| This is a discussion on automatic electric grill blocking within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Wouldn't it be easier to have two sheets of plastic layered together with slots cut in them and just slide ... |
| | #21 |
| Senior Member Join Date: Jan 2006 Location: San Antonio, TX
Friends: 0 | Wouldn't it be easier to have two sheets of plastic layered together with slots cut in them and just slide one of the sheets up or down so that the slots are out of alignment and it would block any air from flowing through, then move it back and the slots line up allowing air through again. A lot less complicated then louvers or blinds I think. |
| | #22 | |
| I study nuclear science... Join Date: Apr 2008 Location: San Diego
My Car: 2006 Prius Model: N/A Package: #3 Thanks: 1
| | #23 |
| Member Join Date: Aug 2008 Location: Outside Detroit, MI
Friends: 0 | I think the exterior temp would be the best answer. To get fancy, make them open if the car gets close to overheating. You want to keep the ICE warm (That sounds wrong) to allow it to shut down while driving. At highway speeds, having it open would probably be a good idea to prevent it from overheating. |
| automatic, blocking, electric, grill |
