This is a discussion on Engine Block Heater Install - Did I do it right? within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(tdmalek @ Jul 10 2007, 12:31 AM) [snapback]475979[/snapback]</div> Ive got big arms and it looks pretty tight in there.[/b] ...
Old 07-10-2007, 10:14 AM   #21
FireEngineer
You won't have big arms after you do the install. One trademark of the installs I do is to leave some DNA samples behind in each car. I just did 2 installs a day apart and my arm looks like the cat used it as a scratching post.
Seeing your location, if you can wait a little I can do the install for you when I take the kids to Utica to see the grandparents.
Wayne
FireEngineer is offline
Old 07-10-2007, 10:51 AM   #22
Heikki
Heikki's Avatar
<div class='quotetop'>QUOTE(Green Hokie @ Jul 6 2007, 02:03 AM) [snapback]473722[/snapback]</div>
Thanks, Jim & Evan. The clip definitely locked in place and the tube fit like a glove in that hole... very secure with no movement at all.
I was anxious to test the result so I've been out joy riding, after plugging in the EBH for about 2 hours. To my surprise, I can't really say I noticed much of an increase in the mpg reading during the first 5 minutes. In fact, the instantaneous mpg readings were about where they usually were prior to the install. I have not driven my Prius since this past Tuesday evening, if that has anything to do with it.
Is this normal for summer weather? I think it was in the upper 80's today. Do I simply need run the EBH a little longer next time? BTW, I did confirm that the heating element itself is working properly, since I could definitely feel the heat from the engine block after plugging it in for those 2 hours.
I donīt use block heater in summer. In winter temperatures (-10 Celcius) 14 Fahrenheit consumption screen shows less than (>10l/100km) 23 mpg at first five minute segment. Second segment is approximately (7,5 l/100km) 31 MPG.
Heikki is offline
Old 07-10-2007, 01:08 PM   #23
Green Hokie
Green Hokie's Avatar
Package: S Touring
<div class='quotetop'>QUOTE(tdmalek @ Jul 10 2007, 01:31 AM) [snapback]475979[/snapback]</div>
So, how would you rate the difficulty of the installation from underneath? Ive got big arms and it looks pretty tight in there. BTW, nice pics - the first pic should help me find the slot should I attempt this.
tdmalek, if you don't mind getting a little grease on your fingers (& possibly a few scratches, as Wayne mentioned), I'd say it's a fairly easy install from below the engine. My arms aren't terribly big. Therefore, it was quite easy for me to find the opening for the EBH on the engine block (by feel) and insert the heating tube. No cuts or scratches.
If you want to attempt the install yourself and can wait a little longer, I plan on taking a bunch of photos and putting together a EBH installation procedure this weekend... as my way of giving back to this forum & its members, who have been extremely helpful to me. I'll probably post a new EBH installation thread after this weekend, if you are interested.
Pete
2007 Touring Pkg 3, Magnetic Gray Metallic
3M Ultrashield clear film on hood, front fenders, front bumper, side mirrors, headlights, foglights and top of rear bumper
Tinted Windows (Huper Optik Ceramic-40 all around)
Mud Guards
OEM EV switch
ScanGauge II
Engine Block Heater
Blocked Grill (upper & lower)
Covercraft UVS100 sunshield
Tire Pressure: 44/42 psi
Green Hokie is offline
Old 07-11-2007, 01:59 AM   #24
tdmalek
<div class='quotetop'>QUOTE(FireEngineer @ Jul 10 2007, 10:14 AM) [snapback]476083[/snapback]</div>
Wayne
Utica! Did you or the missus grow up around here? I graduated from UHS in '81.
What dates would you be in this area? I dont have the heater yet. I kind of wanted to give this a go myself but Ill decide after looking at GH's information and seeing if I can get my hand near that hole w/o getting my arm stuck. :P
tdmalek is offline
Old 07-11-2007, 02:15 AM   #25
tdmalek
<div class='quotetop'>QUOTE(Green Hokie @ Jul 10 2007, 01:08 PM) [snapback]476204[/snapback]</div>
Absolutely, I would greatly appreciate any more info you could post. My main concern is getting my hand comfortably near the slot, I can work by feel instead of sight pretty well. I am especially interested in details of how you routed the wire to the grill. Thanks GH.
tdmalek is offline
Old 07-11-2007, 10:39 AM   #26
FireEngineer
<div class='quotetop'>QUOTE(tdmalek @ Jul 11 2007, 12:59 AM) [snapback]476667[/snapback]</div>
My wife grew up in Detroit and her family moved to the Utica area some time in the mid-70's.
When will we be out that way? Don't have any firm date, sometime before school starts. But if you get your EBH and need help.....could be sooner.
Wayne
Old 07-11-2007, 12:40 PM   #27
kettledrum
Wayne,
I get up to NW Indiana on a regular basis and if you'd be willing I'd love to get an EBH installed sometime this summer. It'd be great to catch you on your way through to MI or back.
kettledrum is offline
Old 07-11-2007, 01:36 PM   #28
FireEngineer
<div class='quotetop'>QUOTE(kettledrum @ Jul 11 2007, 11:40 AM) [snapback]476880[/snapback]</div>
Wayne,
If your up in NW Indiana your all of 25 minutes from my house and street garage, if you dare brave the I-80/94/294 mess. When you get your block heater just let me know and we'll arrange something.
Wayne
Old 07-12-2007, 02:28 AM   #29
tdmalek
<div class='quotetop'>QUOTE(FireEngineer @ Jul 11 2007, 10:39 AM) [snapback]476788[/snapback]</div>
Wayne
OK, thanks Wayne. I will contact you after I get a good look at the situation.
tdmalek is offline
Old 07-12-2007, 07:59 AM   #30
kettledrum
<div class='quotetop'>QUOTE(FireEngineer @ Jul 11 2007, 01:36 PM) [snapback]476940[/snapback]</div>
Wayne
Will do.
I think my next currently scheduled trip to "Da Region" is the weekend of 8/11-8/12 for my nephew's baptism.
Thanks so much.
Want to install an Engine Block Heater yourself? This guide may help. Green Hokie Gen II Prius Modifications 176 11-07-2009 05:21 PM
MiHG to install 24 block heater's on 10-13-07 Bradlee Local Clubs, Events, and Road Trips 0 09-30-2007 04:56 PM
Help me install block heater. i will pay $ saechaka Private Sales 1 09-21-2007 01:44 PM
My Engine Block Heater install Rangerdavid Gen II Prius Modifications 66 07-09-2007 01:26 PM
DIY Block Heater Install? gpb5200 Gen II Prius Modifications 3 03-02-2007 10:41 PM
