This is a discussion on Want to install an Engine Block Heater yourself? This guide may help. within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Now you can do the next one in about 1/2 hr....
LinkBack (13) Thread Tools
Old 11-05-2008, 10:51 AM   #141
bat4255
2008 Package #2
bat4255's Avatar
Default Re: Want to install an Engine Block Heater yourself? This guide may help.
bat4255 is offline
Old 11-05-2008, 12:17 PM   #142
Lacarp
That's probably true, but it would have to be for somone like Jessica Simpson or Halle Berry. The reasons there should be obvious.
Lacarp is offline
Old 11-13-2008, 05:23 PM   #143
Santiago
Santiago's Avatar
Lacarp, you were my inspiration. If you could do it after your rough beginning, I figured I could too. Here's my "lesson learned" adventure.
I finally found the hole, and after several "dry" inserts, I greased it up and locked it in place. The key for me was to loosely secure it to my finger with a rubber band so I wasn't concerned about dropping it when I was moving it to the extreme left to insert it.
After an hour or so trying to plug the AC line into it (even though I thought I knew the proper orientation of the female plug), I finally had to release the core and rotate it a couple of times (just a few degrees) and I finally made contact.
A quick plug into AC to check it out nearly burned my probing finger but all's well that end's well. My only remaining question is how do I secure the male AC plug to the lower grill? It wants to pull out when I plug it in to the power cord.
ClearBra, 3M Tinting, BodySide Moldings, Rear Bumper Protection, SunScreen, Locking Wheel Nuts, Blocked Upper Grill, Engine Block Heater
Santiago
Santiago is offline
Old 11-16-2008, 10:43 PM   #144
TEW
I successfully installed an EBH in my 09 Prius this Friday. Thanks to Green Hokie for the guide.
My hands look like I fended off an enraged squirrel, but the block heats up nicely and the wiring is user-friendly.
-tew
TEW is offline
Old 12-02-2008, 11:03 PM   #145
Rufus T. Firefly
A123 Hymotion PHEV Prius
Is there another EBH Group Buy going on, or planned?
Rufus T. Firefly is offline
Old 12-07-2008, 07:50 PM   #146
zenMachine
Just another Onionhead
zenMachine's Avatar
I finally got around to install the EBH today. Kinda tricky but doable. Patience was key. That and a certain oblivion to cuts and scratches.
Anyhow, I recall there was a thread that discussed various ways to tie the power cord down using a patch cord, but can't seem to find it using different search terms. Any help would be much appreciated.
zenMachine is offline
Old 12-07-2008, 08:03 PM   #147
zenMachine
zenMachine's Avatar
Ah, found it!
http://priuschat.com/forums/prius-mo...install-2.html
Old 12-07-2008, 08:44 PM   #148
zenMachine
zenMachine's Avatar
And here's where you can buy a short 14AWG extension cord:
10in Outlet Saver Power Extension Cord
Old 12-10-2008, 01:59 PM   #149
zenMachine
zenMachine's Avatar
I ordered this extension cord and received it yesterday, only to realize that it's 18AWG. I thought I read in the other thread that the recommended gauge is 14AWG.
Q: Is 18AWG enough, or should I return this and get a 14? What is the AWG of the built-in cable?
Old 12-10-2008, 03:35 PM   #150
Aces
Aces's Avatar
I wouldn't use 18 AWG. When I was posting in that thread, I looked at a lot of on-line places to try to find a 14 AWG extender. I couldn't find one. and a lot of the sites don't even tell you what gauge there's are. I wish I could remember where I'd found the one I'm using. I'd bought it at least 2 years ago. And there's nothing on it to indicate who made it. My best guess is that it was at a home improvement store.
Aces is offline
block, engine, guide, heater, install
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/35035-want-install-engine-block-heater-yourself-guide-may-help.html
Réchauffeur électrique du bloc-moteur thermique - Forum Prius Touring Club This thread Refback 11-01-2009 11:21 AM
Toyota Prius engine block heater - new in box This thread Refback 10-17-2009 08:25 AM
3rd-gen block heater This thread Refback 09-02-2009 04:51 AM
1966 Lincoln Continental Exhaust Manifold, Ford Marine Glenwood Exhaust Manifold, Oldsmobile Exhaust Manifolds - Yanomamiindians This thread Refback 03-13-2009 05:24 AM
How To Tow A Honda Civic, How To Tow A 1997 Mitsubishi Mirage, How To Trailer A Motorcycle - Polarisclothing This thread Refback 03-07-2009 04:01 AM
The GPSy EV Project: 4 wheel Archives This thread Refback 02-28-2009 09:49 PM
Toyota Prius Engine Block Heater Peak Oil Garage This thread Refback 01-28-2009 01:34 PM
Installed Engine Block Heater (EBH) in my 2008 Prius - The GPSy EV Project This thread Refback 01-23-2009 04:22 PM
???????????????????????? - ???? This thread Refback 12-04-2008 11:14 PM
prius engine block heater guide - Zuula Search This thread Refback 11-22-2008 06:17 PM
Predictably Random This thread Refback 11-18-2008 06:12 AM
Toyota Prius Engine Block Heater Peak Oil Garage This thread Refback 10-21-2008 07:11 PM
eric.krause's bookmarks on del.icio.us This thread Refback 01-15-2008 11:46 AM
Engine Block Heater Install - Did I do it right? Green Hokie Gen II Prius Modifications 36 12-30-2007 03:05 PM
Engine Block Heater DIY Guide Tideland Prius Knowledge Base Articles Discussion 8 10-18-2007 08:19 PM
Help me install block heater. i will pay $ saechaka Private Sales 1 09-21-2007 01:44 PM
My Engine Block Heater install Rangerdavid Gen II Prius Modifications 66 07-09-2007 01:26 PM
DIY Block Heater Install? gpb5200 Gen II Prius Modifications 3 03-02-2007 10:41 PM
