| This is a discussion on Want to install an Engine Block Heater yourself? This guide may help. within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Thank you! Checked 3 home improvement places this morning and seems like an 8" extension might be hard to come ... |
| | LinkBack (13) | Thread Tools |
| | #171 |
| Member Join Date: Jun 2009 Location: Midwest USA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 3
Friends: 0 | Thank you! Checked 3 home improvement places this morning and seems like an 8" extension might be hard to come by. HD had a 9" but it was industrial strength and the plug was pretty big. Will continue to look around at some other places and on the net to see what else I can come up with. Thanks again! Appreciate it. Last edited by mccats; 08-31-2009 at 01:54 PM. |
| | #172 | |
Friends: 12 | Quote:
Wayne
__________________ 2010 Blue Ribbon Metallic Prius IV w/Sunroof-Solar-Navigation 2005 Salsa Red Package 6 (BC)-Retired 6/12/2009 w/89,989 miles Average MPG 54.5, Best tank MPG 80.1/932 miles 2004 Oldsmobile Silhouette "Final 500" mini-van Free engine block heater install, just ask. 163 warmer Prius done to date. Including one very special 2010 Prius. Come join us at the ChicagoPriusGroup. | |
| | #173 | |
Friends: 37 | Quote:
| | #174 |
Friends: 0 | Thanks for the input. Have been reading more threads this morning on the EBH. Enjoyed the older posts regarding the DNA Distribution Tour and the Tour Map. After reading all of this, I sure hope the dealer knew what they were doing when they installed ours. More than likely they haven't installed in as many as Wayne has. When I look on the Toyota website at our records, the only thing I know about it is that is says it is a EBH 900. Will check out Walmart, Staples, etc for the 8 inch cord. Sounds like I need a 14 or 16 guage from what I read. Will check into a wire loom also. Yes, after reading a bunch of threads, it does sound like the EBH cords aren't that sturdy. |
| | #175 |
My Car: 2004 Prius Model: N/A Package: Base Thanks: 118
Friends: 33 | I'd make a cord. I know in Australia I can buy the plugs and sockets to make an extension cord. Buy the socket and use the cord from an old washing machine or something else that is designed for a wet environment and has a molded sealed plug. The socket will be out of the weather under the bonnet or behind the bumper cover. Wrap the plug and socket where the EBH and extension join in heavy plastic to protect it from water. (liability waver) If you don't have the skills to do this have an electrician do it for you. |
| | #176 |
| Member Join Date: Apr 2009
My Car: 2009 Prius Model: N/A Package: N/A Thanks: 0
Friends: 1 | First, thanks a lot for this instruction, I just used it to install my EBH and it made my install absolutely peachy. Second, just adding to the pile of data, my install was super-fast and easy - it took me longer to route the cable than it did to install the heater element! Locating the hole in the engine block was easy (and 90% of the work) once I knew what I was looking for. I zip-tied the plug itself on the vertical frame of the front horizontal grills, just next to the driver side fog light - it doesn't move so I think I'll be okay with the cable flex issue. The beauty of this is that I can use the protective plug cover that came with the EBH. Time will tell if I have a good install... |
| | #177 |
| Junior Member Join Date: Oct 2007
Friends: 0 | I am the first to admit when I'm unsuccessful. I have a 2008 Prius. I tried installing the EBH according to the guide. It took me a while to find the hole, and I had to turn the clip 90 degrees, otherwise it didn't clip to anything. So with the EBH in, its orientation is such that the clip is on the down side of the EBH, the flat side of it is facing front and thus the cable would have to be oriented towards the back of the car. I did try to rotate the EBH and definitely noticed that was the only possible way. The problem I ended up having is that there seems to be no place for the cable, there is some kind of pipe in the way of the cable, not where it needs to go into the EBH but because it is shaped at 90 degrees from the EBH. After 3 hours and multiple attempts I removed the EBH using a screw driver to push the clip. All I have to show for it is scratched hands... I am in the Boulder / Louisville / Superior Colorado area. Is there anyone nearby that would be so kind to help with the installation? Thanks, Amnon
__________________ Amnon Driftwood Pearl 2008 Touring package #6 |
| block, engine, guide, heater, install |
| Engine Block Heater Install - Did I do it right? | Green Hokie | Gen II Prius Modifications | 36 | 12-30-2007 03:05 PM |
| Engine Block Heater DIY Guide | Tideland Prius | Knowledge Base Articles Discussion | 8 | 10-18-2007 08:19 PM |
| My Engine Block Heater install | Rangerdavid | Gen II Prius Modifications | 66 | 07-09-2007 01:26 PM |
| DIY Block Heater Install? | gpb5200 | Gen II Prius Modifications | 3 | 03-02-2007 10:41 PM |
