| This is a discussion on Help with debadging within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; As to the purpose of the holes under the fender HybridSD badges, this picture extracted from a Toyota-EU document shows ... |
Help with debadging
| | #31 |
My Car: 2008 Prius Model: Package: #6 Touring Thanks: 94
Friends: 2 | As to the purpose of the holes under the fender HybridSD badges, this picture extracted from a Toyota-EU document shows that in that market there are side marker lights in that location: http://priuschat.com/forums/attachme...1&d=1208607295 And they can be gotten, $89 !!!, here: Sigma Automotive – Toyota Hybrid Prius 2004 - 2009 OEM & JDM auto accessories Last edited by Rokeby; 04-19-2008 at 08:38 AM. |
| | #32 |
Friends: 0 | Well, this morning I just pulled the front-of-hood "T" logo off mine, following krousdb's advice of "just yank", although I did so slowly by prying carefully up a little with a non-marring tool [screwdriver with tape over it] and letting it sit there under that strain for several minutes while the sticky started to slowly separate. Helped it separate along by punching another screwdriver through the "web" of adhesive as it started to come up, and eventually the thing could just be pulled off the car. . So now I've got a grayish "T" oval of sticky gunk on the hood, and will try to remove same without making the same kind of mess I made of the rear one [but managed to recover semi-gracefully]. . Basically, whatever the right solvent is will be determined on a noncritical out-of-the-way area in the paint, I expect coupled with a good bit of finger-rubbing to roll the stuff off. Then comes the problem of filling the holes [Dan said clear RTV was fine] and touching up. But I'm thinking maybe of painting some *other* kind of logo over the area to help visually hide the bulge that hints that something was supposed to go there. [Suddenly, the Mack bulldog comes to mind...] . Maybe a frontal pic and a little photochopping work to play with concepts is in order... . _H* |
| | #33 | |
| Senior Member Join Date: Jul 2005 Location: Raleigh, NC
My Car: 2004 Prius Model: I Package: #7 Thanks: 9
Friends: 10 | Quote:
| | #34 |
Friends: 2 | Temps in our beloved Ballamer reached 75 deg in mid afternoon. I have been waiting for a month for temps to get above 60 deg to debadge the rear hatch. By way of prep, I read debadging threads on at least four different marque forums. The recommended process ranged from a combination of heat guns and various petrochemicals to just grabbing the badge with your fingernails and pulling. I figured there was a simple way somewhere in the middle of the range. I parked the car with the rear hatch facing south, into the noonday sun. Then I made a simple tool equivalent to a popsicle stick tapered for about 1/2 inch to a near chisel point. A half an hour later, the hatch was hot to the touch. I grabbed one end of a badge with my fingernails and pulled firmly outward. The adhesive stretched slightly, maybe 1/8 inch.. With the chisel end of the tool I pushed gently against the stretched adhesive close to where it was stuck to the car. The adhesive let go for about 1/16 - 1/8 inch on the car side but remained stuck to the badge. As the adhesive detached from the car, I kept up continuous outward pressure and repeatedly pushed the adhesive off the car. At no time did the tool touch the paint, and the adhesive came off cleanly. No pain and no strain. I had the three rear hatch badges off in 10 minutes. It was so easy as to approach being trivial. You'd have to be really ham-handed to screw it up. Just remember to get the badge and hatch quite warm. In post #32, Hobbit was taking off the Toyota oval-T badges which are secured with stickum and pins with retainers. Thats a whole different ball game not to be confused with badges secured solely with tape as above. Last edited by Rokeby; 04-20-2008 at 12:29 AM. |
| | #35 |
Friends: 0 | Cool. My hood wasn't quite as warm yesterday, but I did manage to get all the stickum cleanly off. A little 95% isopropyl did help soften the stuff and let it "ball up" a little better. Nothing any stronger would truly leave the paint alone. . _H* |
| | #36 |
Friends: 2 | Hobbit, Are you dead set against all badging on the hood/hatch, or just the Toyota oval-T? If not totally against them, these Toyota of Japan badges might be plug-n-play as it seems to me that all Toyota models have the same size oval-T on hood and hatch/trunk. This one's from a Vitz: http://priuschat.com/forums/attachme...1&d=1208716120 And this from a Harrier: http://priuschat.com/forums/attachme...1&d=1208716120 They are from: eBay Seller: jdmpit: Parts Accessories, Action Figures items on eBay Motors Oops, sorta' off topic topic, I know. But it could be the next topic! |
| | #37 |
Friends: 2 | As to dealing with the holes under the fender HybridSD badge, this Dodge Pacifica Touring badge might fill the bill: Auto Parts People (Dunno why but there is no drawing of this badge, but its got a part number and price, $18 for that little-bitty thing!) I've seen, touched it in real life. It's about 1/2 inch by 3 inches; "Touring" painted on a chrome rectangle with radiused corners and edges. Don't know if it's plastic or metal. For a touring model, use as is with a couple of coats of high quality clear coat. For non-touring, first a little work with paint remover -- no abrasives, please -- then the clear coat. And what do you say it is if asked. Why make up some outlandish lie of course! Its the ultra long wave lunar phase sensor, or the differential gravitometer, or better yet they're the contacts for PHEV recharging. Hehehe. |
| | #38 |
Friends: 0 | Okay, I need some aesthetic feedback here. Maybe it's that I keep hearing the rods going by on the highway a half-mile away [gas prices, schmas prices...] or that I just spotted a lot of sensible "line matches" when staring at the car's nose. . ![]() ![]() . Note that I haven't actually *done* this to my car yet, it's just a photochop artist's conception. But somehow it brings to mind those raised-center mustang or whatever hoods, y'know, the one you squeeze the massive blower underneath. Or something. I'm kinda likin' this, and I'm not even sure it would hide the fact that there's a bump where the logo was... . Comments? Counter-proposals? This feels particularly weird because I usually don't sit around art-fagging about cars. Then again, if there wasn't something going on here I wouldn't have pulled the logo off in the first place. . _H* Last edited by hobbit; 04-27-2008 at 11:13 PM. |
| | #39 |
Friends: 2 | Hobbit, It has a strong resemblance to the raised certer section on the Gen1. Hmm, retro. The fumes from the rodders must really strong, nitro maybe? Ethanol? (Does this make me an aht-fag?) |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/33829-help-debadging.html | ||||
| Prius debadging attempt | This thread | Refback | 11-24-2008 04:56 PM | |
| Hood logo | This thread | Refback | 09-18-2008 04:19 PM | |
| Prius debadging attempt | This thread | Refback | 06-14-2008 07:08 PM | |
| Hood logo | This thread | Refback | 05-25-2008 01:49 AM | |
| Prius debadging attempt | This thread | Refback | 04-20-2008 04:38 PM | |
| 'Debadging' a 2006 | milhouse | Gen II Prius Modifications | 9 | 09-18-2007 05:55 AM |
