This is a discussion on Coastal EV mode died within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Looking for help in diagnosing this problem. Have 2006 prius. Installed the Coastal EV mode mode. Worked fine. Now, it ...
Old 02-11-2007, 09:25 PM   #1
psibill
Have 2006 prius. Installed the Coastal EV mode mode. Worked fine. Now, it doesn't work. Pulling the cruise level toward me and holding for 2 secs or so, nothing. If the ICE is running (after warmup) and cruising below 34mph, ICE won't shut down. If trying to go into EV mode while the ICE is in warmup mode (yes, I know it won't go), I no longer get the warning on the MFD that "can't enter EV mode now."
So, something definitely up. It IS curious that, although I don't drive it that often, the problem seems to have occurred after the car's first service period at the dealer. Any chance they could have somehow disabled the programming?
If I wanted to test the EV mode programming to see if it's still working, can I just short one of those wires to ground? Which one?
Thanks.
--Bill
psibill is offline
Old 02-11-2007, 10:24 PM   #2
dzucc
dzucc's Avatar
<div class='quotetop'>QUOTE(Bill-psi @ Feb 11 2007, 08:25 PM) [snapback]388687[/snapback]</div>
Thanks.
--Bill
Bill,
First I would check your connections again. In particular, check to see if the pin you inserted into the wiring harness is seated properly. If that doesn't work call or email coastal. Warning, be patient and persistent with trying to get a hold of Coastal. Good Luck!!
dzucc is offline
Old 02-11-2007, 10:26 PM   #3
Friends: 37
Have you eye-balled your connections? In particular your tap to ground and the pin in #27 on the ECU...those can pretty easily come lose. Of course you've got another tap with the Coastal rig so check that as well.
The programming hasn't, I'm absolutely confident, been changed. It's highly unlikely the dealership has any clue that the mod is there. If they do know there's something there they probably don't know what it is. There's been no TSB issued about disabling any EV mods.
But, if you've got to test you just need a momentary ground to pin 27 to test.
Evan E. Fusco, MD
efusco is offline
Old 02-11-2007, 10:30 PM   #4
tripp
tripp's Avatar
Friends: 6
<div class='quotetop'>QUOTE(Bill-psi @ Feb 11 2007, 07:25 PM) [snapback]388687[/snapback]</div>
Thanks.
--Bill
Has it been brutally cold where you are? I've noticed a possible connection between temp and the thing not working. It's been warmer here lately and it's been working fine again.
tripp is offline
Old 02-11-2007, 11:24 PM   #5
psibill
Yeah, but I'd not expect a bad wire connection. It can happen, of course, but...
I did just visit, or tried to visit, their website.
I got a "service unavailable" page. Hope that doesn't mean anything bad.
do you have their phone number, in case the website doesn't come up for a while?
Thx.
<div class='quotetop'>QUOTE(tripp @ Feb 11 2007, 10:30 PM) [snapback]388705[/snapback]</div>
That depends on your reference. Yes, we had a few days of really cold whether a week or so ago. Got down to the low thirties. But it's much warmer now.
psibill is offline
Old 02-12-2007, 09:48 AM   #6
grasshopper
check out this post http://priuschat.com/index.php?act=ST&...st&p=386134
grasshopper is offline
Old 02-13-2007, 03:16 PM   #7
Presto
Has his homepage set to PC
<div class='quotetop'>QUOTE(Bill-psi @ Feb 11 2007, 06:25 PM) [snapback]388687[/snapback]</div>
Thanks.
--Bill
The EV mod looks like it's working fine if you go the message that said it can't go into EV mode. There's just some other factors that prevent the Prius from entering EV mode. Temperatures, SOC, etc... could be preventing EV.
Presto is offline
Old 02-14-2007, 11:55 AM   #8
ilusnforc
Package: #8
<div class='quotetop'>QUOTE(Presto @ Feb 13 2007, 02:16 PM) [snapback]389668[/snapback]</div>
But he did say "I no longer get the warning on the MFD that 'can't enter EV mode now.'"
It sounds like a connection came loose to me... I would try shorting that pin on the computer to a ground source.
ilusnforc is offline
Old 02-14-2007, 06:27 PM   #9
Presto
<div class='quotetop'>QUOTE(ilusnforc @ Feb 14 2007, 08:55 AM) [snapback]390207[/snapback]</div>
oops.. missed that "no longer" part.
reading comprehension pwned me
Presto is offline
Old 02-14-2007, 07:41 PM   #10
ilusnforc
Package: #8
<div class='quotetop'>QUOTE(Presto @ Feb 14 2007, 05:27 PM) [snapback]390534[/snapback]</div>
You need a signature at the bottom of your post to match the avatar:
"D'oh!"
coastal tech mode derohanes Gen II Prius Modifications 10 05-08-2007 06:54 PM
Coastal EV Mode trouble... homeinvader Gen II Prius Modifications 28 07-16-2006 06:46 PM
06 EV mode behavior w/ Coastal mod? crichman Gen II Prius Modifications 4 04-16-2006 06:38 PM
Just installed my Coastal EV Mode mod DaveSheremata Gen II Prius Main Forum 2 03-15-2006 12:15 PM
EV Mode From Coastal: Any Experience Out There? Bob Hayes Gen II Prius Modifications 36 08-07-2005 02:37 AM
