushed sea shell (I'm told) to it. I did my own analysis on the speedometer/Odometer variation and I concur with you. I am going to buy my wife a new set of GY TT 195/60R/15 tires. As to tire pressure. The "Low Pressure" dashboard indicator seems to be very sensitive and triggers almost to 1 psi loss. I was told not to pay too much attention to it. What's your opinion on this?
Thanks again,
Moshe
sunnymoe is offline
Old 03-12-2009, 01:52 PM   #369
Salt
Just had the new LRR Bridgestone Ecopia EP100s (OEM tire for the 2010) installed on my '06 Tuesday. Although my initial impressions are somewhat suspect since I switched from squishy winter rubber on steel wheels, they seem much more stable on the highway than the Integritys. The tires are very quiet and ride feels much stiffer with solid handling. Mileage is way up from the Winter set, but it's too early to generate any real data.
Downsides so far are the lack of any mileage warranty, and the fact that this is a Summer only tire. I'll post an update once I have them broken in a bit more. -J
Salt is offline
Old 03-12-2009, 02:06 PM   #370
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
Hi Salt,
Looking forward to your future reports on the Ecopia EP100.
-- Do we know if it is the same tire as the Ecopia EP20 that was on the 2010 Prius models at the various auto shows and Prius Connection events? (It does sound like it's the same.)
-- What size did you get and how much did you pay?
Regarding the warranty, this report said 3 years:
2009 Chicago Auto Show: Bridgestone Brand Ecopia EP100 Debuts at Chicago Auto Show-VIDEO ENHANCED
Boo is offline
tire, upgrade
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/20573-tire-upgrade.html
Toyota Sai to Be Next Prius-Branded Hybrid? | PriusChat This thread Refback 10-15-2009 12:09 PM
Touring Edition Tire Upgrade wblovett Gen II Prius Modifications 44 10-24-2009 08:57 PM
Tire Upgrade - Walmart ibcs Gen II Prius Main Forum 3 11-19-2007 11:21 AM
Tire upgrade and pressure sensor question Dr Ed Gen II Prius Technical Discussion 16 08-20-2007 06:01 PM
Tire Upgrade Kramer Gen II Prius Main Forum 16 10-10-2006 10:39 PM
17" Tire Upgrade Reccs? Ken S Gen II Prius Modifications 5 09-12-2006 03:41 PM
