This is a discussion on First Morning with a Blocked Grill within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by snead_c DAPASTAGUY, you might also put some of your insulation on the lower grill that also really ...
LinkBack (4) Thread Tools
Old 01-21-2009, 02:05 PM   #291
dapastaguy
dapastaguy's Avatar
Default Re: First Morning with a Blocked Grill
Originally Posted by snead_c View Post
DAPASTAGUY, you might also put some of your insulation on the lower grill that also really takes in quite a lot of cold air.
I will probably block some of it tonight. I am also going to get a scanguage to monitor the temps. It looks like an interesting add on for any car, not just the prius
I blocked 1 section of the lower grill - didn't have enough materials to do more. It was very hard to do, and I will have to cut it into individual sections. I don't like the wavy look as it is now.
dapastaguy is offline
Old 01-26-2009, 03:32 PM   #292
dapastaguy
dapastaguy's Avatar
I took a trip from Sumter, SC to Charlotte, NC over the weekend with just the top grill blocked. MFD indicated 43.8. After fuel up fpr return trip (I fill at half tank all the time) it is currently showing 48.9. A big improvement.
My scanguage should be here Thursday or Friday. I looked at Can View but it looked too hard to install. After ordering the scanguage I sam the Dash HQ - I wish I had waited as it looks much neater with the visual effects.
I have searched the forums for the prius lower grill block that had the holes in it that you could plug. I know I saw it in one of these posts. I think that would be much simpler for the lower grill, and I could place and rem,ove plugs as the temperature required.
Old 01-26-2009, 05:51 PM   #293
snead_c
snead_c's Avatar
Package: #5 Touring
I'm new here and have not seen the removable plug block.
For the lower grill I cut two 3 foot sections of insulation and lined up the sections against the grill noting where notches need to be located. I cut notches out to allow the foam to slip in closer without showing the cuts. The glue on the foam seems to be holding the strips in place well enough for the few months I'll leave it on and the foam has a smooth appearance.
I'm planning on a Scanguage...What is a Dash HQ ?
snead_c is offline
Old 01-26-2009, 09:26 PM   #294
dapastaguy
dapastaguy's Avatar
There is a thread for it in the Mods forum - I may have the name wrong.
I did it is DashDAQ
http://priuschat.com/forums/prius-mo...w-canview.html
Old 02-04-2009, 04:31 PM   #295
bobjeri
Package: #4 Touring
This is a sensational thread .. found it & went thru it last night.
Huge thanks to the numerous posters who led the way on this and provided volumes of feedback and advice.
Installed the upper grill blocks this AM. Will block 1/2 the bottom later today.
I'll have another question later but the answers here have some bearing.
When fully blocked the OAT gives distorted reading. Will the OAT give distorted readings at highway speed:
1 When the lower grill is only half blocked?
2. When only the upper grill is blocked?
Edit -- did upper half of the lower grill and after it cooled took a 20 mi drive.
Seems to allow the passenger compartment to warm up quicker and better mileage by a noticeable factor. Drove by a bank temperature sign that was 4 deg cooler than the OAT indicator. 180 mi drive tomorrow in 32 to 50 deg and check temps with a good thermometer.
"What can be asserted without proof can be dismissed without proof."
-- Christopher Hitchens
bobjeri is offline
Old 02-04-2009, 10:23 PM   #296
boxer93
Psyched for PHEV
boxer93's Avatar
I have searched the forums for the prius lower grill block that had the holes in it that you could plug. I know I saw it in one of these posts. I think that would be much simpler for the lower grill, and I could place and remove plugs as the temperature required.
You might be thinking of hybrid effects Hybrid Effects - Grille Block I checked this out first. As I wasn't as worried about looks. I cut a piece of vinyl siding and connected it through the lower grill with toggle bolts. It's been working fine for me.
Chris
boxer93 is offline
blocked, grill, morning
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/26675-first-morning-blocked-grill.html
Cute Car Seat Covers, Custom Car Seat Cover Eeyore, Custom Hawaiian Print Car Seat Covers - Cornbelt This thread Refback 03-09-2009 07:32 AM
Grille blocking The Chronicles of a Geography Nerd This thread Refback 12-03-2008 02:09 PM
Reusing election debris | Tiny Choices This thread Refback 11-17-2008 10:44 PM
Prius update The Chronicles of a Geography Nerd This thread Refback 11-10-2008 02:13 PM
Blocked Grill and Erroneous Temp Readings? TonyPSchaefer Gen II Prius Main Forum 17 10-27-2008 12:32 PM
grills blocked by insulating material jarhtmd Gen II Prius Modifications 14 06-29-2007 09:19 PM
Blocked in-Tow them? Peking Duck Gen II Prius Main Forum 0 10-15-2004 10:19 PM
PC pages blocked by Spybot!? Varko PriusChat Website Questions 16 10-09-2004 02:57 AM
