This is a discussion on Prius Tire Upgrades within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(theorist @ Oct 22 2006, 06:53 PM) [snapback]336535[/snapback]</div> My understanding is that size 195/55-16 tires on 16" rims are ...
Prius Tire Upgrades
View Poll Results: Tire Upgrade Pole
BFGoodrich's Traction T/A H 7 10.77%
Bridgestone Potenza RE960AS Pole Position 4 6.15%
Goodyear Assurance TripleTred 32 49.23%
Kumho Solus KH16 0 0%
Michelin Pilot Exalto A/S 16 24.62%
Yokohama AVID H4S 6 9.23%
Voters: 65. You may not vote on this poll
LinkBack (3) Thread Tools
Old 09-09-2007, 10:24 PM   #21
nyprius
My understanding is that size 195/55-16 tires on 16" rims are standard in Europe and Australia, optional in Japan, and now available in the US on the 2007 touring edition. I don't know of anywhere that Toyota equips the Prius with size 195/60-15 tires that will fit our 15" rims.
My choice for my uses is the size 195/65HR15 ContiProContact (or perhaps the Dunlop SP Sport 5000?). If still lived in Phoenix, I'd go with a Sumitomo HTR 200. If I lived in Seattle, I'd go with the Potenza RE960AS. If I cared less about fuel efficiency and was facing a Michelin sale at Costco (like now) -- the Pilot Exalto AS. If I was looking to spend less up front -- the Falken ZE-512.
I bought the BF Goodrich Traction TA 195/60HR15 for our Elantra. I wouldn't buy them again because of the high rolling resistance and loss in fuel economy that I've experienced, other users at TireRack have since complained about, and Consumer Reports has now measured. Otherwise they're good performance tires. (They're too noisy and rough riding to be considered grand touring.)
195/60R15 is the OEM size for the Prius in Australia. It causes less speedo/odo distortion than the 195/65R15 since revolutions per mile are .9% higher, versus 2.2% lower. Also, for nearly all brands, the 195/60 will have wider tread than the 195/65 since there is less balloning with a lower tire. Therefore, the 195/60 will handle better than the 195/65 because it has wider road surface contact and the car is slightly lower than the OEM 185/65 versus slightly higher for the 195/65.
nyprius is offline
Old 09-10-2007, 05:15 AM   #22
Lim
Lim's Avatar
Package: S Touring
My Prius is come with the size 195/55-16 tires on 16" rims. I have changed it with Goodyear Excellence 195/55-16R and changed the rims to Enkei RS+M 16x7.
Lim is offline
Old 05-14-2008, 02:50 PM   #23
fmshire
Package: #2 Touring
Default Re: Prius Tire Upgrades
Hi;
I just bought Prius 2008 Pkg. 2 Dark Blue. I was thinking upgrading both the tires and rims. And this is what I have in mind.
205/50/17 Michelin Pilot Exalto A/S with Enkei RS+M 17.
Please let me know what you think and any recommendations you may have.
Cheers.
fmshire is offline
Old 05-27-2008, 11:12 AM   #24
PriusSport
PriusSport's Avatar
For new cars, you can do a new tire swap of the 185/65 Integritys with Goodyear for wider tires--195/60 Comforttreads or Tripletreads. I've done it before with other cars.
The Comforts are quieter, the Triplethread are better in wet/snow conditions. A tradeoff. Both are rated much higher than Integrity on Tirerack. They also cost more.
$81 for Comfort, $97 for Triple vs $65 for Integrity. Is it worth it? Maybe in winter climates.
PriusSport is offline
Old 05-27-2008, 01:11 PM   #25
PriusSport
PriusSport's Avatar
I checked with a local Goodyear dealer, and they will swap the same tire size only--since 185/65 is the only Prius spec size for 15" wheels. The ComfortTread in the same size will cost $25 added plus install per tire.. More of a premium tire than the Integrity. Better traction, wear and lower noise. They currently have a $40 rebate so I'm considering it.
Old 05-27-2008, 02:29 PM   #26
hiremichaelreid
Wrnchs OScopes Computers oh my
hiremichaelreid's Avatar
Package: Pioneer #3
Interesting info. I don't suppose Bridgestone has an equivalent deal ? In Canada ?
hiremichaelreid is offline
Old 09-01-2009, 03:34 PM   #27
chefHawk
chefHawk's Avatar
Model: V
Package: G Touring w/ Leather
You seem to know a lot about Tires.. I have the 2010 model V with the 17 inch rims. My Firestone/Bridgestone guy recommended the Potenza Re960as Pole Position. Any thoughts about if there is any tire that would give me better mileage than my OEM tires?
Any thoughts about the best winter tires?
Any Prius owners our there who use a snow tire?
Originally Posted by theorist View Post
<div class='quotetop'>QUOTE(FBear @ Oct 16 2006, 04:24 PM) [snapback]333652[/snapback]</div>
chefHawk is offline
Old 09-02-2009, 06:58 AM   #28
turnerdhr
HellaFlush(TM) Prius
turnerdhr's Avatar
Package: Premium (Europe)
Friends: 26
i'm currently on 19 Inch Falken FK-452 Tires - 215/35/19 all around.
44psi in Front and 42psi in Rear.
post pics of your prius w/ rims!!
i'm liking it so far...~ !
turnerdhr is offline
Old 09-02-2009, 10:25 AM   #29
max2prius
You must be taking a huge mileage hit as well as a rough ride. I have 17 inch Scion TC rims with Bridgestone Potenza EL400 215 45 17's and am taking a 5MPG hit. Any tire upgrade suggestions to improve mileage? I know the wheels itself are 8lbs heavier than OEM which hurts.
max2prius is offline
Old 09-04-2009, 05:21 AM   #30
turnerdhr
turnerdhr's Avatar
Friends: 26
i'm averaging 559 miles for a full tank of gas at the moment.... not sure if that's good or bad for riding on 19"s and pure city driving....
prius, tire, upgrades
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/24687-prius-tire-upgrades.html
prius tire size - Zuula Search This thread Refback 09-15-2009 01:47 PM
prius best tires - Zuula Search This thread Refback 03-31-2009 08:15 PM
prius tires michelin - Zuula Search This thread Refback 01-17-2009 09:18 AM
tire shop broke a TPMS tire pressure monitor sensor during tire change theorist Gen II Prius Care, Maintenance and Troubleshooting 32 04-08-2009 11:57 PM
Prius-class Shuttlecraft Upgrades Doc Willie Gen II Prius Main Forum 49 04-03-2008 06:50 AM
Market for Prius upgrades Swanny1172 Gen II Prius Main Forum 8 05-30-2007 08:49 PM
'01 Prius System Upgrades Bigtruc Gen II Prius Audio and Electronics 9 04-08-2006 03:36 AM
Prius Engine HP upgrades JBJAG Gen II Prius Main Forum 19 11-14-2005 12:22 AM
