This is a discussion on Making Aerodynamic hubcaps and rear wheel skirts? within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I would rather have something along the lines of this. My dad rebuilt three 56 Ford Fairlanes and they all ...
Old 02-16-2008, 02:24 AM   #21
priusfreak
priusfreak's Avatar
Default Re: Making Aerodynamic hubcaps and rear wheel skirts?
I would rather have something along the lines of this. My dad rebuilt three 56 Ford Fairlanes and they all had these on them.
priusfreak is offline
Old 02-16-2008, 07:31 AM   #22
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
Just exactly what I want on the Prius, where can I get that from?
patsparks is online now
Old 03-28-2008, 08:20 PM   #23
Bob64
Sapphire of the Blue Sky
Bob64's Avatar
Originally Posted by Bob64 View Post
I'm thinking of just wrapping the outer portion of my trim ring with a piece of shrink-wrap-like material. Bam, blocks the air and dirt cheap.
Edit:
Actually, since my plastic wrap idea is such a great idea, I'm going to do that right now. Pictures after I borrow my friend's digital camera.
pix:
http://i11.photobucket.com/albums/a1...s/IMG00054.jpg
http://i11.photobucket.com/albums/a1...s/IMG00053.jpg
http://i11.photobucket.com/albums/a1...s/IMG00052.jpg
Bob64 is offline
Old 04-12-2008, 09:39 PM   #24
Sheepdog
C'Mere Sheepie!
Sheepdog's Avatar
Friends: 6
Um, Bob? I realize it's a work in progress, but that looks like something in tupperware- that spoiled!
Sheepdog is offline
Old 05-23-2008, 08:08 PM   #25
jdm-option
Originally Posted by TheForce View Post
NICE! but the skirts don't flow well with the car. Google does a horible job at translating. Is the something offered in Japan?
This is the same body kit from Japan, named as A-CORO(ecolo from ecology) but without rear wheel skirt. Looks nice, right ??? It's originally designed to improve the fuel efficiency of Prius at high speed driving even better by paying the very detailed attention in aerodynamic theories. It stands out with decent and noble shilhouetts, not too much of agressiveness, dsitinct from all other Prius and furthermore it's more A-COROgical.
Ask info@jdmotpion.com for more information.
Click the image to open in full size. Click the image to open in full size.
jdm-option is offline
Old 05-25-2008, 12:24 AM   #26
Bob64
Bob64's Avatar
Yeah, which is why I "upgraded em" (they were falling apart a bit) with the aluminum "racin" hubcaps... which I've come to have the opinion that the cheapest place sells the exact same ones as the more expensive place.
If I had a better way to mount the plastic to the rings, then it would look better, but the method I used was physical (stuffed them in between the ring and the wheel and hoped they stayed out of the brakes).
Bob64 is offline
Old 05-25-2008, 09:04 PM   #27
Bob64
Bob64's Avatar
I wonder if theres a way to easily calculate where the air stems point out if I added a valve extension so that I can drill through the aero hubcaps and stick them through... without making an overly-large hole...
Bob64 is offline
Old 05-25-2008, 10:26 PM   #28
donee
Hi Bob,
I ended up with 1/4 inch radius, by about 1 inch long oval holes. This was because the valve stem is on an angle, and the extension ends up further toward the center.
donee is offline
Old 05-26-2008, 02:02 AM   #29
Bob64
Bob64's Avatar
Ah, but the problem with the aluminum "racing" moons that I have now, is that it extends past the wheel and is curved, adding additional complexity into calculating its location...
Need a way to somehow figure out where the valve stem is :/
Bob64 is offline
