| This is a discussion on Scan Gage 2 within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; How do you stop from timing out when ICE is off? Where do you mount cable & get it to ... |
Scan Gage 2
| Senior Member Join Date: May 2007 Location: Endwell, NY
My Car: 2009 Prius Model: Package: #3 Touring Thanks: 0
Friends: 0 | How do you stop from timing out when ICE is off? Where do you mount cable & get it to stay? Last edited by nickfromny; 01-30-2008 at 09:00 AM. Reason: Typo's |
| "Dream" Prius Join Date: Apr 2007 Location: Cincinnati, KY
My Car: 2010 Prius Model: III Package: N/A Thanks: 3
Friends: 6 | |
Friends: 0 | OK. So How do I do that? |
| Member Join Date: Apr 2007 Location: Canton, MI
My Car: 2008 Prius Model: Package: Thanks: 0
Friends: 0 | The manual shows how to adjust the settings (i.e. fuel type (diesel, gas, hybrid), fuel tank size, engine displacement, etc) which can be found here: ScanGaugeII - Frequently Asked Questions Hope that helps a little more. |
My Car: 2007 Prius Model: Package: B Thanks: 4
Friends: 0 | If you use velcro to mount the SG II on the dash to the left of the MFD, the cable runs straight down the dash on the right of the steering column. It can then be zip-tied to the harness' under the dash. It doesn't move in this location. If it's a problem get some velcro with double sided tape on it. Fold one side (I choose the hook side) around the cable, just a small piece, and put a small loop piece on the dash. The cable will then stick to it and say in place. Makes it easy to remove and reinstall. The velcro can easily be removed from the dash with no residue.
