| This is a discussion on North American EV Indicator Light within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Well I just got done tearing my dash apart to see if installing an EV light is possible. I spent ... |
| I plug in my Prius Join Date: May 2005 Location: Wheelersburg, Ohio
My Car: 2006 Prius Model: N/A Package: #7 Thanks: 36
Friends: 23 | Well I just got done tearing my dash apart to see if installing an EV light is possible. I spent 6 hours tearing the dash apart. Had a good learning experience. Cut 3 fingers. Scratched my leather wheel cover but I put some touch up paint on it to hide the scratch. Lost my MPG on the MFD but I was only about 100 miles into this tank. My conclusion is that its not possible to add the EV light. I was able to trace down 3 connectors that go to the EV light. I soldered on 3 lengths of wire to the 13 pin connector where I traced the connections too. I then hooked everything up and put my volt meter on the ends of the wires to see if there was a voltage change when I entered or exited EV mode. Sadly nothing changed. I tried all 3 in different configurations. I even tried grounding each wire with the volt meter hooked up. The Only thing I found was 2 of the wires had a constant 12v and the other was a ground.I believe there must be either (1) There are some more components missing from the main computer (2) There are missing wires going to the main computer or (3) There is no programming for the light. I'm not going to dive into this any further but if anyone else wants to tackle this you can. Also if anyone is interested in a schematic of the indicator circuit board just ask and I will post it shortly. You can see where the EV light should go here on the left right next to the W. The W means the LED should be WHITE. [attachmentid=7772] [attachmentid=7773]
Friends: 0 | <div class='quotetop'>QUOTE(theforce @ Apr 30 2007, 05:51 PM) [snapback]432852[/snapback]</div> Quote:
because if you just add an ev sw. 2pole single throw and power half of the sw.and the other to the ev indicator and just bypass the relay board all together. if the indicator is realy important. seems as it shpould work if the icon is there or is it blacked out on the dash? | |
Friends: 4 | There is no etching on the North American dash. I think only the LED was missing, The Force would have found someone to do the etching for him later, but all in all he has the can-view to show when EV mode is on. |
| | #4 | ||
Friends: 23 | <div class='quotetop'>QUOTE(priussoris @ Apr 30 2007, 08:10 PM) [snapback]432861[/snapback]</div> Quote:
| science runs my life Join Date: Mar 2005 Location: maryland
Friends: 27 | wow man, you just saved DH some work, he was interested in the very same thing! that does suck though ![]() thanks for doing that. |
Friends: 23 | Well I think I have a theory. The extra resistor and diode just pass voltage to a pin on the connector. Could this be an "enable LED" signal for the computer? Something like if signal is + then you have EV and light the LED when EV mode is activated, if not dont send voltage to the LED. Could this be how it works? If so we will need to find the resistor values to give it a try. Maybe if we can get one of our Japanese or Europe guys to take a good pic of the board it might help us a little. Here is a schematic so you can see what is going on. [attachmentid=7775] |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 462
Friends: 28 | are you sure? Cause on the 04/05s, you can see the EV light outlight. The icon is there, the light isn't. |
Friends: 23 | <div class='quotetop'>QUOTE(Tideland Prius @ May 1 2007, 12:13 AM) [snapback]433046[/snapback]</div> Quote:
Friends: 4 | I sure hope the guys over at Toyota are reading this. Do you see who you are dealing with? We are obsessed with a silly LED light? Why? Because everyone else in the world has it and we don't. How much time and frustration would you have saved your fans, how much money would you have saved in production, if you would have just left it in there? Not having the silly led light does not hurt us, but somehow I can't help feeling a little cheated by not having one on my dash when the rest of the world does. If I could buy one now for a reasonable price now I would.
__________________ * Classic Silver, Prius Plus Plug-in Hybrid Electric Vehicle Conversion *EV Button* Free Reverse Beep Mod, *Mirror Mod, * Aerodynamic hubcaps, * Almost Free Anytime Reverse Video, *Anytime Forward View Video, *Fumoto F103N Oil Drain Valve, *Almost Free Speed Wire Interrupt, *Almost Free Navigation Override switch, *Dual Microphone Mod *In Dash DVD Theater, *V4 CAN-View </span> <span style="color:#FF0000">Mods wanted in the near future - Hydraulic Brake -Pressure Indicator -Hobbits Vacuum “Good vs. Bad” Driving Indicator |
My Car: 2004 Prius Model: Package: #9 Thanks: 129
Friends: 42 | <div class='quotetop'>QUOTE(Cheap! @ May 1 2007, 04:28 AM) [snapback]433116[/snapback]</div> Quote:
| american, indicator, light, north |
| 2004 North American Car of the Year!!!! | Mybrid | Gen II Prius Main Forum | 4 | 01-07-2009 01:35 AM |
| Toyota considers building up to 5 North American plants | Beryl Octet | Other Cars | 0 | 01-11-2007 11:49 AM |
| 2006 Pricing up on North American Press!!! | XLR8 | Gen II Prius Main Forum | 3 | 11-05-2005 03:50 AM |
| Toyota to Decide North American Site for Hybrid Auto | dbarry | Prius and Hybrid News | 0 | 03-10-2005 06:29 PM |
| EV mode available on north american models! | DaveG | Gen II Prius Audio and Electronics | 0 | 02-08-2004 12:49 AM |
