| This is a discussion on Disconnect the battery before doing mods? within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I apologize in advance if this question is as silly as it sounds, but do you disconnect the battery before ... |
| Junior Member Join Date: Sep 2006
My Car: 2007 Prius Model: N/A Package: #6 Thanks: 0
Friends: 0 | I apologize in advance if this question is as silly as it sounds, but do you disconnect the battery before adding any mods (EV switch, video interface, etc.) to your Prius? Is there a reason why you shouldn't? I'm only asking because my gut instinct is to disconnect it, but from what I've read here, it sounds like some people leave the battery connected. I didn't know if there was a reason specific to the Prius for keeping the battery connected. Thanks, Paul |
| Has his homepage set to PC Join Date: Mar 2005 Location: Vancouver, BC
My Car: 2005 Prius Model: Package: B Thanks: 0
Friends: 3 | The safe way to go would be to disconnect the Aux battery, but I like to live on the edge |
Friends: 0 | <div class='quotetop'>QUOTE(PaulV @ Dec 13 2006, 10:37 PM) [snapback]362003[/snapback]</div> Quote:
| Platinum Member Join Date: Mar 2006 Location: Minnesota
My Car: 2006 Prius Model: Package: #7 Thanks: 35
Friends: 3 | It really depends on what you're doing and your knowledge level of electronics. If you're performing a simple mod that involves plugging/unplugging items, you probably don't need to worry about it. if it involves wire tapping, if you're sure the wire is electrically isolated or that you fully understand the implications have having it connected/disconnected at various times, then you don't need to worry about it. However, if you aren't that informed electrically about the car, then disconnect it just to be on the safe side. no harm, other than losing the clock, radio presets, and recorded mileage on the MFD, will come from it. |
Friends: 0 | I've installed Coastal's EV mod, Auto-Lock and basic NAV kit; cut and installed a switch for the phone override and installed the DICE all without disconnecting the battery. I was probably very luck, but there was no problems. |
| Senior Member Join Date: Jan 2006 Location: Washington State
Friends: 0 | <div class='quotetop'>QUOTE(eagle33199 @ Dec 14 2006, 06:52 AM) [snapback]362119[/snapback]</div> Quote:
When you diconnect the battery there is one more step (than those listed by eagle above) which you must do. It is initialization of the power window regulator. It is a simple procedure. After reconnecting the battery you: 1. turn on the car to Ready, 2. Open the driver's window half way, 3. Close the driver's window and hold it closed for at least one second, and 4. check theAUTO/UP and AUTO/DOWN to see that they work properly. If they don't, you disconnected the 12 v battery for 10 seconds and repeat the process. If you don't do this step, your power windows may not work properly. Almost any interuption of electric power calls for this initialization of power windows.
__________________ White 2006 Package 8, clear bra, block heater, ScanGuage, Highlander side mouldings | |
Friends: 3 | <div class='quotetop'>QUOTE(Allannde @ Dec 14 2006, 10:02 AM) [snapback]362153[/snapback]</div> Quote:
And honestly, the only reason the repair manual specifies disconnecting the 12v battery for everything is for legal reasons - it's a hell of a lot easier to say disconnect it for everything than it is to fight a legal battle when someone leaves it connected and gets shocked when something shorts out (odds of that happening are slim, though) | |
Friends: 0 | When I installed my Kapppa's with an amp, I didn't disconnect the battery. I hacked together a T-harness to go between the stereo and the car wiring harness. I left one wire cut but untaped, wasn't stripped. When I plugged it in to see if it worked, pop, everything shut off.. At first I though just a fuse, but nothing worked. No dome lights, car wouldn't start, nothing. After freaking out for a minute, I decided to start pulling fuses. Turns out I just blew one fuse, lucky me. I also accidentally bumped the windows lock switch when I was putting the driver door panel back on. Again took me a while to figure out why the passenger window switch would not work. Good thing I can keep calm pretty well. |
| Battery Mods | mr_zorg | Gen II Prius Modifications | 4 | 10-06-2006 08:22 PM |
| Disconnect battery terminals for DICE installation? | Priscilla | Gen II Prius Audio and Electronics | 4 | 07-31-2006 10:41 AM |
| Cannot reset auto window after battery disconnect | mwhaley99 | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 06-14-2006 12:03 PM |
| Center Speaker Disconnect | pennyprius | Gen II Prius Audio and Electronics | 36 | 06-10-2006 04:42 PM |
| Disconnect Battery? | Florida Prius | Gen II Prius Main Forum | 2 | 02-02-2006 09:32 PM |
