This is a discussion on When to remove lower grill block? within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(TonyPSchaefer @ Feb 9 2007, 05:47 AM) [snapback]387387[/snapback]</div> Wait a minute! It's warmer in Canada than it is in ...
Old 02-09-2007, 10:21 AM   #11
Frank Hudon
Wait a minute! It's warmer in Canada than it is in Chicago?
currently 40F
Frank Hudon is offline
Old 02-09-2007, 11:19 AM   #12
dmckinstry
<div class='quotetop'>QUOTE(Frank Hudon @ Feb 9 2007, 07:21 AM) [snapback]387437[/snapback]</div>
currently 40F
I assume you're in British Columbia, rather than further north.
In the right edge of Washington State, it still got just below 0C last night. That's in spite of weather people claiming a "pineapple express" for last night or the night before. It's above freezing now, but the roads are still slick from the underlying frost.
Dave M.
dmckinstry is offline
Old 02-09-2007, 12:32 PM   #13
Frank Hudon
<div class='quotetop'>QUOTE(dmckinstry @ Feb 9 2007, 08:19 AM) [snapback]387474[/snapback]</div>
Dave M.
yup in Vancouver. I lived up north and I've seen -45F more than I ever want to again. But we need that to kill the mountain pine beetles that are devastating the northern pine forests. But global warming hasn't allowed that to happen. So it'll be burn baby burn again this summer.
Old 02-09-2007, 04:35 PM   #14
dmckinstry
<div class='quotetop'>QUOTE(Frank Hudon @ Feb 9 2007, 09:32 AM) [snapback]387533[/snapback]</div>
Yep. And burning off more trees sure isn't going reduce global warming.
Dave M.
Old 03-26-2007, 02:29 PM   #15
Chuck.
Honda Enzyte Driver
Chuck.'s Avatar
My Car: Other Hybrid
<div class='quotetop'>QUOTE(efusco @ Feb 6 2007, 09:58 PM) [snapback]386481[/snapback]</div>
When temps are consistantly above 60 I think I'd remove the lower just to be safe. Upper when consistantly 70. My numbers, no data, just rough guide based on observed temps.
For you guys in the Sunbelt, it's probably time to remove it - seriously.
ScanGage says my coolant temperature normally peaks at 198F. Saturday I drove 210 miles cruising on the interstate at 65mpg in 75F weather. Coolant was at 227F. Was running the heater before I stopped to remove the radiator block. Yes I drive an Insight, but does anyone want to test their coolant hoses?
Chuck. is offline
Old 03-31-2007, 04:22 AM   #16
philmcneal
Taxi!
i commute to richmond everyday with upper and lower blocked but the lower has two airintake holes to cool, however, it still reaches 95 degrees C every now and then and then gets knocked down to 86 C... maybe cooling system kicked in? So far it has never exceeded 96C but I do climb hills... two major ones in fact.
But yeah when the mornings do hit 15 degrees C its time to strip.
philmcneal is offline
Old 03-31-2007, 11:07 AM   #17
Frank Hudon
<div class='quotetop'>QUOTE(philmcneal @ Mar 31 2007, 01:22 AM) [snapback]415407[/snapback]</div>
I've hit 97C a couple of times but it only last for a few minutes. This with the Classic, the wife with a realativily flat commute hasn't got to the mid 90's yet so it's still plugged as well. I'm going to do my little experiment with her's by pulling the top grill blocks and see what the temps turn out to be. I couldn't get it to the thermostat opening temp,87C, with the top not blocked in the winter so that's the reason for my taking them out first. The belly pan has the openings for the inverter section of the rad in case it goes over temp. By Richmond do you mean B.C. or VA?
Blocking the grill New2Prius2008 Gen II Prius Main Forum 28 01-07-2008 07:24 AM
Sorry if this is stupid...but what is grill block? sea-horsea Gen II Prius Modifications 5 10-24-2007 03:12 AM
Temps, grill blocking and when and which to remove Frank Hudon Gen II Prius Main Forum 17 04-13-2007 01:20 AM
Last day with Grill blocker efusco Gen II Prius Modifications 13 03-17-2007 07:31 PM
To remove or not to remove door panels DBM Gen II Prius Modifications 4 06-27-2005 10:24 AM
