| This is a discussion on Blind Spot Mirrors within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi has anyone in the Prius Chat installed the blind spot mirrors on the left and right side of the ... |
Blind Spot Mirrors
Friends: 0 | Hi has anyone in the Prius Chat installed the blind spot mirrors on the left and right side of the car? I think maybe it's a small square you stick on your side mirrors, and is supposed to eliminate the blind spots on the right rear and maybe the left rear. Do they work well, and if they interefere in any way, can they be removed. It would be great for backing up in the parking lot/ Mary |
Friends: 6 | Yep, I have them. Round, though, not square (not that it really matters). Having driven trucks and emergency vehicles for years, I've become quite accustomed to using my side mirrors for backing, lane changes, etc. The mirrors are one of the first things I added to the car. |
Friends: 0 | <div class='quotetop'>QUOTE(JimboK @ May 26 2007, 08:29 PM) [snapback]450564[/snapback]</div> Quote:
Can you tell me where you bought there mirrors, and how to put them on, and the brand name? Thanks so much. Mary | |
Friends: 6 | I don't remember for sure where I got them nor the brand name, but any auto parts store or the automotive section of a department store will have them. I got the smallest ones they have, which are maybe an inch and a half to 2" in diameter. I put them on the outer, upper corner of the side mirrors, attached with adhesive strips included with the mirrors. |
Friends: 0 | <div class='quotetop'>QUOTE(JimboK @ May 27 2007, 07:07 PM) [snapback]450754[/snapback]</div> Quote:
Thanks Jimbo, but can they be removed if they seem to be in the way. Do they block any part of your view? Mary | |
My Car: 2006 Prius Model: Package: #6 Thanks: 18
Friends: 12 | The best advice I can give is to adjust your mirrors properly so that you can see in all your "blind spots" with no extra convex mirrors blocking the relatively flat glass. The side mirrors are to see what's beside you. The middle "rear view" mirror is to see what is behind you. Give this an honest try - you will be safer, and won't need the extra stick-on mirrors. http://www.cartalk.com/content/features/mirrors/ |
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 9
Friends: 12 | <div class='quotetop'>QUOTE(darelldd @ May 27 2007, 09:47 PM) [snapback]450840[/snapback]</div> Quote:
There's a photo of mine on page 41 of the User-Guide. | |
Friends: 0 | <div class='quotetop'>QUOTE(Masnyd @ May 27 2007, 08:59 PM) [snapback]450825[/snapback]</div> Quote:
For every vehicle I bought, the first 'modification' I did is to stick on the convex mirrors. They are available at Target, Wal-mart and Kragen, Autozone, etc. you name it. They usually cost about $1 to $2 dollar per. I recommend putting them on the inside part (upper or lower) so that you still can make good use of the outer part to judge distance. | |
| Senior Member Join Date: Dec 2004 Location: San Ramon Valley, CA, USA
Friends: 1 | Mary- Yes you can easily remove them if you decide you do not like them. I suggest using a hair dryer to heat the adhesive tape which adheres them to the car's mirror first and then just grab them and pull them off with your fingers or something that will not scratch the factory mirror. Then a little wax to remove any residue. I too would get the smallest round ones and see if you like them. |
| blind, mirrors, spot |
| Blind Spot Testing by ConsumerReports.org | F8L | Gen II Prius Main Forum | 10 | 11-01-2007 12:06 PM |
| Blind Spot Patch | Mary Snyder | Gen II Prius Main Forum | 15 | 12-06-2006 12:33 PM |
| Does anyone else have a blind spot... | kdmorse | Gen II Prius Main Forum | 21 | 02-09-2006 12:31 PM |
| Prius Blind Spot | GreenMachine | Gen II Prius Main Forum | 6 | 11-02-2005 10:57 AM |
| Blind Spot | Ken Cooper | Gen II Prius Main Forum | 5 | 05-26-2004 11:52 AM |
