| This is a discussion on Want to install an Engine Block Heater yourself? This guide may help. within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by efusco Having ,personally, repaired EBH cords on my car twice and my wife's Highlander Hybrid once, and ... |
| | LinkBack (13) | Thread Tools |
| | #161 | |
| Senior Member Join Date: Mar 2007 Location: Glen Allen, VA
My Car: 2007 Prius Model: Package: S Touring Thanks: 0
| | #162 | |
Friends: 6 | Quote:
| | #163 |
| Senior Member Join Date: Mar 2007 Location: Foothill Ranch, Ca
My Car: 2007 Prius Model: Package: Base Thanks: 4
Friends: 0 | It's been just over a year for me. I think mine quit this week.... |
| | #164 |
| Senior Member Join Date: Apr 2009 Location: North Andover, MA
My Car: 2009 Prius Model: N/A Package: No Package Thanks: 3
Friends: 9 | To make the plugging in and out a little easier (for the male/female connection) I've heard that dielectric grease will make the transition a little easier but where do I put the grease...right on the three plug prongs on the male end before inserting into the female end? Just didn't want to do anything I'm not supposed to...thanks in advance for the help! |
| | #165 |
Friends: 37 | |
| The Following User Says Thank You to efusco For This Useful Post: | sfvb (08-20-2009) |
| | #166 | |
| Member Join Date: Jun 2009 Location: Midwest USA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 3
To save the life of the EBH cord and plug are you saying you attach the EBH plug to an extension cord and then route that extension cord through the grill? Then one would plug that extention cord into another one which goes to the timer? Thank you for the clarification. | |
| | #167 |
My Car: 2004 Prius Model: N/A Package: Base Thanks: 108
Friends: 33 | I think you got it. The idea is that in plugging and unplugging the EBH from the mains you move the plug end of the cable to the EBH. If you make a stubby extension cord and firmly secure the cable that comes with the EBH under the bonnet the only cable you will be bending or that might pull if you are a bit sleepy and back out with it still plugged in is a short 8 inch length of flex, cheap and easy to replace. It also keeps the plug in the EBH standard cord out of the weather avoiding corrosion to the pins. Might even be a good idea to replace the plug on the short extension cord each fall (autumn) to remove a possible fail point. |
| The Following User Says Thank You to patsparks For This Useful Post: | mccats (08-31-2009) |
| | #168 | |
Friends: 37 | Quote:
I had to repair my original EBH cord 3 times in 2 years, eventually replaced the original EBH and cord about 2 years ago and started using the 8" extension and have had no issues with the new EBH cord at all. | |
| The Following User Says Thank You to efusco For This Useful Post: | mccats (08-31-2009) |
| | #169 |
Friends: 0 | Thank you both for your input. I sure don't want to have to repair or replace the EBH all of the time, so this solution makes perfect sense. Might I ask you a few additional questions? Are you coming out of the top grill or the bottom one? Looks like the pictures at the start of this thread show the bottom one. It seems impossible to get a plug through the top one on our 2010, but haven't studied the bottom one yet. Also, do you have any kind of a cap for the end of your 8" extension or just leave it as is? I live in Des Moines, IA and they use a lot of salt on the roads so assume the plug would get pretty dirty on a normal snowy day. Maybe you just keep a towel handy to wipe it off and wait until it's dry to plug it in. The dealer just left the cord right there with the EBH, so it's not routed anywhere at this time. I'll take a closer look at the pics included in this thread again, but if anyone has any pics of where they routed/attached the cord on a 2010 through the engine compartment to come out of the grill would be great to see them. Thank you again for your help. |
| | #170 |
Friends: 37 | I think you'll need to hit up FireEngineer or someone who has an EBH in a 2010 for recs of where to run the cord, I haven't investigated that as I have a Prius II. I do not cap the cord, but I think you might be able to use the cap that's on the EBH cord. Again, I don't worry about it too much b/c if it gets too corroded I can always replace it. |
| block, engine, guide, heater, install |
| Engine Block Heater Install - Did I do it right? | Green Hokie | Gen II Prius Modifications | 36 | 12-30-2007 03:05 PM |
| Engine Block Heater DIY Guide | Tideland Prius | Knowledge Base Articles Discussion | 8 | 10-18-2007 08:19 PM |
| My Engine Block Heater install | Rangerdavid | Gen II Prius Modifications | 66 | 07-09-2007 01:26 PM |
| DIY Block Heater Install? | gpb5200 | Gen II Prius Modifications | 3 | 03-02-2007 10:41 PM |
