| This is a discussion on Tom's Prius Rear Suspension Member Strengthening Brace for a 2007 Toyota Prius. within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; ^^ So far, nothing in terms of new creaks or rattles. The brace is in there solid. As long as ... |
| | #11 | |
| Has his homepage set to PC Join Date: Mar 2005 Location: Vancouver, BC
My Car: 2005 Prius Model: Package: B Thanks: 0
Friends: 3 | ^^ So far, nothing in terms of new creaks or rattles. The brace is in there solid. As long as I get the spacers in properly for the crossbar, it should stay quiet. I have too find some time to take pictures. It's been too busy this week. My arms are still sore from the brace installation haha. <div class='quotetop'>QUOTE(apriusfan @ Jun 19 2007, 09:38 AM) [snapback]464735[/snapback]</div> Quote:
__________________ Daniel 2k5 Prius 'B' Package PriusPuter(nav/wifi/entertainment) E-Bay Motorized VGA TouchscreenEV Button CAN-View V2 TRD Sportivo Shocks and Springs Tom's Strut Tower Brace Tom's Lower Suspension Brace Tom's Rear Brace | |
| | #12 |
| Member Join Date: Nov 2006
Friends: 0 | I went back and got shorter, more stable braces installed. The back end is definately more solid now. I still hear a clunking sound that I need to get resolved. The shop took everything apart down to the shocks and I still can't get rid of the noise. I believe the noise is related to the single bar i the back. I'll post if I find a solution. Anyway since my Prius is an '05 and at least the gas tank is lower, the rest of you probably wont' have the same problems. I can take pics of the spacers if anyone is interested....let me know.
__________________ 2005 Package #6, white, 17" weds with general tires (about 8 oz more per wheel/tire than stock), trafficgauge, window tint, Focal front door speakers, auto door lock, trd sportivo suspension, toms front shock tower brace, Toms front lower brace, Toms rear suspension brace, HID foglights, signal mirrors, Damplifier noise reduction, anti-rattle pads, Lockpick, HD radio/Ipod adaptor, Sirius. |
| | #13 | |
Friends: 0 | <div class='quotetop'>QUOTE(Presto @ Jun 19 2007, 01:02 AM) [snapback]464530[/snapback]</div> Quote:
With all the flicks you shoot in Vancouver, I'd be worried. Seriously though, if you're racing around skipping your rear tires on all that TRD & Tom's gear, I'd expect some kind of abrasion. Sounds like you see the underside often enough to keep an eye on it though.
__________________ '01@77K@56mpg, '05@40K@44mpg, '06@20K@46mpg | |
| | #14 | |
Friends: 0 | <div class='quotetop'>QUOTE(bobdavisnpf @ Jul 9 2007, 07:43 AM) [snapback]475490[/snapback]</div> Quote:
Thought I'd add another note on spacers required for clearance of the triangular rear brace from the gas tank. I've got an '07 and I needed a 1" spacer to lower the rear part of the brace to provide about a 1/4" of clearance (I didn't want an interference fit) between the brace and the tank. The handling still felt much improved over the original set up. | |
| | #15 | |
| Senior Member Join Date: Apr 2007 Location: S.F. Bay Area
My Car: 2007 Prius Model: Package: #6 Touring Thanks: 38
Friends: 3 | <div class='quotetop'>QUOTE(Bogus Bill @ Jul 28 2007, 08:53 PM) [snapback]486923[/snapback]</div> Quote:
| | #16 | |
Friends: 0 | <div class='quotetop'>QUOTE(apriusfan @ Jul 28 2007, 10:01 PM) [snapback]486955[/snapback]</div> Quote:
What I've got in there right now are a bunch of stacked up washers (1" O.D. washers x qty10). I'm planning on replacing those with some solid spacers made out of some 1" aluminum bar stock. The one inch spacers also required me to purchase some longer 8mm bolts that didn't come with the kit. One comment on the washers, they were actually kind of handy in the first fit up excercise since I could keep adding them one or two at a time to get the clearance I wanted. Now that I know exactly how long they need to be it should be easy to fabricate the solid spacers. Given that some folks don't need spacers, others need 1/2" some need 1" makes it nice to have the adjustablility for determining the desired length. I really appreciate this forum for pre-educating me that I might need spacers by the way, otherwise I would have been ticked off when I went to do the brace install and had so much interference. So thanks to all those folks who traveled the road before and decided to share their knowledge. | |
| | #17 | |
Friends: 3 | <div class='quotetop'>QUOTE(Bogus Bill @ Jul 29 2007, 07:55 AM) [snapback]487055[/snapback]</div> Quote:
| | #18 | |
| Junior Member Join Date: Sep 2009 Location: Chicagoville
My Car: 2009 Prius Model: N/A Package: #6 Touring Thanks: 0
| | #19 | |
My Car: 2007 Prius Model: Package: #2 Thanks: 166
Friends: 22 | Quote:
This thread is pretty old. So if you don't get an answer, I suggest that you send a PM (Private Message) with your questions to apriusfan who, if I recall correctly, has a Touring Edition and put on all of Tom's braces. | |
| | #20 | |
| Rare Under-30 Priuschat Member Join Date: Jun 2008 Location: Chicago, IL
My Car: 2008 Prius Model: N/A Package: #3 Touring Thanks: 9
Friends: 9 | Quote:
I would also be interested, so a public post here would be helpful. | |
| 2007, brace, member, prius, rear, strengthening, suspension, tom's, toyota |
| 2007 Prius - Soon To Be New Member | Dahgu | Gen II Prius Main Forum | 2 | 09-09-2007 06:06 PM |
| New member and I just bought a 2007 Prius! | Jaibyrd | Gen II Prius Main Forum | 13 | 08-13-2007 11:15 PM |
| Tom's Floor Strengthening Brace | adamorzol | Gen II Prius Modifications | 4 | 05-09-2007 12:44 PM |
| Do you think the Prius rear suspension is too low? | silentak1 | Gen II Prius Main Forum | 8 | 12-05-2006 02:42 AM |
